10-28-2023, 07:55 PM | #1 |
Speed Racer
29
Rep 68
Drives: 2013 F30 335i M-Sport
Washing Car at Home
I just started getting into washing my car at home and so I got a used pressure washer off of FB Marketplace, but it was just my luck that the damn thing literally failed within the first few minutes of me using it. The motor literally seized and is useless now. So I was looking for ways to wash my car at home with the two-bucket method but no pressure washer. I know people always say to “lubricate” the car before applying contact but since I can’t use a foam cannon at the moment what do you all recommend? Should I just hose it down and then start contact washing or what? I appreciate any response to help me out!
10-28-2023, 08:19 PM | #2 | |
15
Rep 21
drf3028.50 |
10-29-2023, 07:30 AM | #3 |
Rep 16,102
Foam cannons are highly over rated. It looks cool being able to cover the car with suds in a matter of seconds, but once the suds are there you still have to go through the normal procedure of washing by hand. Pre-rinsing is a must to get large dirt and sand particles off the car, but you don't need a power washer to do that. Pre-rinsing provides all the 'lubricating' necessary. What you need to keep lubricated is the sponge.
10-29-2023, 12:59 PM | #4 |
Rep 3,878
It sounds like you have misunderstood what foaming is all about.
Foaming is the first stage of washing - you foam (using a power washer or a pump-sprayer), you let it do its thing for 3-5 minutes and then you rinse, ideally with a power washer! Depending on the foam you use, this, in combination with a power washer, can get up to 90% of the dirt off your car! And this is exactly what foaming is all about! It is NOT for lubrication!! Lubrication comes from the shampoo in your bucket and a soaked- enough wash mitt! Plus the fact that the car would already be wet from the rinsing. But you NEVER just foam and start hand-washing without first properly rinsing (ideally under pressure). So to answer your question - if your power washer is temporarily unavailable, I'd use a pump-sprayer and then rinse thoroughly with a hose. Then you carry on with the 2-bucket wash carefully, with frequent cleaning of the wash mitt. Don't forget a dirt trap in your bucket(s) Good luck! P.s. Please don't use a sponge...! Use a micro-fiber wash mitt or a micro-fiber-covered sponge. Bare sponges is what our grandparents (or my sloppy colleague) use together with a dish-washer detergent to wash their cars.....
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
10-29-2023, 07:46 PM | #5 |
Speed Racer
29
Rep 68
I appreciate everyone’s replies to this thread thus far. This concept of “washing at home” is definitely starting to make more sense now. I washed my car today first by rinsing the entire car with a hose spray nozzle, then cleaning the wheels and rinsing with wheel cleaner, and then finally doing my contact wash with the two-bucket method. To finish off, I rinsed off the soap and then used Turtle Wax wax and dry as a drying agent to dry the car. I was overall pleased with the results with the exception of a few things:
1) There were some areas, mainly on the bottom of the car near the bumpers and fenders, where dirt was trapped and wasn’t coming off even after the contact wash and rinse. How do I get those parts of debris and dirt off? I have the same question regarding bugs and things on the front bumper of the car that seemingly don’t come off. 2) I was using some microfiber towels I got from Walmart to dry the car but they felt like they were causing friction against the surface of the car and didn’t feel smooth. Any drying towel recommendations? 3) Overall, what is a good starring set of detailing tools and items for the car in terms of detailing wheels, interior, exterior, etc? Thanks everyone! |
10-30-2023, 03:48 AM | #6 |
Rep 3,878
1) For those areas, especially if they have not been thoroughly cleaned before or typically in the spring - you need a tar remover. You typically spray it after the foaming phase, let it sit for 3-5 mind and rinse. You can of course also use it during the hand-wash when you discover such areas, just don't forget to rinse after a few min before continuing with the hand wash.
What you should also have readily available is Iron remover. It is applied the same way as the tar remover. It will dissolve most of the stubbern iron particles which typically attach behind the wheels (brake dust...) and on the trunk / rear-bumper. I typically use iron remover once a year, after the winter. tar remover is used on demand, but also typically after the winter when it is mostly needed and 1-2 times in addition during the year, as required. My point is - they are both not part of the regular wash but used as needed. 2) There are MANY car detailing communities and test reviews. You can look there for recommendations. Liquid Elements Silverback XL and Liquid Elements Orange Baby XL are two of those with excellent reputation based on tests. 3) This is a tough one to answer shortly. It really depends on your level of involvement. I would recommend adding new things to your artillery as you go along, based on your needs and desires. As an absolute minimum - power-washer, quality MF mitt (preferably at least 2), quality MF multi-purpose towels, quality MF drying towel(s), foam, shampoo, tar remover, iron remover. For the interior you need an all-purpose-cleaner suitable also for displays and sensitive surfaces, an ultra-SOFT, quality MF towel dedicated for use on screens and sensitive surfaces, something for the trim (trim cleaner / trim restorer / etc.). If you have leather seats - that's a topic on its own as well, but even alone for the steering wheel - leather wipes with conditioner as a minimum, ideally some leather balm to apply annually. And at the end - to wash all MF towels and mitts - a MF washing detergent (no, you do not wash them as you wash your clothes!). A very large domain, car detailing But a good hobby too
drf3028.50 |
10-30-2023, 08:36 AM | #7 | |
Rep 481
Skyhigh1891.00 |
10-30-2023, 08:39 AM | #8 |
Rep 3,878
That's maybe a bit excessive but of course can be done I use 2, whereas one is usually dedicated to the high-risk areas (lower part of the vehicle). Dirt traps in the buckets are also a good idea.
10-30-2023, 08:42 AM | #9 |
Rep 481
Correct, I use two buckets, portable battery operated power washer, foam gun and 6 wash mitts lol, and two drying towels, might be buying leaf blower, my car has ceramic coating and it will be easy to dry using leaf blower.
10-30-2023, 09:29 AM | #11 | |
Rep 3,878
Recommend a car dryer such as BigBoi (https://ibigboi.com/) I am quite happy with mine. It takes much longer than using towels but it is 100% safe for the paint and it is fun, especially in the winter. I apply a towel only on the windows since it speeds things up and there is no risk of scratches.
10-30-2023, 10:06 AM | #12 | |
Rep 481
https://www.youtube.com/shorts/k8cmCzC-dOs https://www.youtube.com/shorts/FS5Wk1RtR6g |
10-30-2023, 10:17 AM | #13 |
Rep 3,878
Feel free to give it a try not saying it doesn’t work at all, it is just way too slow and inefficient. There are tools made for that. And hot air is very nice in the winter too.
P.s. both my cars are waxed and quite hydrophobic too.
10-30-2023, 11:25 AM | #14 |
Rep 16,102
I'll use my leaf blower to get rid of most of the water that remains after my initial rinsing, but it doesn't get all of it off, and wouldn't replace drying by hand with microfiber towels anyway, as there would still be water spots. After rinsing and blowing I use Optimum No Rinse. I use four or five towels. When the first wash towel is dirty I use the first drying towel as the second wash towel, and so forth.
As for a cordless pressure washer, I have this. It can use a garden hose for water supply or a bucket with the included siphon hose. It also shares the battery with other 24v Sun Joe tools. If you already have one of them buy the bare washer option. https://www.amazon.com/Sun-Joe-24V-P...7-857e17e03685 |
