BMW X3 Forum
BMW X3 Forum
      01-16-2022, 05:30 AM   #1
peds2002
Drives: BMW 4 Series F36
Boot twisted/not alligned
Hi All,
My boot recently has stopped closing properly and stops halfway down. I then noticed that the boot is not alligned correctly. I have undone the hinges and tried to adjust it but there is much give on them. Any suggestions please. I have attached photos.
      01-16-2022, 11:02 AM   #2
Opie55
1207
Drives: '15 650i Convertible
Any chance someone drove it with something large in the back and left the boot open without tying it down? Hitting bumps with the boot open and letting it bounce up an down could deform the mounting points. Otherwise, for something like that to happen suddenly with no accident would be very odd.
      01-16-2022, 11:11 AM   #3
peds2002
Not that I'm aware of. I am beginning to think it wasn't correctly aligned when built. The only reason I noticed it was the boot doesn't go right the way down when you close and thinking one of the gas struts might be faulty. Maybe i should replaced the hinges before I replace the struts
      01-16-2022, 01:43 PM   #4
pungo
pungo's Avatar
Drives: Z4MC-X3-35i-525i, Corrado G60
Disconnect struts and see if it closes properly without them.
Wgosma810.50
WagonR293.00
      08-07-2022, 07:39 AM   #5
Bamboozled
Drives: BMW X3 F25
Hi Peds2002, did you find a fix for this? I've got the same problem, boot is tight on the right side.
      08-07-2022, 07:48 AM   #6
peds2002
Unfortunately I did. I have you but a replacement strut in the end, but it made a huge difference and sorted the issue straight away.
      08-09-2022, 08:46 AM   #7
MSport_Jon
Drives: X3 F25 LCI /// F80 M3 (SOLD)
Here you go...
Attached is the BMW procedure to adjust your tailgate. Good Luck!
TX55257.50
      04-23-2024, 03:49 AM   #8
bakram
Drives: X3 F25
I am having same problem and I have tried to slacken and adjust by loosing 'Screw 1' as per the Adjusting tailgate pdf, but this only makes adjustments up and down. I can't figure out how to make the adjustments left and right. I didn't attempt to unscrew 'Screw 2'. Am I wasting my time as earlier post says replace the closing strut? Both seem to be working.
      04-23-2024, 06:00 AM   #9
peds2002
I thought that as well, the Sturts did look to be working fine but when I replaced them, everything was ok straight away.
xbimmers
