07-29-2020, 02:47 PM | #45 |
Rep 28
07-29-2020, 02:52 PM | #46 |
Rep 28
On my car the button IS ignored when AC is on and over 20C outside, sometimes even when over 12C.From above fragment is not not clear to me which video matches your car behaviour https://vimeo.com/440448893 or https://vimeo.com/442124971 ? Please clarify.
07-29-2020, 05:09 PM | #47 |
Rep 5,984
First video is what my car does from standstill.
Drive for a bit, get heat in the coils and then the recirc flaps will open up and let fresh air in. The second video you have forced recirc on while not in auto, while stood still it will remain on until you start driving, you have to turn off the climate to force the recirc off again if you're not driving. Try that again with the system set to auto. Try it again and drive off. Last edited by gIzzE; 07-29-2020 at 05:18 PM.. |
07-29-2020, 05:11 PM | #48 | |
Rep 5,984
Sorry, what is the problem in the cabin? Too hot? Too cold? Smells? My guess is you have no problem other than you want to understand how the system works and it is annoying you. If you stopped fucking around with it and let it do its job I bet it would do everything it is meant to do, which is keep the cabin at desired temperature and dehumidify it. |
07-29-2020, 05:36 PM | #49 | |
Rep 15,858
To the OP... The other factor to note, when stationary the sniffer sensor can be picking up fumes and HVAC function is not a constant. What is controlling the cycle when you try a button pushing sequence? Humidity will change the parameters. As will ambient temperature inside/outside the cabin. Hard to compare cars, or even the same car, in different settings and conditions. There is a lot going on, which means what happens one time you try a control sequence, is not the same the next time you try it. How do I know... been there, trying to identify why my AUC (auto recirculation) function was not always acting fast enough and fumes were coming into the cabin. Don't expect an exact sequence when testing. I can get both your experiences, flicking through the buttons in my 5-series. It all depends... it's a complex system and is best left running fully Auto. |
07-29-2020, 06:47 PM | #50 | ||
Rep 28
Interesting, the first video is my car, in any mode auto or manual, A LED or no LED as soon as AC is on I see fresh air flap closes immediately if hot outside.
My questions still remain. 1. No observed behaviour matches BMW factory driver's manual. Yes, I heard that IHKA-High system firmware may be updated over time but I am referring to an online manual not the printed one. 2. Why AC immediately closes fresh air flap on one set of tested BMWs and does not touch fresh air flap on another set in absolutely identical weather conditions, baked under the bright summer sun next to each other on a parking lot. |
07-29-2020, 07:00 PM | #51 | ||
Rep 28
07-30-2020, 04:06 AM | #52 | ||
Rep 15,858
Recirculated air should not be a constant function in AUC position. The following (not specific for the F30) illustrates the typical strategy. Quote:
It does appear you have some kind of fault, if you don't get any fresh air with AC running. Comparison to other cars, particularly when stationary, could be a red herring, due to lots of variables which may mask the real issue. Best course is live data while driving. If BMW take it seriously, there is the chance they will put a data logger in the car and interrogate after test runs, or you using the car for a few days. I've personally had a data logger in an E91, to see why my HVAC system did strange things while driving. (Long story short, there was a humidity issue). Also my dealer has run a laptop in my current F11, to identify if the AUC sensor was functioning correctly. Was the simplest way to prove its function. |
07-30-2020, 08:35 AM | #53 | |
Rep 28
But again, a major concern is gigantic difference between BMW F3x manual and current conditions fresh air control button behaviour. |
07-30-2020, 08:59 AM | #54 | |
Rep 15,858
The manual won't be explaining every particular button pushing reaction, as you initially change, flip through the setup. The feature/function description is clear for specific running settings. But repeatedly playing with buttons can 'upset' the system. Often requires time to stabilise, or prioritise and/or eliminate conflicts first, like dealing with humidity. In my current car, cycling through AUC/outside air, doesn't always follow what I'd expect. Sometimes it immediately changes flap positions, air flows and fan speeds, other times it appears to do nothing. System is working correctly in use. |
07-30-2020, 09:22 AM | #55 | |
poopycat
266
Rep 791
Go find another one that has the required tools. PS, you should report the BMW Dealer that can not do diagnostics. |
12-12-2020, 05:43 PM | #57 |
Rep 1,398
The OP seems to firmly believe that the air outside his/her vehicle is drier than inside when there are people on board. The location "Salem" is ambiguous, but the two most notable are in Massachusetts and Oregon neither of which is know for their dry climate, soooo I dunno about the dry air being outside.
