12-04-2021, 01:34 PM | #1 |
Alexander Hartunian
60
Rep 95
Drives: 2018 BMW 440i
2018 440i F32
I ordered a VR Performance intake, VRSF catless downpipe, and Dorch Stage 2 HPFP. The pump should arrive next week, and will be installed once BM3 releases the flash DME unlock. I live in California (ACN91). Assume all my parts are installed and DME is unlocked. [COLOR="DarkOrange"]What are the primary differences[/COLOR], as far as timing changes, boost pressure, etc, between running a Stage 2 ACN91 and Stage 2+ E30 map? The reason I am asking is because you can set the Stage 2 ACN91 to read a Dorch S2 Pump, but the Stage 2+ E30 map includes the HPFP as required in the description of the tune. I have access to two E85 stations nearby so getting the fuel mix shouldn't be a problem. Thanks!
2018 F32 440i - Black Sapphire Metallic - KW Suspensions V1 | VRP Intake | VRSF Catless Downpipe | Dorch Stage 2 HPFP | MHD OTS Stage 2 E40
12-04-2021, 07:53 PM | #3 |
Rep 3,191
Apples and oranges, probably a 80whp difference.
alexander759960.00 |
12-04-2021, 07:57 PM | #4 |
68
Rep 180
The biggest changes will be the timing. You will be able to run significantly more timing than with the ACN91. Not sure how much boost pressure will increase by.
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust PJ ACN91 + Meth tune| XHP Stage 3 |
b58, bm3, e85, maps, tuning |
