Can't quit that long roof... New E91!
12-24-2023, 03:51 PM | #111 |
Rep 3,038
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
E93Seattle (Racerbruce)799.50 |
12-24-2023, 04:32 PM | #112 | |
Rep 553
Most California vehicle "operators" (IMO the "drivers" term can not be used) have no idea what rear fogs are. And yes, for them the fog here lays in front the car only - the "operator" does not consider the fact that there are maybe other cars behind Newer Tesla's and some Audi's have rear fogs available from the factory. I see ^ cars with rear fogs on at all times, irrespective of weather conditions. I feel that same goes here for FLA/5AC. Most have no idea what is that "blue" light on the dashboard. Hence, E9X had 5AC available for M3 & E7X for E71 in NA I scored my E70s rear fog switch from ECS at some crazy sale price; plan to put it on next summer. I would love to do E90 next, so will need those printed parts
12-24-2023, 06:36 PM | #113 |
Rep 3,038
Let me know if you can use one POBEP E70 was easy, just follow the guide that's out there for the wiring addition. Took about five extra minutes!
As for today... tackled the upper windshield seal. I had a tough time with it getting the edges on. Finally occurred to me to slide them into place first, then do the middle section. Derp. So easy after I pretty much ruined the piece. Hope it stays down and isn't too beat up from the process. Practice for next time!!! |
12-24-2023, 06:47 PM | #114 | |
Rep 3,914
StradaRedlands4970.00 |
12-25-2023, 01:18 PM | #115 | |
1208
Rep 2,835
But the "rear fogs" were setup to light up under heavy braking as an extra set of brake lights. |
12-27-2023, 01:36 PM | #116 | |
Rep 468
Drives: Break My Wallet
https://autocatalogarchive.com/wp-co...3-2007-USA.pdf Page 9 I wonder if this feature is only for North America or includes ROW. I think the latter. |
12-31-2023, 12:04 AM | #117 | |
Robot
1693
Rep 2,193
12-31-2023, 09:49 AM | #118 | |
Rep 3,038
I'm hoping to start in on the heavier mechanical items the next few days after focusing on the easier/cosmetic ones. Rad/pump/oil cooler/hoses/flange/belt are all kind of related and make sense to do at the same time, but a lot of moving puzzle parts to keep organized! Still waiting on one hose for the oil cooler upgrade which hopefully comes in Wed. Otherwise everything is ready to go! Last edited by StradaRedlands; 12-31-2023 at 11:23 AM.. |
12-31-2023, 08:22 PM | #119 |
Rep 3,038
Started in on it today. Jacked it up, pulled the belly pan, and did the easy job of the power steering fluid/filter. Sort of easy, as that lower line did not want to let go. Had to cut a cm or so away to get it off.
Pulled the fan as a first step to getting the radiator out as well as opening up access for the OFHG, belt, etc. Snapped the nub no surprise. Finally pulled the cover off the engine and saw that a major leak was from the oil filler cap. I think the VCG is probably bad as well, but for sure the cap and gasket need replacing. I'm going to focus on cleaning as much of the gunk off as I can before I start reassembling. I took a look at the water pump and it was ridiculously covered in oil slime. Yuck. |
01-01-2024, 02:32 PM | #120 |
Rep 3,038
Today is clean the engine bay day and maybe do the water pump/stat if I'm really motivated day. Started this morning by further disassembling the front of the engine.
This is what happens when Mickey Mouse enters the public domain: Walked about 4mm toward the edge. Didn't jump: But hey, the coolant was blue! And probably added 15 years ago in Munich: Last edited by StradaRedlands; 01-01-2024 at 07:52 PM.. |
9
POBEP368.50 M-technik-32103.00 Cal122191.50 lowrydr3101692.50 Mike K322.00 E93Seattle (Racerbruce)799.50 BRG_N54302.50 xlr88r290.50 Greyfox1207.50 |
01-01-2024, 05:40 PM | #121 |
Rep 3,914
A few good catches there!
StradaRedlands4970.00 E93Seattle (Racerbruce)799.50 |
01-01-2024, 07:49 PM | #122 |
Rep 3,038
Didn't get to the bottom yet, but the engine is cleaned up, did VANOS seals, new tensioner/pulley/belt, and upgraded to a X3 oil cooler.
Tomorrow the new radiator goes on, water pump/stat get R&Red, and new hoses all around. Fingers crossed everything falls into place! One hose is still in the wind, so maybe everything minus that! Only piddling jobs are changing the brake fluid and tracking down the windshield wiper reservoir leak. Can do those any time. Took me all day, and finished in the dark, but here she be: |
01-02-2024, 08:42 AM | #123 |
Rep 583
well done strada!
significant progress. is the oem coolant always a "blue" tint?? |
01-02-2024, 09:19 AM | #124 |
Rep 3,038
E93Seattle (Racerbruce)799.50 Greyfox1207.50 |
01-02-2024, 09:31 AM | #125 |
Rep 583
01-02-2024, 10:07 AM | #126 | |
1453
Rep 2,140
VAG cars get pink and GM etc is orange - again, all having their own mythical formulas to keep their ICEs running. |
01-02-2024, 10:37 AM | #127 |
Rep 583
01-02-2024, 10:38 AM | #128 | |
Rep 3,038
I try to use BMW's concentrate https://www.fcpeuro.com/products/bmw...ze-82141467704 but also have Wal*Mart's pre-mix on hand https://www.walmart.com/ip/Super-Tec...0-50/341857559 All my cars have some percentage mix of the two along with some Redline Water Wetter just for fun https://www.fcpeuro.com/products/wat...ne-83522-80204 I carry a gallon of the sealed pre-mix in the cars as it's convenient to carry and doesn't leak. |
01-02-2024, 10:53 AM | #129 |
1453
Rep 2,140
01-02-2024, 11:42 AM | #130 |
Rep 1,570
some brand dont mind what dye they put. I have BMW coolant and it's green.
01-02-2024, 07:47 PM | #131 |
Rep 3,038
And, done! Well, still waiting on one hose, and I need to see if it actually starts and everything, but I'm saying done!
What all the fuss was about: Where it came from (packed on oil and grime was kind of miserable): This is what happens when you don't take care of your car! Housing was covered in oil and the gasket was the flattest and hardest of any I have ever replaced! Front end is back together minus the oil cooler hose (from a Z4). So close!!! Bin goes out tomorrow: Cleaned up, but still on stands waiting for the finishing touches: About four hours of work today doing the cooling system. Everything was replaced minus the short rubber elbow connecting the engine pipe to the back of the water pump. I'll take my chances. Previous owner did not do regular maintenance on it, which is a bummer. But that's why he was selling it low... I think it was a fair price based on the condition. I can't tell if the oil pan gasket is really bad or it's just oil leaking down from the top end. Fingers crossed the latter as I really don't want to do the OPG anytime soon. |
01-02-2024, 07:54 PM | #132 |
322
Rep 395
Drives: 2011 e91 328i RWD
Nice work! Actually, those old hoses don’t look too bad considering the lack of maintenance from the DPO.
