BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Seafoam or Walnut Blasting?
ARMA SPEED
      03-17-2017, 07:45 PM   #1
GTBrandon
GTBrandon's Avatar
Drives: 13' M3 Competition
Just wondering if anybody has performed either of these on our engines. I know walnut was a big thing on the n54's and have heard from some it is not as necessary for the n55's. Also I have not seen many subjects on seafoam for these engines so I thought I would throw it in here as well. Any thoughts/experience appreciated!
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL |
85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger
      03-17-2017, 09:49 PM   #2
AGONXF30
AGONXF30's Avatar
Drives: 2012 335i S-Line/Melbourne Red
Are you burning any oil? If you are not, then there is barely any oil going into the intake manifold runners, head intake runners and valves. My N55 may burn a Liter/QT of oil in 10K (I do oil changes between 5 and 10K) depending on drive style, but I rarely have to put oil in it.
      03-17-2017, 11:09 PM   #3
obert
obert's Avatar
Drives: 2013 328i
Walnut blasting will be way better than sea foam.
      03-17-2017, 11:40 PM   #4
mr_kay
mr_kay's Avatar
126
Drives: F30 335i
I looked at mine when I was doing my oil filter housing gasket Bc I had to pull the manifold out a little. They looked pretty clean with ~65k on it. I burn about a quart of oil every 8-10k. You can probably split the manifold enough to take a peek in there in around 15 minutes. Each case seems to be different, I've seen some e90 n55 pictures that were terrible.
      03-18-2017, 09:05 AM   #5
STR8-6IX
536
Drives: RWD 528i N52
seafoam doesnt do much, if anything at all. do a walnut blast. what mileage are you at?
      03-18-2017, 09:23 AM   #6
enjoythemusic
enjoythemusic's Avatar
364
Drives: 2014 BMW 435i Dinan Stage 4
Agree with others, walnut. Occasional use of Techron cleaner (every 3k miles) is also beneficial imho.
Enjoy the Drive,
Steven
2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S.
      03-18-2017, 09:32 AM   #7
hardparker
Father of Frankenfold
299
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
WMI = clean manifold forever!
      03-18-2017, 02:34 PM   #8
Tchao
Boost Addict
Tchao's Avatar
334
Drives: E30, E82, F30, F87
You do know we have direct injection...injector/valve cleaners wont work.
      03-18-2017, 03:53 PM   #9
enjoythemusic
364
You're right, sorry, i deal with many cars and just got the BMW so forgot.
Enjoy the Drive,
Steven
      03-19-2017, 01:29 AM   #10
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Run some E85 to clean your carbon build up
I haven't seen any Fxx series N55 needing to do walnut blast
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      03-20-2017, 05:54 PM   #11
izaazk
Drives: 2013 335i
They have a spray version of intake cleaner / seafoam that can be sprayed into throttle body....
Anyone ever use one ... ? Im thinking about running a can or so of sea foam or some sort of valve cleaner... my n55 f30 seems like it can use it after i drive all highway and harsh
      03-21-2017, 08:58 AM   #12
Orion4
Drives: 2013 335i Sport Line Sedan
Actually, Seaform or Techron (BMW Injector Cleaner), which I prefer, does work, but only for the combustion side of the system, ie- injectors, combustion chamber. Due to the configuration of DI systems, the backside does not get "washed" by the fuel as in earlier systems and that is what walnut blasting addresses.
My 09 335i (N54) had 55K on it when the blasting was performed. When they pulled the manifold off to blast it and showed me the buildup, i was amazed. I was burning any measurable oil, but the carbon buildup was impressive!
The N55 is supposedly less susceptible to the DI carbon issue and unless you are seeing a decrease in MPG &/or drop-off in measurable performance, a blasting is probably not necessary. As mentioned above, just run Techron Fuel Injector cleaner through your tank every 3-5k miles.
      03-23-2017, 08:36 AM   #13
Big_CG
Big_CG's Avatar
185
Drives: 2020 X5
Has anyone with N55 and any amount of mileage actually documented that there is carbon buildup on the intake valves? With the N54 there are tons of stories, but I haven't seen anyone say the walnut blasting is necessary on N55 even with 100k+ miles.
      03-25-2017, 03:19 AM   #14
Krelle
Denmark
90
Drives: M2C
No chemicals can clean this carbon build up which becomes kind of ceramic like hard.
Walnut cleaning or baking Soda, (Natriumbicarbonate / Natriumhydrogencarbonate) is The Thing to use for soot/soda blowing.
Which ever you choose I recommend changing the oil shortly after. Both product may enter the oil but does no harm, guess I'm just carefull
/Krelle
Ist der Motor kalt, Gib ihn sechs ein halb.....
GTBrandon260.00
blasting, carbon, engine cleaning, seafoam, walnut
