04-05-2024, 09:02 PM | #1 |
Rep 9
Ruff Idle and Stall
I have a 2015 335i m sport and was having some problems running. At cold start, car idles ruff.(rpm’s drop then ramp up) If I do not let the car warm up, car wil buck and shake like hell. Car threw a MAF code and occasionally gives a drivetrain malfunction. The worst part of this is that when coming to a stop the car will occasionally stall. To put on that car shifts aggressively.
Mods Mhd stage 2 plus with FBO Xhp stage 3 |
04-05-2024, 10:13 PM | #2 |
Rep 1,699
Drives: 2014 428i and 2018 X5
Have you cleaned the MAF sensor and throttle body? What did the codes say?
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
rrupert131.50 |
04-06-2024, 07:19 AM | #4 |
///M
183
Rep 676
Drives: '18 F80 M3 ZCP, '14 F30 328i
get some CRC MAF cleaner, give it a good soak and let it dry. Reset the code and see if that helps.
F80 ///M3 2018 / ZCP / executive / 6-speed / nav
F30 328i 2014 / dinan sport kit / premium pkg / 6-speed / nav / hex trim / HK sound / B14 coilovers / oem roof rack / active autowerke exhaust / eventuri CAI |
rrupert131.50 |
04-06-2024, 04:26 PM | #6 | |
Rep 12
04-07-2024, 01:24 PM | #8 |
Rep 12
I am having a similar issue on my ‘15 335 as well (im getting mixture too lean codes), if cleaning the maf hasnt worked for you. I would suggest trying on the stock intake if you have it and see if that changes anything.
Here is a link to my forum: https://f30.bimmerpost.com/forums/showthread.php?t=2093693 If i figure out a solution to my problem i will post it there. |
