09-01-2021, 01:28 AM | #1 |
Rep 818
[6MT] Changing gearbox gears ratio or diff final drive ratio?
Hey guys.
I'm not satisfied with the gear ratio of the 6MT, I think it kills pretty much of the torque when you shift to 3rd and 4th. Actually I'd like to make 1~5 gear shorter, keeping the 6th like an overdrive gear. I would make my street rides more fun, yeah, but mainly the track days. I've seen some posts about shorter final drive ratio, but none about the gearbox. Is it too expensive to do that? Change the 5 gears of the gearbox? That would lead me to the other option, which is changing the final drive ratio. I've been watching some videos, and the 4.10 seems to be not enough for what I expect. The 4.44 is quite that. This is a 4.44 final drive: Compare to my stock 3.85 final drive: I can't help beeing amazed for the 4.44. Those gears fit so perfectly. But fuck, the 4.44 is $2k more expensive than the 4.10. But whatever, I would pay. 6th gear will be shortened too, I know, but I can stand it, as we don't have any road here in Brazil which is allowed to travel above 75mph, and I'm not a final speed lover. But in the track I want to have all the gears in the optimum torque band. And on the street, I want to spin the rear wheels anywhere. Well, cut the talking. What would be more expensive? Gearbox ou differential? |
09-01-2021, 03:09 AM | #2 | |
Rep 510
Drives: 2007 E85 Z4 / 2013 E93 M3
The real question is: have you done the math and the calculations on trans ratios vs. 4.44 gearing? Go run rpm vs gearing calculations and do you think you can live with that? -Duke |
09-01-2021, 03:42 AM | #3 | |
Rep 818
I want the shorten the five first gears, but keep the original 6th gear ratio. If that is more expensive, I would give up on the long 6th gear ratio, and would go with the shorter diff ratio. I just was curious about tuning the gearbox gear ratios, and couldn't find any info about it. |
09-01-2021, 03:49 AM | #4 | ||
Rep 510
The gearing would be the easiest and simplest way to go. If you find someone who can rebuild your 6MT with updated/upgrades ratios, it's going to cost probably in the 7-10K range (I'm ballparking it here). They'll have to match up ratios to your 4.44 and ensure it works and syncs up correctly to actually be usable on track or street. Additionally, you'll need some tuning for the engine to ensure DME doesn't throw some crazy codes for engine speed vs trans speed or whatever weird stuff might come up. Not saying it can't be done, I've just never heard of anyone doing it or read about it. Someone might have, I just don't know. -Duke |
09-01-2021, 04:08 AM | #5 | |
Rep 818
I can either change ONLY the final drive gear, which is located in the differential, or change ONLY the gears in the gearbox. There's no need to do both. If I choose to go by the final drive gear, I'll change the wheel speed in all the gears, which will make the 6th gear a not so good gear to drive in long trips. If I choose to go by the gears in gearbox, I can shorten only the 1st to 5th gears, and leave the 6th stock, keeping it good to drive in long trips. The only con would be the big RPM drop from 5th to 6th gear, but absolutely no problem with that. |
09-01-2021, 04:16 AM | #6 | |
Rep 510
4.44 gears would be cheapest. 4.44 gears + trans ratio rebuilt would be crazy expensive. Not saying you can't do both, again, just comes down to cost. Additionally, at that cost point, why not just get a S/C and not mess with gearing? You'll get nearly the same results, if not better from the increase in HP. -Duke |
09-01-2021, 04:19 AM | #7 |
469
Rep 280
Drives: M2 F87, M3 E92 & E46, C63, 911
Garage List 2018 BMW M2 F87 [0.00]
2008 BMW M3 E92 [0.00] 2003 BMW M3 E46 [0.00] 2012 BMW M3 E92 [0.00] 2011 Merc C63 AMG [9.00] |
why is a 4.44 cwp $2k more expensive then a 4.10?
