GetBMWParts
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Cosmetic and Lighting Modifications
      02-16-2021, 07:12 PM   #1
///M4 F83
///M4 F83's Avatar
85
Drives: 2015 BMW M4 convertible
Question F82 tail lights retrofitted into a F83?
I was always under the impression that F82 tail lights won't work for a F83 but I've seen a member here (see photo below) retrofit OEM GTS tail lights into his F83. What kind of work needs to be done? Any DIY available? I tried searching and didn't come up with anything.
I really want the GTS tail lights but I don't want to purchase them at the price tag for an OEM set. Now GTS-style tail lights for the F80 are available with talks about them releasing for the F82 soon. I'm sure the F83 version will take longer (if ever). So I plan to retrofit the F82 GTS-style tail lights into my F83 when they release.
All input is appreciated. Thanks.
2015 BMW M4 F83 | Alpine White | Sakhir Orange interior | 6 speed manual
2008 BMW M3 E92 | Alpine White | Bamboo Beige interior | 6 speed manual
      02-16-2021, 09:38 PM   #2
TrueLoyaltyInc
TrueLoyaltyInc's Avatar
97
Drives: BMW 328i Coupe
His are actual OEM OLED taillights
Check out this link (he has to this day parted out the car and sold the taillights)
Trust I'm on the same hunt you're on!
      02-16-2021, 10:26 PM   #3
///M4 F83
///M4 F83's Avatar
85
yea I saw his for sale thread and he advertised his tail lights for F82 AND F83. how is that possible?
      02-17-2021, 04:34 PM   #4
NickyC
NickyC's Avatar
17485
Drives: M4 CS. Former G82, x2 F82, F80
OLEDs are so nice, remind me of a Decepticon eye or something hah.
      02-17-2021, 04:53 PM   #5
phantome46
phantome46's Avatar
113
Drives: 2015 M4 Convertible - Sakhir
Subscribed
      02-17-2021, 09:56 PM   #6
Street_insainity
Street_insainity's Avatar
59
Drives: BMW M4 Comp, X5M Comp
2017 bmw m4  [0.00]
really? I haven't heard of the headlights being non compatible across f82 and f83, I believe they're exactly the same, including the harness and all. only issues I believe f83 might have is if we have pre lci tail lights.
      02-17-2021, 11:15 PM   #7
///M4 F83
///M4 F83's Avatar
85
yea if you do a quick search, you'll see they have separate part numbers and are not interchangeable.
      02-18-2021, 08:21 AM   #8
amancuso
amancuso's Avatar
726
Drives: 330it, 428ix, 430i
The only difference is the alignment peg on the inside of the tail lights. Or at least it is between F32 and F82. Just snip the peg off and the fitment is perfect.
2016 428ix, r, 2018 430iC, 2018 330it
      02-18-2021, 11:53 PM   #9
///M4 F83
///M4 F83's Avatar
85
I wonder if it's the same case retrofitting them into a F83.
hoping someone that has done it before chimes in
      10-05-2023, 12:00 AM   #10
spacewj
Drives: BMW 2016 F82 ZCP
2016 F82 M4 ZCP  [0.00]
Could you show me what needs to be removed?
      02-17-2024, 05:16 PM   #11
WhiteFox
WhiteFox's Avatar
108
Drives: BMW M4 F83
I’ve done this on my F83 with OEM OLEDS
1) These lights will fit the F83 but the inner light pegs will need to be cut off as they don’t align but not needed.
2) Wiring harness was never made for this car hence you will need to run two additional wires and tap into two. I can’t recall as been sometime. This is the most complex bit.
3) You will need to code these into the car as GTS lights.
4) The lights are different shape hence the drip rails do not fit these like they do the F82 lights hence you will need to modify these drip rails to make them fit.
No idea why BMW changed the shape design for these but believe it was because they didn’t want them to go on the F83.
f80post
