01-18-2024, 10:22 PM | #45 |
Rep 715
A few winter upgrades in progress…the persuite to 2900 continues…
Took out 30ish pounds from the front end of the car… adding a lightweight battery. That’s another 60 pounds. Weight before I started is below, will know updated weight shortly Also upgrading several of the coolers. Took the front end apart to work on this. Can’t believe how heavy the factory cooling fan is; over 33 pounds. Ouch…need to figure out an alternative here and take out another 20 or so pounds at some point. Added bimmerworld / CSF charge cooler, and bimmerworld / PWR oil cooler…bimmerworld / PWR aux coolers on order. Will replace these soon as well. While at it, removed the AC compressor and pulleys…trolaced the belt with a shorter one. Do also have the fuel starvation kit, this will be installed shortly as well. Finally while at it…replacing the upper radiator brace to a slon carbon piece. A few more pounds saved here… Here a few pics…of the work in progress. More soon.
2015 M3 - GT4 replica Ongoing build thread https://f80.bimmerpost.com/forums/sh....php?t=1802471 For Pics / Video's visit Instagram https://www.instagram.com/ninekrpm1/ |
GreenGoblin51.50 DRLane3996.00 funk323177.00 GuyLedouche590.50 D_SheerDrivingPleasure1104.50 sly1types431.50 drroc423.00 |
01-19-2024, 11:59 AM | #47 |
Rep 469
I also just did an AC delete. To save more weight I went with the engine delete.
01-19-2024, 12:20 PM | #48 |
Rep 5,914
GuyLedouche590.50 |
01-19-2024, 01:02 PM | #49 | |
Rep 715
01-19-2024, 03:27 PM | #50 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
How did you remove 30 pounds from the front of the car?
01-19-2024, 03:50 PM | #51 |
Rep 715
yes...a few more then 30 22# from AC compressor 2-3 # by removing the extra pulleys 3ish # by cutting the metal bracket around the air ducts 5 # by replacing the top radiator brace to carbon Some ounces, lighter oil cooler Definitely adding 2-3 due to the larger radiator capacity... However, the heaviest thing left in the front is the factory fan...28#'s. A spal fan or similar is less then 10 #'s.
funk323177.00 chetrickerman10446.50 |
01-19-2024, 06:28 PM | #52 | ||
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
01-22-2024, 09:00 AM | #55 |
Rep 715
Weekend update…almost back together.
Waiting for the slon carbon top radiator bracket arriving this week…and the MCS’s from service. Couple of weeks before heading out for a test and tune day at Willow Springs… On a separate note…did manage to take out a few additional #’s.
01-22-2024, 09:34 AM | #56 | |
Rep 3,413
Not a Doctor, those are just my initials.
ninekrpm540.50 |
01-22-2024, 10:04 AM | #57 | |
Rep 940
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
01-22-2024, 09:30 PM | #58 |
Rep 715
oem is 30#'s...new one is 15 (antigravity 40ah)
was originally looking at Braille as an option, sub 10#...just confirmed, they are not shipping to the US market (yet...)
sly1types431.50 |
01-22-2024, 09:31 PM | #59 | |
Rep 715
good stuff...thanks
01-23-2024, 08:34 PM | #60 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
Which Braille battery? Im running the Braille G30 in my F80.
01-23-2024, 08:39 PM | #61 | |
Rep 715
not braille, sorry meant to write https://en.liteblox.de/ do tell more about the G30?
01-23-2024, 08:55 PM | #62 | ||
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
http://f80.bimmerpost.com/forums/sho...1&postcount=26
01-24-2024, 10:49 PM | #63 | |
Rep 522
01-25-2024, 06:06 AM | #64 |
Rep 715
01-25-2024, 07:55 AM | #65 | |
Rep 469
01-25-2024, 02:49 PM | #66 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
I fabricated a battery strap.
GuyLedouche590.50 |
