      12-20-2015, 05:40 PM   #67
lowside67
219
Drives: 2011 BMW 128i
Coming from the guy with TCK DAs to the guy with JRZ RS Pros...
Mark
      12-21-2015, 01:36 PM   #68
RyanDavies
Drives: 2012 128i MSport
I am cheap! AA headers instead of Supersprint too! And a custom exhaust!
Honestly I want the leather Recaro PPs, or see if I can fit some of the leather GT3 replicas inside. That'd be ideal.
      02-23-2016, 09:21 AM   #69
kobeballer96
kobeballer96's Avatar
Drives: 6SPD E82
What do you guys use to mount the factory seat belt buckle? Which kit is better VAC? I'm trying to do a fixed position no sliders for now. I have a sparco sprint 5 seat that I want to mount on the driver side but am clueless on what parts I need as far as floor mounts then what next for the seat mounts and belt buckle. Where can I go that's not going to break my wallet but still safe and repeatable.
      02-23-2016, 11:54 AM   #70
slonik
slonik's Avatar
Russia
463
Drives: e46 M3, e82v8 (s65 swapped)
we have bucket seats in our e82 with sliders, and in lowest position you couldn't see anything thru steering wheel.
i'm about 180cm height, and other drivers in our e82 about 185cm.
      10-03-2016, 01:12 PM   #71
tphaeng
tphaeng's Avatar
82
Drives: derrrty
Does anyone know which codes to code out to remove airbag lights? Ill be putting in some sparcos soon and dont want the airbag light on.
Thanks in advance
      10-03-2016, 01:29 PM   #72
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
Thanks in advance
Alex @ Alpine MSS did mine. Basically remote coding to remove airbag lights and full occupy the seat for proper airbag deployment.
      10-03-2016, 03:22 PM   #73
RyanDavies
With my car, I had to have the stock seats *in* with no code in the system to code it out, FWIW.
      10-04-2016, 08:43 AM   #74
scotty_miller
scotty_miller's Avatar
185
Drives: 2003.5 E46 M3
Here's mine. I went with a custom half cage, Corbeau seats, and race tech harnesses. Love the set up
You'll find me at the track
BMW CCA Club Racing #905
Instagram: scottynotpippen
      04-04-2018, 02:07 AM   #75
Bmdachowski
Drives: Bmw 135i
Are those FX1 pros? And what seat bracket did you use? Looking at purchasing some this weekend but after reading this form, I’m not sure if they’ll fit.
      04-04-2018, 05:12 AM   #76
scotty_miller
185
Are those FX1 pros? And what seat bracket did you use? Looking at purchasing some this weekend but after reading this form, IÂ’m not sure if theyÂ’ll fit.
These are the fx1 pros, great beginner seat! I liked them for the time that I had them. The guy that built my cage when I had my 135 also made the seat the brackets for me.... mine are fixed even though you can't really tell from picture. Check out VAC. They make a wide variety of bases and side mounts that may work.
      04-04-2018, 07:33 AM   #77
bionicbelly
78
Drives: Z3 coupe, 128i
I put FX1 pros in my car with Brey-Krause mounts with zero issues. The mounts have the ability to mount the three point seatbelt or five/six point belts. Good stuff.
http://www.bkauto.com/R_9262_for_Nar...s_p/r-9262.htm
AndyW672.00
      04-04-2018, 04:22 PM   #78
Bmdachowski
Drives: Bmw 135i
Awesome guys thanks! On order now
      07-04-2018, 06:09 PM   #79
lowside67
219
Thanks in advance
Bump - do we have any information on what the actual codes to be deactivated are?
Thanks,
Mark
      07-05-2018, 01:17 PM   #80
spxxx
Boost
spxxx's Avatar
1354
Drives: 135i M-Sport
http://www.bkauto.com/R_9262_for_Narrow_Seats_p/r-9262.htm
The BK mounts also have an option for OEM electric sliders using an E30 window switch. Only adds ~4lbs or so for some pretty sweet functionality.
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
      07-08-2018, 08:40 AM   #81
mabrahams
75
Drives: X1 M-Sport 28i
Thanks,
Mark
Mark,
The driver and passenger airbags need to be set to inactive. I highly recommend using BimmerGeeks.
      10-16-2018, 02:30 PM   #82
dbronnik
dbronnik's Avatar
223
Drives: N54 E88
Originally Posted by mabrahams View Post
Mark,
What is the consequence? Will all airbags still go off in event of an accident?
      10-18-2018, 10:57 AM   #83
amg6975
amg6975's Avatar
500
Drives: '12 M1.5, '05 ZHP, '98 M3/4/5
I think it's just so the light isn't on. There are airbags in the OEM seats that aftermarket won't have.