As for the A/C setting taking over regardless of the recirc setting, I believe that is largely true with mine as far as I can tell. I'm not too fussed, because when it is 104°F/40°C or more with suspended dust and traffic products, the last thing I need is outside air. I do agree with the OP that you can hear when a car is in recirc compared to pulling outside air when you have the fan up high. ICan hear it on my F30, ML350 and it was REALLY obvious on the Xterra I used to own. I must assume that those who claim they cannot hear it are at least tone deaf. |
12-13-2020, 03:32 PM | #58 |
127
Rep 339
Question, perhaps this was answered elsewhere, but why would you even want to operate the AC system with fresh air on? This is akin to operating the AC system with the window open? Correct me if I'm wrong about that. Wouldn't doing that, just freeze up your condenser? Again correct me if I'm wrong about that one too. WTH?
10-27-2022, 07:36 PM | #60 | |
Rep 4
10-30-2022, 09:54 PM | #61 |
Rep 7,622
Hah i just read through this entire thread. I find it amusing because my car actually does the same thing as OP and I was never able to figure out why, assumed it was just a BMW thing. I do think its annoying when turning the AC on forces the car into recirculate mode if there is enough of a difference between the setpoint temperature and outside ambient temp (i.e., its hot outside and you are setting it to a low temperature inside). It doesn't make sense IMO when there is a separate button for recirculate settings and that effectively does nothing in this situation.
04-02-2023, 03:05 PM | #62 |
20
Rep 53
This is the first I have seen this entire string but find it very interesting. I have a 2020 M340i and last year, I began having some issues with either mold or moisture building in the evaporator - just getting some musty air...but still cooling well. All that seemed to resolved itself over time. HOWEVER, along the way, I observed the exact problem you have outlined in the initial post of this thread. The system does ignore the fresh/recirc/auto button ANYTIME the A/C is on, in which case it is always in recirculate mode. Aside from the sound of the air never changing, when switching modes (with A/C on), you can actually see the primary flap underneath cover the secondary battery located in the engine compartment, in front of the passenger. In fact you actually see the incoming side of the cabin filter. The ONLY way to get that flap to open is to turn off the A/C and then set the mode to "fresh air". You definitely hear and feel the air speed slow down in the cabin. If you then switch it to "recirculate", the A/C comes on automatically (which is crazy) and the air speed speeds up. THEN, if you turn off the A/C and don't touch the mode button for the air, you can have recirculating air without the A/C on (although I would never recommend it). However, you cannot have the A/C on in fresh air no matter what you try.
