TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > N54 missfire at cold start
      03-02-2020, 07:13 AM   #1
zack9r
24
Drives: bmw 335i
When i start my 335, it seems to missfire (mostly cyl 6) temp can usually range from 30f to 57f. Once warm, seems to run fine.
Replaced injectors, spark plugs/ coils
N54 e90 335i
      03-02-2020, 07:21 AM   #2
relative4
Drives: '08 335xi E90 MT stage 1+
What are your bank 2 fuel trims at idle?
      03-02-2020, 07:50 AM   #3
Moisture
27
Drives: 2015 Mazda 6, 2020 Lexus NX300
It's probably your fuel injectors. You can pull them out and get them tested for a poor spray pattern.
      03-02-2020, 07:58 AM   #4
zack9r
24
Drives: bmw 335i
.... literally brand new
N54 e90 335i
      03-02-2020, 07:59 AM   #5
zack9r
24
Drives: bmw 335i
No clue. I have yet to calibrate them. Probably what ill do later tonight
N54 e90 335i
      03-02-2020, 08:05 AM   #6
Moisture
27
My mistake. I skimmed through your post quick and didn't realize you mentioned your injectors as well.
With those three things out of the way it starts to become more difficult to pinpoint what the issue could be, as there are a multitude of different potential causes. Have you gotten the car scanned with a BMW scanner yet?
First step is to check the fuel trims like the guy said. Does your car seem hard to start when cold, like a long crank? how's your fuel pressure looking?
      03-02-2020, 09:16 AM   #7
zack9r
24
Drives: bmw 335i
I have a scanner and the k+dcan cable. Ill look at my trims, and adjust as necessary
N54 e90 335i
