Assorted LED BULBS- 5000-6000k various prices
04-25-2014, 03:42 PM | #1 |
Came to the N55 Darkside
1115
Rep 12,740
In the pictures below you'll see an assortment of LED bulbs- mostly interior- for the dome, the footwells, the map lights, and so forth. Others, however, are miscellaneous- not quite sure what they are for - could be for brake lamps, could be for exterior lamps. If you're interested in one or more- or all of these LEDs- please contact me for details. The ones in the silver packaging are 2 T10s, and would sell for 10 bucks- perfect for dome or map lights, and are a cool 6000k. The others in this set range from the 5000K to 6000K white LED spectrum. - The two panel LEDs are for the dome light. The one without the wire is a HPB high output 6000k LED panel ($20). The other LED panel with the wire would be mounted by double-sided tape, and may possibly be from E-92 lighting. - The two with the grey colored base, and that I hold in my fingers, are for a dome light or map lights. - The other two with the 4 square LEDs are for footwells (5$ each). - The two in the upper left and right corners are for dome or map lights as well (10$ each). - The three on the left and right side of the HPB high powered dome panel are misc, 194 and 168 bulbs I believe, but I am not certain what they are used for. - The two wire sockets on either side may possibly be for an LED reverse light conversion perhaps, although I can't really be sure about this. Perhaps HPB or Jeff can help a brother out with IDing some of these LED bulbs? I have 100% positive I treater feedback and ship via USPS priority with tracking, or we can meet up for a deal - buy with confidence! I posted prices for those of the bulbs that I know for sure what they're used for. The other bulbs are negotiable. Pics below. I will try to answer any questions as best I can, but the ones that I can say for certain go for the interior are the ones that were specified as such. I can only guarantee for sure that the T10 dome light bulbs (5000k) in the upper left and right corners of the picture, and the two T10 bulbs in the silver bag (6000k) are CANBUS. While all of them should work just fine, I can no way guarantee that they won't go off in certain vehicles. That said, the interior LED bulbs mentioned should work fine in any E90, E92, and even E93, with the exception of the high output HPB 12 LED dome panel light in the upper middle. Thanks for looking, and looking forward to doing business with you |
04-25-2014, 04:20 PM | #2 |
1115
Rep 12,740
Dome light bulbs, outer left and right corners: I toned down the exposure so the color of the light could be seen, but believe me when I tell you they're bright as hell. I would put them around 5000k.
04-25-2014, 04:21 PM | #3 |
1115
Rep 12,740
One without a filter, real world brightness:
The other bulbs, with the exception of the HPB high output LED dome light, are around this same 5000k white as well. I believe the LED dome panel (without the wire, topmost one) is 6000k. |
05-01-2014, 07:40 PM | #4 |
1115
Rep 12,740
Two more to add to the collection:
2PCS T10 8 LED SMD 3020 No Error Canbus LED White Lights Bulb Lamp: 6000-7000k range Use for dome or map lights. If interested PM me and we'll work out a price. |
05-01-2014, 07:43 PM | #5 |
1115
Rep 12,740
And these:
Color Temperature: 6000K White Bulb diameter: 11mm Length: 29mm Bulb type: T10 (dome or map) If interested PM me and we'll work out a price. |
05-28-2014, 06:27 PM | #6 |
Do you even post BRO?
219
Rep 2,937
Drives: 330xi
do you have a whole set of dome lights with the same color lol. front back with left and right and center bulbs thanks. maybe i can pick them up where in nj/ny are you. you can pm me if its easier
06-06-2014, 11:39 AM | #8 |
1115
Rep 12,740
Bump!
I know everyone out there knows at least someone- or might be that someone - who needs just those couple of LEDs in their car to make that look happen. |
09-21-2014, 07:46 PM | #12 |
295
Rep 2,203
Currently looking for LEDS that will fit, Puddle, footwell and trunk. If these work I'll take all of em off ya. PM Price for all if you like!
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
09-27-2014, 12:38 PM | #13 |
1115
Rep 12,740
Well, the flat chip looking ones are definitely foot well brotha- any of the other T10 LEDs would fit puddle lights, domes, or maps.
The trunk light would be a festoon replacement (the vial looking one with pointed metal tips on both ends.) I do not have one like that I actually got a replacement module for the trunk light from HPB. |
02-09-2016, 06:54 AM | #19 |
Rep 1,413
Drives: 2020 X3MC
How much for interior set for 07 E92 shipped to 21784?
02-09-2016, 10:01 AM | #20 |
1115
Rep 12,740
Not sure they're a complete set, but let me get another shot of what I currently have when I get down to the garage. I imagine the only bulbs missing would be the glove box, trunk, and the two small bulbs on either side of the rear passenger area.
02-09-2016, 09:53 PM | #22 |
1115
Rep 12,740
Let me get together what I have now as soon as I can. They're really just various LED bulbs- not exactly a complete set, but what I have can accommodate most interior lights (maps, dome, footwell, under door puddles.)