I actually met with a factory engineer about this here in Houston and, in effect, won a bet. he assured me the flap would be open if I put the switch in fresh air mode with the a/c on. When he saw that did not occur, he shook his head and was in somewhat disbelief. The on thing he did tell me but could not confirm was that there is more than one flap and just because we couldn't see any other flaps, he tried to assume there was still at least one flap keeping fresh air moving when the A/C was on. While this may be true, I'm convinced I will never know this for sure. The fact the air speed doesn't change convinces me, there is ni fresh air being coming thru the cabin filter when the A/C is on...which is 98% of the time in Houston. This explains why, after 3 years, my cabin filter still looked like new. Although, I did replace it anyway for good measure. Anyhnow, just wanted to share my story. The originator of this thread raised some good points and good he persisted in getting some feedback. BMW does do some crazy things and it is amazing how few people - including technicians and field representatives still do not understand about these cars! Thanks for listening and look forward to any feedback or input any of you may have. |
CSBM52754.50 |
04-03-2023, 03:06 PM | #63 | |
Rep 7,622
So let's say in your case its 70F outside. If you set the AC to 60F it will probably go into recirc. However if you continue raising the setpoint temp higher and higher will it eventually go into fresh air mode? In my case, it will. But if it starts to get hotter outside (or perhaps in the car), it will then kick itself back into recirc automatically regardless of the settings for that. |
07-01-2023, 12:30 PM | #64 | |
33
Rep 79
Hey, did you ever find a solution to this? I started a thread here about this on the G20 forum. I find this to be really concerning! Link to my thread: https://g20.bimmerpost.com/forums/sh...3#post30269353 |
08-15-2023, 05:38 PM | #65 |
Rep 2
It was interesting reading this...albeit 2 years later. This issue has bugged me since the day I bought my car new in 2013. I owned an 08 335 before this one and the behavior is certainly different. The minute I got my 13 I noticed it had strange AC tendencies. The first thing I noticed, and hated, is that the AC will run after starting the car, even when the AC is turned off. SOMETIMES.
I hate AC. What bugs me is the general attitude that BMW has a reason and/or it makes sense. I live in southern CA (NOT LA haters), I live where humidity is noticeable on the days it rains which can be counted using your fingers. Sometimes I start the car in the morning and it's dry as paper outside but the AC will turn on, I turn the heat up, the AC runs for about 5 minutes then shuts off and suddenly I'm heating the car so I have to turn the temp down. See, I have to fidget with the knobs so why not let me choose? The next day it might be damp (to us) but the AC doesn't run automatically so I manually turn it on. Have I mentioned that I hate AC? I only use it when it's really necessary so when the car turns AC on when it's 55 degrees in the morning I hate my car. See the relationship between loving your car "because it's a BMW" and living with it and wishing you hadn't. I know some other car vendors do this too but that doesn't make them smart just because they do it too. And saying it is performing as designed is a cheap answer. I was told that for 6 months when my car had a rattle after buying it. I learned to hate that answer. Why does BMW think they are smarter than those of us who wish to press the button when we want AC? I never had issues with AC on a car until they started overriding my choice. Think about it, we are talking about a car company that never wanted to design cup holders into the car, they thought the little coffee cup holder in the armrest was sufficient even though the dealers told them for 10 years that they needed cup holders. I don't consider anything they do "Smart". Intelligent maybe, but I never presume Smart. Point being, we do NOT need the AC to run in order to prevent fogging of windows. I have 4 cars and 2 of them don't have AC. I can't remember the last time I had fogged up windows. Maybe when the dewpoint reached total saturation one rainy day in 2010 LOL. Like the original post, my '13 335 recirculates the air when the AC comes on. I hate that even more than the AC running. I haven't connected B-link to see if the code says it is recirculating but you can hear the flap close and the fan is audibly louder. Plus you can feel the airflow differential. This is all confirmed if you press the recirc button there there is no difference like there is when the AC is off (on those moments the car lets you turn the AC off). I read that some models can be code changed to not auto-recirculate when AC is on so that verifies that BMW is coding it to recirculate when AC is on, on some models. Mine only has the option to save the last setting which doesn't make sense because it's always recirculating. You know, I never had issues with AC when I drove a car with a dumb air conditioner, they worked just great and I honestly never gave AC any thought. Windows fogging up on one of 10 rainy days? Turn the AC on. Is it hot? Turn on the AC. What's even more novel is if you moved the dial to Fresh your got fresh air. The problem is BMW got too pretty. They aren't driving machines anymore, they are trying to compete with luxury cars so they are heavy and have too much automation. Do I love the way my BMW drives? Yes Do I love their finish materials? Yes Do they have attributes that are not smart? Yes "BMW, You hate to love it". |
08-15-2023, 05:49 PM | #66 | |
Rep 2
BMW allegedly uses a variable compressor so why not let us choose when to turn it on. During the Spring and Fall fresh AC Air is refreshing but recirculated air is picked up down by your feet...is that what you want coming out of your vents? |
