08-13-2023, 10:07 AM | #1 |
Rep 1,125
Drives: 2015 BMW 435i Xdrive MSport
M Sport Auxiliary Cooler Retrofit?
Hell everyone,
Has anyone done this retrofit? Is it possible? Doing a ZHP inspired build.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
08-13-2023, 12:31 PM | #3 |
Rep 1,125
Nope. Cold climate car. I also converted my sportline to m sport but never did the cooler. Also need to delete my fogs.
08-13-2023, 10:07 PM | #4 |
Rep 499
I was wondering this too, didn't end up getting any information. You'd probably need to retrofit the auxiliary water pump too.
https://f30.bimmerpost.com/forums/sh....php?t=1996843 |
08-14-2023, 06:43 AM | #5 | |
Rep 1,125
08-14-2023, 07:36 AM | #6 |
Rep 3,958
Yes, there is. It's right behind the passenger headlight assembly.
The retrofit isn't as straight forward or plug and play. You do have to re-do a bit of the coolant plumbing for it to work. I also can't remember this - but is M Sport the only configuration that has the air to liquid oil cooler as well? |
08-14-2023, 07:38 AM | #7 |
Rep 499
https://www.realoem.com/bmw/enUS/sho...diagId=17_0675
Not to be too pedantic, but it might be plug and play assuming you have everything including hoses, radiators, water pump, etc. I don't know if there would be a coding associated with it or not, or if it just splits the signal from the primary water pump. |
08-14-2023, 07:40 AM | #8 | |
Rep 1,125
08-14-2023, 07:50 AM | #10 |
Rep 1,125
Yeah just not the auxiliary cooler. Seems to be a luck of the draw.
08-14-2023, 08:04 AM | #11 | ||
Rep 3,958
My F25 X3 35i does not have the aux oil cooler. |
08-14-2023, 08:16 AM | #12 |
Rep 499
Not sure we are all on the same page right now. In the PASSENGER side wheel well, behind the fog light, there is an oil cooler. It is my belief it is there for all N55 vehicles on this chassis since my 335i luxury line has this.
In the DRIVER Side wheel well behind the fog light, there is an auxiliary radiator on M SPORT vehicles only. There is an auxiliary water pump which is mounted inside the engine bay somewhere that helps pump coolant through this radiator, as well as additional coolant hoses to integrate it into the cooling circuit. |
08-14-2023, 08:23 AM | #13 | |
Rep 1,125
Polo088161616.00 |
08-14-2023, 08:36 AM | #14 | |
Rep 499
In any case, its entirely tangential to the discussion because we are talking about retrofitting the auxiliary radiator. I think you could do it but you need to get everything. The only question that remains is how that water pump runs- I don't think there is any auxiliary thermostat so it must just run on conjunction with the main water pump. I don't know what wiring harness you need but this is definitely possible to do. It would be easiest to find a donor vehicle so you can swap the entire thing over, but that may not be feasible. The real elephant in the room here is cost- It would probably be prohibitively pricey to buy everything new, since simply buying a bigger radiator is probably a more cost effective solution. So you could do this if you want to make an exact M Sport replica, but I sincerely doubt its "worth" it. |
08-14-2023, 08:39 AM | #15 | |
Rep 1,125
08-14-2023, 10:30 AM | #16 | |
Rep 499
Whats the last 7 of your VIN btw? realOEM shows most of the things you would need on one of their pages. For example on my car - https://www.realoem.com/bmw/enUS/sho...diagId=17_0676 also shows an additional heat exchanger for M sport as well as additional parts for the auxiliary radiator - https://www.realoem.com/bmw/enUS/sho...diagId=17_0675 Last edited by rlesko; 08-14-2023 at 10:37 AM.. |
08-14-2023, 10:50 AM | #17 | |
Rep 1,125
08-14-2023, 12:17 PM | #18 | |
Rep 499
As I think about this more I wonder if there is a different wiring harness for M Sport models, I can't think of how else the auxiliary pump would be powered. It would be much easier to inspect a real car than keep rummaging through realOEM. |
08-14-2023, 01:09 PM | #19 |
Rep 1,125
Yeah I have a 435i. I have yet to see one up here in PA with the auxiliary radiator.
08-14-2023, 02:06 PM | #20 |
Rep 895
It looks like there’s 3 configurations - Base, MSport and Track pkg. (with an Auto vs. 6MT variation on the Track pkg). See borrowed pic from a recent thread...
Phil, you must have Base. My ‘16 435iX GC has the Track pkg version. Looks like LOTS of hose changes are involved… |
08-14-2023, 02:30 PM | #21 | |
Rep 1,125
08-14-2023, 02:35 PM | #22 | |
Rep 7,634
