08-13-2023, 05:58 AM | #1 |
36
Rep 97
M-Performance power kit
My F30 2013 335i N55 comes with M-Performance power kit.
Does it mean that I have 20hp more with tuning in DME and have forged internals.🤔 |
08-13-2023, 11:25 AM | #4 |
1306
Rep 3,554
Yeah, it makes a few extra hp over stock.
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
08-13-2023, 12:43 PM | #6 |
36
Rep 97
08-13-2023, 12:53 PM | #7 |
901
Rep 223
Drives: 2012 335i Sport
Still a nice kit! While it doesn’t make much sense to buy if you’re looking for a tune these days, getting a car with it is still a nice find, I think you should have the performance intake and exhaust, check under your bumper and see if there’s an ///M on the muffler- a pretty desirable part for most that want an upgrade but not a crazy loud aftermarket system. The tune is fine, you can always get an aftermarket one that pushes the engine more but nothing wrong with the m performance one and I’d be pretty happy if my car had been outfitted with one
PWG and EWG are different kinds of wastegates on the n55 engine, EWG was an updated version that was electronically controlled, but more importantly there was a revised turbo that was a bit bigger as well. Stock for stock not a huge difference, EWG will get a little more gains in aftermarket tunes and has a slightly higher ceiling that can be pushed on the stock turbo. PWG still has plenty to give though- for most people difference won’t matter or be that apparent. Someone who is more familiar with EWG can chime in but unless you’re planning a rather large build you probably wont notice much of a difference. |
Shah_F3035.50 |
08-13-2023, 12:57 PM | #8 | |
36
Rep 97
And yes I have Mperformance muffler and Mperformance exhaust tips plus the Mperformance sign coming up on instrument cluster when switch on/off.. |
thatgarrett901.00 |
08-13-2023, 04:02 PM | #9 | |
Rep 5,410
It primarily replaces the bottom of the airfilter box with one that has an extra air hole trimmed in red plastic for effect. It mostly lets out more of the turbo sound from the engine. It has a bunch of decals and a new fancy plastic engine cover. If you want a small performance bump, then replace the stock airfilter with a free flow washable/reusable aFe Pro Dry airfilter. See photo for part number. Anyone with a stock intake can obtain the same effect without the decals by either buying and replacing the bottom of the stock airfilter box or cutting holes in the stock unit. Please see photos. There are a couple different MPPK kits depending on the build date of the car. Some come with an MPPK tune installed by the dealer. It’s a really small performance bump, not worth the price at all. Much better to install a real tune like a Bootmod3 Stage1. (Never install a tune on an F30 N55 without first upgrading the charge pipe because the stock CP is a poor design that will break) Note: Answer to a common question… If a tune such as Bootmod3 is installed to an engine that has a BMW MPPK tune, it does NOT add to it. Bootmod3 saves the MPPK tune as the original tune that can be reinstalled at any time. Then it erases the MPPK tune from the car and installs a fresh copy of Bootmod3. Here is a link to the MPPK kit for your car. https://www.getbmwparts.com/oem-part...w2LWdhcw%3D%3D |
08-14-2023, 09:03 AM | #10 | |
Rep 4,218
https://f30.bimmerpost.com/forums/sh...ghlight=397whp
Mods: Yes.
thatgarrett901.00 |
08-14-2023, 11:00 AM | #11 | |
Rep 5,410
It was nice feeling that with the MPPK tune there was a little more power than the exact same 335ix’s that I had driven that had only the stock tune. When I installed Bootmod3 Stage1 (rated at 70hp more), now that was a real kick in the pants. If the MPPK tune really was +50hp, then the +20hp more from Bootmod3 would have felt relatively minor. I would only believe a dyno if actually did the same car back to back first with the stock tune and then with the MPPK tune. This was one of the things that I had wanted to test. When I thought that I had local access to a AWD Dynojet, I put a test plan together. Halim sent me a stock tune so I could use it as a baseline on the dyno. Then I’d work my way up through MPPK, BM3 Stage1 93 all the way through full E85 tune. I was going to test a few components too like maybe stock intake, MPPK Intake (with aFe filter) and MST Intake. However local AWD Dynojet access was not to be, or I would have great accurate incremental data on tuning steps with the stock N55 EWG turbo. I have leads on two AWD Dynojets that are more of a drive. They are used for internal product development use, but I’m hoping that one will allow me to test. |
08-14-2023, 11:34 AM | #12 | |
Rep 4,218
https://www.dynojet.com/dyno-tunings...e-dyno-center/
Mods: Yes.
08-14-2023, 01:53 PM | #14 | |
Rep 5,410
08-14-2023, 02:44 PM | #15 | |
Rep 4,218
Mods: Yes.
n55david1306.00 |
08-14-2023, 02:58 PM | #16 |
1306
Rep 3,554
Yep.. 600 to 700rpm of usable power band and way more power.
08-14-2023, 03:07 PM | #17 | |
204
Rep 383
(Although the EWG does allow for more precise tuning of the wastegate, and generally has more support which also contributes to a difference on car’s with the same turbo, like the Pure 500. Just not as significant) |