      10-18-2018, 12:38 PM   #84
drunkenup
Drives: 2009 135i, 2021 F150
Thanks,
Mark
Several items in the VO, both oc3 items, sidebag_links, sidebag_rechts, SPSBF_1, SBE1_1_CD, SPSF_1_CD, and active headrest if equipped, which will be both AKS lines. This is just going off of a friend's backup MRS file I coded for him. If you're doing it yourself I can look mine up later and share what I did. Also pretty sure sitzposition codes need to be inactive. There is a thread on M3post that I used to code out the lights.
If you prefer, whether for harness or shorter receptacle usage, you can also kill the buckle light and buckle tensioner, which I believe are the gurtkontact lines.
MHD | BMS | VRSF | APEX | RECARO | TC Kline | BERK | Turner Motorsport | Eibach | BMW Performance
      10-19-2018, 04:10 PM   #85
lowside67
219
Thank you for this - if you could confirm the exact codes, it would be much appreciated.
Can you also confirm if this can be done in advance of removing the seats or if I have to do this concurrent with actually removing them (I guess I could just unplug them...)
Thanks!
-Mark
      10-19-2018, 09:00 PM   #86
drunkenup
Here is my modified MR5
Code:
SEAT_BELT_DISTANCE
	wert_01
AIRBAG_BEIFAHRER_1
	aktiv
AIRBAG_FAHRER_1
	aktiv
BPLUS_TRENNUNG1_1
	aktiv
CC_GURTWARNUNG_1
	aktiv
CURTAIN_BEIFAHRER_1
	aktiv
CURTAIN_FAHRER_1
	aktiv
FAHRERBAG_STUFE2_1
	aktiv
GURTKONTAKT_BEIFAHRER_1
	aktiv
GURTKONTAKT_FAHRER_1
	aktiv
GURTSTRAFFER_BEIFAHRER_1
	aktiv
GURTSTRAFFER_FAHRER_1
	aktiv
GURTSTRAFFER_FONDLINKS_1
	nicht_aktiv
GURTSTRAFFER_FONDRECHTS_1
	nicht_aktiv
GURTSTRAMM_SEITENCRASH_1
	nicht_aktiv
ITS_GEGENUEBER_1
	aktiv
ITS_SCHRAEGCRASH_1
	aktiv
KNIEBAG_BEIFAHRER_1
	nicht_aktiv
KNIEBAG_FAHRER_1
	nicht_aktiv
LANGER_CURTAIN_1
	curtain
LENKSEITE_1
	links
OC3_1
	nicht_aktiv
POL_1
	aktiv
POS_1
	nicht_aktiv
ROLLOVER_OPTION_1
	nicht_aktiv
SBR_FAHRER_1
	aktiv
SIDEBAG_LINKS_1
	nicht_aktiv
SIDEBAG_RECHTS_1
	nicht_aktiv
SLV_BEIFAHRER_1
	nicht_aktiv
SLV_FAHRER_1
	nicht_aktiv
UPFRONT_LINKS_1
	aktiv
UPFRONT_RECHTS_1
	aktiv
US_SCHWELLEN_1
	aktiv
SBE_SCHWELLE_ON
	wert_01
SBE_STEP_DOWN
	wert_01
SBE_STEP_UP
	wert_01
SEAT_BELT_MONITOR
	wert_01
SEAT_BELT_SPEED
	wert_01
GURT_NICHT_AB_GK
	nicht_aktiv
GK/OC3/POL
	nicht_aktiv
POL_MAX_SCHWELLE
	wert_02
POL_MIN_SCHWELLE
	wert_02
AACN_1
	aktiv
O_GW_F_1
	aktiv
SPSBF_1
	nicht_aktiv
SBE1_1_CD
	nicht_aktiv
SPSF_1_CD
	nicht_aktiv
AKS_LINKS_1_CD
	nicht_aktiv
AKS_RECHTS_1_CD
	nicht_aktiv
ADAPTIVER_BEIFAHRERAIRBAG
	nicht_aktiv
AGKL_1
	aktiv
AGKR_1
	aktiv
AUFROLLSTRAMMER_LINKS_1
	aktiv
AUFROLLSTRAMMER_RECHTS_1
	aktiv
KNIEAIRBAG_BEIFAHRER_1
	nicht_aktiv
KNIEAIRBAG_FAHRER_1
	nicht_aktiv
AUFROLL_SEITENCRASH
	aktiv
EAM_TIMEDELAY_CD_C22
	e82_us
	e82_bev
FR_HE_PARAM_1_CD_C22
	e82_us
FR_HE_PARAM_2_CD_C22
	e82_us
FR_HE_PARAM_3_CD_C22
	e82_us
FR_HE_PARAM_4_CD_C22
	e82_us
FR_HE_PARAM_5_CD_C22
	e82_us
PARAMETERSATZ_0_CD_C22
	e82_us
SEITEN_PARAM_CD_C22
	e82_us
UP_FR_PARAM_CD_C22
	e82_us
MRSA_TUERE_1_C22
	aktiv
TCU_UEBERWACHUNG_4_22
	aktiv
SBR_PREWARNING_BF_MRS
