07-30-2023, 04:04 PM | #1 |
Rep 896
Drives: OG M2
Dorch Stage 2 2023 Update???
Does anyone know if this pump’s design was updated recently? The one I got in the mail from them looks completely different and is missing the bracket that used to come with them. My pump is completely different from everything on YouTube and on Dorch’s own install PDF. Anyone have updated instructions or know if this is the correct pump for the n55? I really don’t wanna just throw this in the car without proper directions
OG M2 with the OEM M mirror retrofit
07-30-2023, 06:09 PM | #2 | |
@lbb_kev
496
Rep 516
Edit: Nvm saw your follow-up on the other thread. Glad you sorted it out. https://www.bimmerpost.com/forums/sh...php?p=30355260
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage |
08-01-2023, 12:49 AM | #3 |
Rep 896
Drives: OG M2
Update for everyone!
The pump was indeed redesigned; the installation is mostly the same except for a few points: - there is no more extra bracket in this kit (there used to be a bracket supplied that would attach to an OEM bracket to hold a wire and the low pressure outlet line) - you now need to install the HPFP to fuel rail line BEFORE dropping in the pump - use blue threadlocker on all 4 of the bolts for the HPFP and the Dorch flange - the HPFP inlet hose/LPFP outlet hose is now routed under the cable junction box and plugs in straight on the other side of the fuel pump (as opposed to routing it around the flange); make sure this black fitting is finger tight and then use an adjustable wrench to turn it 1.5 flats Pics attached for reference! Lmk if y'all have any questions as I got it all figured out now!
08-01-2023, 11:33 AM | #4 |
1306
Rep 3,554
Yeah its from a different GM pump supplier.. its a redesign..
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
