New 2009 2010 BMW Z4 - ZPOST
      02-16-2024, 05:43 PM   #1
Trooge
Drives: BMW Z4
E89 Windows not inching down when opening door
Hey Folks,
Both the drivers and passenger windows do not inch down when opening the door and they don't inch up when you close the door, so it's not getting a good seal.
I've tried the reset method of putting car into 1 on position, opening window fully and holding for 15 seconds then closing fully and holding for another 15 seconds, does nothing. Any tips on what it could be?
      02-17-2024, 03:14 AM   #2
B21
B21's Avatar
153
Have you put a BMW specific code reader on it ?
      02-19-2024, 07:45 PM   #3
Trooge
Drives: BMW Z4
No, would a BlueDriver one work? Have one on the way.
      02-20-2024, 03:01 AM   #4
B21
B21's Avatar
153
Not sure..usually you neee a bmw specific code reader for E89s…with 30 plus ECUs almost all are entirely or mostly bmw specific..
      02-23-2024, 06:39 PM   #5
Trooge
Drives: BMW Z4
Uhhhh got a few lol.
File Type: pdf WBALM5C59BE379900_scan_2024_02_21_12-05-22.pdf (89.9 KB, 30 views)
      02-24-2024, 02:43 AM   #6
B21
B21's Avatar
153
Well the general methodology is to read the codes, then clear them down, then straight away re-read them..you can accumulate a lot of codes over time for many reasons..that code reader really isn’t up to snuff..at the moment we can’t see the wood for the trees..
      02-28-2024, 11:58 AM   #7
RichBZ
9
Drives: 2011 Z4 3.0i
2011 Z4 3.0i  [0.00]
a few years ago I had the same issue with the windows not inching up or down. I tried all the items you tried but no go. Finally at the dealer they said my battery was weak (old) and when this happens the car systems start shutting down non essential items. They replaced the battery and that fixed the issue.
      02-28-2024, 03:05 PM   #8
B21
B21's Avatar
153
Good to know ..90% of all mystery issues on E89s end up as a duff battery…
      03-12-2024, 09:13 PM   #9
Trooge
Drives: BMW Z4
I'll get my battery tested, thank you for the suggestion!
      03-31-2024, 09:43 PM   #10
Trooge
Drives: BMW Z4
Tested battery, no issues. Took it to a mechanic and he couldn't figure it out either :|
zpost
