01-23-2024, 11:41 AM | #45 | |
47
Rep 28
I don't want to get anything super crazy aftermarket as this is my daily and I love the OEM feel of the 550i clutch. If I can't run anything higher than Stage 2, then so be it... I'm just looking at options. |
01-23-2024, 01:26 PM | #46 |
Rep 7,613
I think the main logic is that you can limit torque down low without sacrificing too much HP (which is RPM dependent). So, you may give up a lot of torque in the lower RPM (which is the worst for your clutch anyways), but you can do that without sacrificing a lot of peak/higher RPM hp numbers. I would say this is somewhat more viable for stock turbo where boost is going to naturally tend to fall a bit in the upper RPM anyways, so the amount you are actually reducing torque with the limiter is lower in the higher RPM, and you are making HP with RPM as opposed to high TQ.
matteo47.00 |
04-03-2024, 12:32 PM | #47 |
21
Rep 152
Drives: 2015 435i Gran Coupe
I am leaning towards this upgrade for my 2015 435. Sounds like it is a good upgrade.
I have the following: Upgraded intercooler Catted downpipe BM3 maps What are your thoughts on this as my next step? Also, where can I get a decent price on this? Thank you! |
04-03-2024, 12:39 PM | #48 |
Rep 7,613
Stock fuel system? HPFP/LPFP?
04-03-2024, 04:43 PM | #49 |
21
Rep 152
04-03-2024, 06:40 PM | #50 |
Rep 7,613
No point in flex fuel IMO, you're capped at about E30 if you are running the OTS stage 2 BM3 or stage 2+ MHD maps. It will only gives you flexibility between E10 (pump gas) and E30 if you are on those maps.
If you were running lower boost maps and if BM3 offers full flex up to E85 (not sure if they do like MHD) then maybe, but still seems not very useful on stock fuel system. Just depends what you are trying to get out of it when you are limited by stock fuel system? |
04-03-2024, 07:14 PM | #51 | |
Rep 5,395
You are in Texas so emission requirements are weak, and you should have both 93 and E85 available. Also you need to make decisions based on the very hot climate. My advice will vary based on your answers. Do you want to stick with just 93 or do you want to run ethanol? But the hot climate choices are pretty straightforward and labor overlaps so it makes sense to do them all at the same time. List below. FTP Charge Pipe/boost pipe kit MAD Race Intercooler Mosselman Oil Thermostat Serpentine belt & tensioner kit Kies Motorsports Seal Guard With the above, and a catted free flow downpipe you can run Bootmod3 Stage2. Mike at Extreme Powerhouse is an excellent source. He can give you advice on reasonably priced good quality downpipes that prevent the gasoline smell of Catless. Hope this helps! |
04-03-2024, 07:59 PM | #52 | |
21
Rep 152
04-03-2024, 08:02 PM | #53 | |
21
Rep 152
Upgraded cp Catted downpipe Upgraded intercooler Maps for BM3 Car is an xdrive and has 90k. S the flex fuel the next logical step to Upgrade for more power? |
04-03-2024, 08:11 PM | #54 | |
Rep 7,613
So in other words, flex fuel kit itself doesnt add power, and it isnt required to run E30. It just allows you flexibility to run an imprecise E30 mix and have the tune adjust for it. I just posted about how i mix E30 on stock fuel system here: https://f30.bimmerpost.com/forums/sh...4#post31037354 If you want to see how much of a difference going from say 91 map to E30 map can make, look at my thread here: https://f30.bimmerpost.com/forums/sh....php?t=1710794 |
johnung4531.00 SpoolinAddict23.50 |
04-03-2024, 09:57 PM | #55 | |
21
Rep 152
Wow, that is a lot of good info. Let me go through this! |