due to limited stock at the moment i sell the 4.44 for eur 1.200,- compared to eur 1.000,- for the 4.10. so this is only €0.2k more. you can instead use the saved $1.8k to also fit a proper clutch lsd which improves handling and traction a lot! i never heard of other gears available for m3 6mt gearbox. i guess this conversion would be way to expensive. no one will spend this for a street car. and if you want to spend it for a racecar it makes more sense to just swap to a sequential racing box where you can choose each gear individually when ordering. |
DukeofAlexandria633.00 jvictormp912.00 |
09-01-2021, 04:21 AM | #8 | |
Rep 818
S/C is not something I'm adept to. |
09-01-2021, 04:24 AM | #9 | |
Rep 818
In the internet I only found the 4.10 M-Diff for 2.5k USD, and the 4.44 M-Diff for 5k USD. I'll keep that in mind, driftflo Not buying it right now, but I will. By the way, you gave me the argument that I needed about tuning the gearbox. |
09-01-2021, 04:31 AM | #10 |
469
Rep 280
currently i have one last 4.44 cwp in stock.
not sure when the next batch will come. bmw motorsports parts (for older cars that are no more used in competitive racing) are sometimes out of stock for long time. i heard they want to produce some new ones... but i do not know when they become available. btw: 5k is a bad joke! |
jvictormp912.00 |
09-01-2021, 09:42 AM | #11 | |
///M Powered for Life
11503
Rep 10,336
09-01-2021, 10:22 PM | #12 |
Rep 844
Drives: 2009 E93 M3
Garage List 2008 E90 M3 [0.00]
1995 BMW M3 [0.00] 2004 BMW M3 [0.00] 2011 BMW 335xi [0.00] 2011 BMW 335is [0.00] 2009 BMW M3 [0.00] |
I just made the switch from a OE 3.85 to a Dinan 4.10 Gear set and it woke the car up.
Has enough torque down low for 3rd-4th backroad driving. I can't imagine having gears shorter than this though. |
09-01-2021, 11:25 PM | #13 |
Rep 818
09-02-2021, 08:30 AM | #14 | |
Rep 844
Drives: 2009 E93 M3
Even around town on low speed roads you'll catch yourself in 4th and 5th rather frequently. I understand having vanos engaged by every gear shift by adding a 4.44, but also doing custom gears just wouldn't be worth the price and the usability of the car. For your purposes on tighter race tracks I can see why you'd want a 4.44, but it just wouldn't make sense anywhere else. Instead of spending 10k on a transmission, you can do a stroker motor, and have the down low power you're looking for without losing the drivability of the car. I believe Dinan paired the 4.10's with their strokers and saw great results. |
jvictormp912.00 |
01-03-2024, 10:47 PM | #15 | |
Rep 7
Drives: e92 M3
So Im looking to get a new diff since i blew mine, and im considering changing from the 3.85. If i got a 4.10 would i accelerate to 100 faster than the 3.85? If i lined up with a car with a 3.85 would I be faster given we were both stock? is there any speed the 3.85 might be faster? |
01-04-2024, 08:42 PM | #16 | |
Rep 1,232
01-08-2024, 09:53 AM | #17 |
Dont listen to me
808
Rep 578
insert E46 M3 diff racing video
Instagram: @thatwhitem4
nycplumber687.00 |
01-09-2024, 04:26 PM | #18 | |
Rep 5,843
I regret selling my slick top, manually adjustable seats Imola Red/Imola Red e46 M3 with too many mods to list. I love the 3.62 FD DCT in my e92 M3! |
nycplumber687.00 |
01-10-2024, 09:14 AM | #19 | |
Rep 1,232
Also in this video it seems like with the new FD you are much higher in the rev range after each shift basically making more power the entire pull, negating any shift time loss |
01-10-2024, 09:25 AM | #20 | |
Rep 5,843
I have two e92 DCTs - one w/ stock 3.15 FD and one w/ 3.62 FD. No comparison between the two. 3.62 makes a noticeable difference in all gears. Best mod I’ve added. Makes 6th and 7th useable when cruising. Both are stage 2 tuned w/ 8600 rpm redline. The extra 200 rpm also makes a noticeable difference. Always hit the stock rev limiter when stock tune is reinstalled for emissions testing. |
01-10-2024, 06:09 PM | #22 |
Rep 4,180
Y'all 3.62 guys are making me regret my 3.45 a lil bit lol. 3.45 is still a great FD especially for daily driver which my car is. Really woke up the engine, and I could still hit 270kmh / 167 mph with the 3.45 (speed laws are lax here). But I'm wondering if I should have just gone 3.62.