	nicht_aktiv
SBR_PREWARNING_FA_MRS
	nicht_aktiv
TROMMELSPEICHER
	nicht_aktiv
SBR_BEIFAHRER_2_CD
	aktiv
O_GW_BF_1_MCD
	nicht_aktiv
SBE1_STATUS_VERZ_MCD
	nicht_aktiv
SBR_SENSOR_BEIFAHRER_MCD
	nicht_aktiv
BEIFAHRERBAG_STUFE2_2
	aktiv
BAUREIHE_MRS5CD
	e82
and my original
Code:
SEAT_BELT_DISTANCE
	wert_01
AIRBAG_BEIFAHRER_1
	aktiv
AIRBAG_FAHRER_1
	aktiv
BPLUS_TRENNUNG1_1
	aktiv
CC_GURTWARNUNG_1
	aktiv
CURTAIN_BEIFAHRER_1
	aktiv
CURTAIN_FAHRER_1
	aktiv
FAHRERBAG_STUFE2_1
	aktiv
	aktiv
	aktiv
	aktiv
	aktiv
	nicht_aktiv
	nicht_aktiv
	nicht_aktiv
ITS_GEGENUEBER_1
	aktiv
ITS_SCHRAEGCRASH_1
	aktiv
KNIEBAG_BEIFAHRER_1
	nicht_aktiv
KNIEBAG_FAHRER_1
	nicht_aktiv
LANGER_CURTAIN_1
	curtain
LENKSEITE_1
	links
OC3_1
	aktiv
POL_1
	aktiv
POS_1
	nicht_aktiv
ROLLOVER_OPTION_1
	nicht_aktiv
SBR_FAHRER_1
	aktiv
SIDEBAG_LINKS_1
	aktiv
SIDEBAG_RECHTS_1
	aktiv
SLV_BEIFAHRER_1
	nicht_aktiv
SLV_FAHRER_1
	nicht_aktiv
UPFRONT_LINKS_1
	aktiv
UPFRONT_RECHTS_1
	aktiv
US_SCHWELLEN_1
	aktiv
SBE_SCHWELLE_ON
	wert_01
SBE_STEP_DOWN
	wert_01
SBE_STEP_UP
	wert_01
SEAT_BELT_MONITOR
	wert_01
SEAT_BELT_SPEED
	wert_01
GURT_NICHT_AB_GK
	nicht_aktiv
GK/OC3/POL
	aktiv
POL_MAX_SCHWELLE
	wert_02
POL_MIN_SCHWELLE
	wert_02
AACN_1
	aktiv
O_GW_F_1
	aktiv
SPSBF_1
	aktiv
SBE1_1_CD
	nicht_aktiv
SPSF_1_CD
	aktiv
AKS_LINKS_1_CD
	nicht_aktiv
AKS_RECHTS_1_CD
	nicht_aktiv
	nicht_aktiv
AGKL_1
	aktiv
AGKR_1
	aktiv
	aktiv
	aktiv
	nicht_aktiv
KNIEAIRBAG_FAHRER_1
	nicht_aktiv
AUFROLL_SEITENCRASH
	aktiv
	e82_us
	e82_bev
	e82_us
	e82_us
	e82_us
	e82_us
	e82_us
	e82_us
SEITEN_PARAM_CD_C22
	e82_us
UP_FR_PARAM_CD_C22
	e82_us
MRSA_TUERE_1_C22
	aktiv
	aktiv
	nicht_aktiv
	nicht_aktiv
TROMMELSPEICHER
	nicht_aktiv
SBR_BEIFAHRER_2_CD
	aktiv
O_GW_BF_1_MCD
	nicht_aktiv
	nicht_aktiv
	nicht_aktiv
	aktiv
BAUREIHE_MRS5CD
	e82
Be mindful that I have a 2009 car, manual sport seats with power bolstering, there may have been changes since. I don't think it matters in which order you conduct the coding, better to let it throw codes to check in INPA, code out in the VO, check codes, rinse and repeat.
      10-23-2018, 06:36 PM   #87
Mark Aubele
43
Drives: '12 135i
We are using a Sparco Evo in my wife's 135i, Sparco sliders, VAC bases. I'm 5'10" 230 and fit in the car with a helmet on by simply removing the lower cushion. Seat is mounted so she is comfortable (she is 5'4" about 130). Seat is very close to driver's door panel but doesn't hit. I used the receptacle from one of my E36 M3s seats so she can use the 3 point for occasional street driving.
I have a question I haven't seen answered in this thread. Can the airbags be coded off? The car's primary use is hillclimb/track, and she is still using the stock steering wheel. Don't want the airbag to go off in her face with a helmet on. If not has anyone found a simple way to make them all inactive?
      10-23-2018, 06:49 PM   #88
drunkenup
The first few lines of the ABG/MR5 module appear to refer to primary and curtain airbags for driver and passenger. It may be as simple as coding them inactive.
