2010 2011 BMW 5 Series Forum F10 Clicking sound while turning the wheels |
06-04-2021, 08:11 PM | #1 |
292
Rep 353
Hi guys, can anyone please help. I hear a click when I back up my car in the garage and turn the wheels to the left. If I try to replicate it, I will not hear it again. It only clicks once. It's a F10 535 is with about 52K miles.
Here is the short clip: https://youtube.com/shorts/KvvEUI3HMYs?feature=share Thank you in advance! |
06-04-2021, 08:31 PM | #2 |
Rep 11
Can you roughly isolate the location of the noise? If it sounds like it is coming from higher up, could be the strut mount bolts loosening which I have seen happen.
To remedy that, retorque the 3 bolts on the strut mount as well as the pinch bolt on the bottom of the strut. It could also be a million other things but this is something that is relatively low effort. Scarier possibilities could include a bad rack or steering column maybe, if the sound is coming from roughly that region? |
zvery777292.00 |
06-04-2021, 08:40 PM | #3 | |
292
Rep 353
I appreciate your input and will keep this post updated once I have more news. |
06-04-2021, 08:50 PM | #4 |
292
Rep 353
06-04-2021, 09:55 PM | #5 | |
1312
Rep 2,595
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
06-04-2021, 10:03 PM | #6 | ||
292
Rep 353
06-05-2021, 11:35 AM | #7 |
Rep 11
I am not familiar with this specific service bulletin but I know F10s are fairly common for eating up wheel bearings and CV axles. I had a wheel bearing replaced and am due for an axle myself
The reason I think that it might not be related to this is because you mentioned you only hear the sound once. When I had issues with my wheel bearing, it was a consistent grinding and while I am currently having issues with my CV axle, its a consistent "tick tick tick .... " sound when I am turning. That being said, its something I'd still say to have them take a look at because worst case, they will inspect the CV axle boots (which are notorious for ripping) and catch any issues before a failure there. |
06-05-2021, 12:04 PM | #8 |
Rep 5,410
Other than your anecdotal experience, any evidence? This is the 1st I've read of this and I have about 90K miles between our 2 F10's with no issues.
06-05-2021, 06:01 PM | #9 | |
Rep 639
Drives: 2016 Alpina B6, 2015 535i
06-05-2021, 09:48 PM | #10 | ||
292
Rep 353
06-05-2021, 09:50 PM | #11 | |
292
Rep 353
07-28-2021, 07:54 AM | #13 |
292
Rep 353
Problem solved
Finally got this issue fixed. Here is what the dealership did:
"clicking noise caused by vibrations between wheel bearing and swivel bearing. Tech 1 880- Verified brake caliper concern, Unbolted right front caliper, untwisted, rebolted caliper, torqued to spec. Verified clicking noise, per SF AH referred to SIB34-05-15, Instaled shims between hub and brake rotor and between brake rotor and wheel, on both sides. Found clicking noise still present. TECH 1856 - VERIFIED CLICKING NOISE CONCERN. FOUND SIB 31 01 12 RELATING TO CONCERN. FOLLOWED SIB AND PERFORMED REPAIR. WHEEL BEARING WAS REMOVED AND MATING SURFACES ON WHEEL BEARING AND SWIVEL BEARING WAS CLEANED. APPLIED TWO COMPONENT GREASE ONTO SURFACES. WHEEL BEARING WAS REINSTALLED AND HARDWARE WAS REPLACED. HARDWARE TORQUED TO SPEC. SHIMS FROM TECH 1880 WAS REINSTALLED BETWEEN HUB, ROTOR, AND WHEEL. VERIFIED REPAIR WITH FOREMAN. CLICKING NOISE IS NOT CURRENTLY PRESENT AT THIS TIME." |
07-30-2021, 06:40 AM | #14 |
Rep 1,062
Thanks for posting this!!!
Does anyone know how to look up SIB 31 01 12? Also, what the heck is a swivel bearing? Is that some weird translation of ball joint from German to English? EDIT: perhaps the swivel bearing is the outer CV joint on the axle? |
07-30-2021, 02:37 PM | #15 | ||
292
Rep 353
I have no idea what a swivel bearing is but I'm sure someone in the forum does. |
07-31-2021, 10:22 PM | #16 | |
Rep 1,062
https://static.nhtsa.gov/odi/tsbs/20...48312-9999.pdf They're talking about the mating surfaces between the wheel bearing and knuckle. |
zvery777292.00 |
11-07-2023, 09:11 PM | #17 |
189
Rep 132
So one of the remedy to front axle clicking is procedure that involves BMW REPAIR SET MICRO/ part#83192298825 for bloody $73. This kit is 2 components grease and piece of sand paper. has anyone find substitute for two part grease from BMW? Thanks
11-08-2023, 05:31 AM | #18 |
Rep 1,062
It’s probably nothing special, just something to keep the surfaces from corroding, sticking together, then clicking when they move relative to each other. $75 is about what I’d expect BMW to charge for $3 worth of materials, lol.
