02-13-2024, 03:02 PM | #89 |
Rep 715
As shared, did a few upgrades…and made a few changes to get some weight out of the car.
Well, here are the results, roughly 50#’s out, slightly less then what I was hoping for… The weight officially is at 3K #’s (no driver, 3/4 tank of gas).
2015 M3 - GT4 replica Ongoing build thread https://f80.bimmerpost.com/forums/sh....php?t=1802471 For Pics / Video's visit Instagram https://www.instagram.com/ninekrpm1/ |
02-16-2024, 07:37 PM | #91 |
Rep 715
Share pics of the install.
02-17-2024, 03:08 PM | #92 |
Rep 469
Pretty easy install. There’s a hole for the hold down cleat for this size battery. Just need to drill through and put a nut on the backside. Other than that no change to the mounting.
chetrickerman10446.50 |
02-17-2024, 04:33 PM | #93 |
Rep 469
To update. I started to register the battery with bimmer code and my scanner and the car died during the process. I had the car hooked up with my CTEK lithium charger as I always do when coding. Battery seems to be completely dead at this point.
I hooked up a good battery and the car is fine so this is related to the battery. |
02-17-2024, 05:44 PM | #94 | |
Rep 715
Interesting… I finally started mine today, it did start right away, but I do see a battery discharge warning on the dash. Have it hooked up to a charger today as well. Let’s see… Going to try to code tomorrow.
02-18-2024, 08:07 AM | #95 |
Rep 469
Battery showed 10.6 V so the car disconnected and wouldn't take a charge. I hooked a charger up to the battery posts and got above 12 V and hooked back up to the car and am charging. Will see what happens.
02-22-2024, 03:12 PM | #96 | |
Rep 715
Any updates on the battery setup?
02-22-2024, 03:57 PM | #97 |
Rep 715
I did end up coding the battery, used 40ah as the setting.
however am seeing this even when the batter is fully charged, ignition ON and when the car is running, I see the following That said...car starts up just fine...so not sure what to do with the error. Finally, I did notice that when the battery is fully charged via the charger, I can turn the ignition ON and move the charger to tune mode; this allows me to keep the car's ignition on. However, if I start the car, let it run for a bit; turn off and try to keep the ignition ON; I get the error above and the ignition turns off I am going to the track tomorrow; going to take the stock battery with as a backup...
02-23-2024, 12:18 PM | #99 | |
Rep 715
Let the car run idle for two plus hours yesterday, the errors seem to have gone away…started with no issues/errors this morning. At the track today…all seems well with battery, no errors.
sly1types431.50 |
03-14-2024, 06:54 AM | #101 | |
Rep 9
03-14-2024, 07:41 AM | #102 | |
Rep 715
It is pretty quick and simple…
03-16-2024, 09:07 AM | #103 |
Rep 715
This weekends project…
Upgrading the DP’s with a resonated setup from “inked customs” out of Germany I will run this with the existing BW GT4 replica exhaust for now… However, going to transition in a few weeks or so to an “inked custom” setup with a single midline (more on this soon).
funk323177.00 D_SheerDrivingPleasure1103.00 |
03-16-2024, 01:34 PM | #104 |
Rep 715
Few install pics…
03-16-2024, 11:49 PM | #106 | |
Rep 715
It’s going to be wild.
03-17-2024, 01:04 PM | #107 | |
Rep 715
Video posted if interested… https://www.instagram.com/reel/C4n-X...RlODBiNWFlZA== It’s going to be wild…loud!
03-19-2024, 12:34 PM | #109 |
Rep 715
Happy for ya! He was great to work with. So much knowledge and patience to do a meticulous job.
johnjames8526.50 |
03-19-2024, 12:46 PM | #110 |
Rep 3,413
+1 on Martyn. He did my wiring!
Not a Doctor, those are just my initials.
johnjames8526.50 ninekrpm540.50 |
