BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Florida > AC Help on E92
      06-04-2019, 03:45 PM   #1
Kentavian328i
Drives: 2007 BMW 328I
AC Help on E92
Hey guys I posted about this before but never got much help so here goes again... I have a 2007 BMW 328i coupe. I have this one particular issue. I switched out the OEM radio and put in a Eonon aftermarket radio around this time last year 6/10/18. It was completely plug in play. After the install I lost my AC. I only have heat and it only blows through the defrost vents and not any other vent on the car. Even when driving it the heat comes through the defrost making it extremely hot to drive during the day. Has anyone installed an aftermarket radio and experienced the same problem? I need help so I can get back to driving my car regularly... Its hot AF here in Tallahassee Fl so i need my AC back ASAP
      06-04-2019, 09:14 PM   #2
Daniel08E93
Daniel08E93's Avatar
Drives: 2008 335i E93
Pull head unit out make sure all clips are all the way in on your climate control and also make sure you didn't punch any wires when putting everything back take your time and check wiring to make sure nothing is being bent you will be able to tell if they were being pinched or not, if your climate control unit is working it shouldn't be your fuse but just double check to make sure you don't have any clown fuses for your ac
      06-05-2019, 07:17 AM   #3
Kentavian328i
I checked the wires and everything seemed to be in correctly and no pinched wires. I will unhook everything and then plug it and back in and see what happens. I looked at the fuses but ill test them to see if anything is blown. Keep you updated Thanks!
      06-05-2019, 07:11 PM   #4
Daniel08E93
Good luck man hope this works, where are you located?
      06-05-2019, 07:14 PM   #5
Kentavian328i
I'm located in Tallahassee Florida. I just scanned the A/C modules an this what I got
      06-05-2019, 07:16 PM   #6
Kentavian328i
I gotta diagnosis the codes
      06-05-2019, 07:17 PM   #7
Kentavian328i
Maybe it's a fuse or relay
      06-05-2019, 08:01 PM   #8
Daniel08E93
Those are a lot of codes if you were closer I'd help personally but you might be right it could be a fuse or relay just double check them and pull them to see if any are burnt that are associated with the ac or climate controls
      06-05-2019, 08:03 PM   #9
Kentavian328i
I'm going to pull them in the morning and check to see if that's the issue. All the code related to the same thing so I'm thinking a relay or fuse
      06-06-2019, 10:48 AM   #10
Daniel08E93
It's looking like it just keep thread updated
      06-06-2019, 10:50 AM   #11
Kentavian328i
No problem 👍🏾
      06-22-2019, 11:15 AM   #12
Hart23
Drives: 2007 328xi
Any updates?
I am having the same issue after installing a eonon HU. did you resolve the issue?
      06-22-2019, 11:18 AM   #13
Kentavian328i
Still working on it. I've been keeping up with another forum an one guy said that everything has to be plugged back in tightly or the actual ac unit may be bad so I'm going to test both today
      06-25-2019, 01:01 PM   #14
domikiki
Drives: BMW 335i
This is the a/c section of the service manual hope it helps.
