      11-01-2021, 12:55 PM   #89
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Very creative solution on the radiator AT lines. By doing it the way you have it instead of blocking it off, does that mean your coolant will continue to circulate and help cool the engine?
Dieselboy448.50
      11-01-2021, 05:07 PM   #90
Dieselboy
Dieselboy's Avatar
449
Drives: '09 135i
I doubt it'll make much of a difference. I could have left the AT cooler on and just pulled the trans lines to act as a second tiny cooler but I'd rather keep it tidy under there.
2009 Widebody 135i ///Build Thread
Instagram: ///TheAxisGarage
If you ride like lightning, you're gonna crash like thunder.
      11-03-2021, 01:18 PM   #91
amg6975
amg6975's Avatar
500
Drives: '12 M1.5, '05 ZHP, '98 M3/4/5
Think you could route the engine oil through it before the air to oil cooler? Bet that would help out oil temps quite a bit.
Dieselboy448.50
      11-05-2021, 02:44 PM   #92
Dieselboy
Dieselboy's Avatar
449
Drives: '09 135i
The beautiful GS6-53BZ MT showed up today. I've got almost everything I need to do the swap so I'm going to start removing the AT this weekend.
Decided to go with XClutch. Purchased the Chromoly Flywheel, 9 in. Twin Solid Organic Clutch Disc kit (XKBM23595-2G), good for 900ft-lb
Still waiting for the Turner coolant relocation tank.....
      11-06-2021, 06:55 PM   #93
Dieselboy
Dieselboy's Avatar
449
Drives: '09 135i
Auto trans out, took about 6 hours. Getting to the trans/engine bolts was the hardest part. Just waiting on the clutch and flywheel now.
houtan707.00
      11-09-2021, 04:03 PM   #94
Dieselboy
Dieselboy's Avatar
449
Drives: '09 135i
Removing the AT wiring harness.
Appreciate 3
houtan707.00
wdb4732.00
      11-14-2021, 05:12 PM   #95
Dieselboy
Dieselboy's Avatar
449
Drives: '09 135i
Still waiting on the clutch, shifter linkage and some brackets/misc parts.
houtan707.00
      11-14-2021, 10:58 PM   #96
SKI-R
Working towards usefulness
159
Drives: 128i, Tundra, B8S4
Usually a spectator while people build/solve given that everyone has their ideas that work for them, but ….if you’re waiting on shift linkage have you considered alternatives……such as:
https://coolerworx.com/shop/short-sh...r-bmw-gearbox/
or something similar?
For me the difference in feel versus the stock linkage was literally night and day.
Really appreciate your documentation.
09 128i Slicktop - TCKlines, KMac Plates, M3 RSFB, M3 RSB, Hotchkis FSB/endlinks, 1M brace, Wavetrac, Coolerworx, JKVK headers, RPM Motorsport Tune, Yokohama A052 255/40/17s
Dieselboy448.50
      11-15-2021, 06:47 AM   #97
Dieselboy
Dieselboy's Avatar
449
Drives: '09 135i
Thanks, yes I was actually considering the RTD short shifter, but ended up buying the Turner adjustable short shifter and upgraded bushings. I figured this would be a good option to start with, and I can always upgrade to a self-centering shifter down the road if I feel the need. Wondering if I should upgrade to the UUC DSSR while I'm at it.
      11-21-2021, 01:32 PM   #98
Dieselboy
Dieselboy's Avatar
449
Drives: '09 135i
The 9" Solid Organic Twin Disc Clutch from XClutch showed up today. Most of the parts I need to finish up the trans swap and to get the motor started keep getting pushed out so may be a while before the next update..
houtan707.00
      11-21-2021, 01:53 PM   #99
Clappede82bucket
Burn rubber not oil
Clappede82bucket's Avatar
England
Drives: E82 E46
Looking good 👍
Dieselboy448.50
      11-24-2021, 05:01 PM   #100
Dieselboy
Dieselboy's Avatar
449
Drives: '09 135i
Bye bye torque converter, hello clutch. I can finish the catch can plumbing and figure out where I'm going to relocate the vacuum canisters while I wait for parts..
Appreciate 3
houtan707.00
wdb4732.00
      11-29-2021, 05:07 AM   #101
Yeineken
Yeineken's Avatar
Drives: '11 135i M Sport
'11 135i  [8.20]
'16 Ford Hatchback  [0.00]
'15 X5  [10.00]
Man this is a great build so far!
Dieselboy448.50
      12-03-2021, 07:41 PM   #102
Dieselboy
Dieselboy's Avatar
449
Drives: '09 135i
Turner expansion tank relocation kit arrived (ordered in Sept), and it looks like a few more parts shipped out. Hopefully I can make some decent progress this month.
Attempting to remove the pilot bearing using grease and Pascal's Law, haven't been able to get it to budge though. May need to get a lever actuated grease gun... Youtube made it look easy using this method...
      12-06-2021, 10:17 AM   #103
wdb
dances with roads
wdb's Avatar
4732
Drives: '07 E86, '02 996, '95 Seven
Attachment 2757417
Why am I looking at the bell housing, etc? The pilot bearing should be in the end of the crankshaft, or in the flywheel...
      12-06-2021, 11:35 AM   #104
Dieselboy
Dieselboy's Avatar
449
Drives: '09 135i
This pilot bearing is located in the center of the transmission input shaft.
BMW PN: 21-20-7-536-792 - Clutch Pilot Bearing, Flywheel Bearing, Cylindrical Roller Bearing R 219900
      12-06-2021, 11:47 AM   #105
wdb
dances with roads
wdb's Avatar
4732
That's a first for me. What does it pilot into? Or maybe I should ask what pilots into it...
      12-06-2021, 05:39 PM   #106
Dieselboy
Dieselboy's Avatar
449
Drives: '09 135i
It pilots into the shaft on the flywheel. You can see it in the second photo in post #100.
Ok, had to bust out the big guns. Couldn't have been easier, 3 pumps and it popped right out. Always use the right tool for the job!
(You vs. the guy she tells you not to worry about)
wdb4732.00
      12-07-2021, 08:40 PM   #107
Dieselboy
Dieselboy's Avatar
449
Drives: '09 135i
Random black friday purchase. I think they look good, and should make rev-matching downshifts easier.
      12-07-2021, 08:55 PM   #108
Bari1695
Drives: 08’ 135i
Can you provide the part numbers used to convert from auto to manual? I’ve search the forums, but there isn’t any information in regards to the 1 series, specifically the 135i.
      12-08-2021, 11:25 AM   #109
Dieselboy
Dieselboy's Avatar
449
Drives: '09 135i
So, it's pretty much the same as the e90. Vehicular DIY made a great 3-part series on YouTube to walk you through step-by-step, this is the guidance I used for the swap. https://www.youtube.com/watch?v=szg15efwGzY
I plan to put together a DIY once I finish the swap. I'm still waiting on a few things before I put the trans back in and do the coding. Here is a list of what I ordered, not all the PN's are listed though. I used https://www.realoem.com/bmw/enUS/select to figure out the parts I needed.
Hope this helps.
bnace10144.50
Blau366.50
      12-08-2021, 02:55 PM   #110
Bari1695
Drives: 08’ 135i
Nice, this is some great info. Starting to gather parts myself for a swap in the near future.
