      06-13-2015, 05:47 AM   #1
vtl
vtl's Avatar
Australia
1495
Drives: 2008 BMW 135i MT
Cruise Control Failure after coding
One of the things I hate most is working on the car and making it worse than it was
I was interested in adding the dynamic cruise control feature to my car. It uses the brakes when driving down hills to slow you down. My car only has the regular cruise. So i added $544 (cruise control with braking ) to my VO and did FA_WRITE to CAS and NFRM. I then did SG_CODIEREN in expertmode to the CAS,NFRM,DSC and KOMBI modules.
Upon cycling the ignition, i get an error message saying "cruise control failure" in the idrive. Scanned the car with INPA and got these obscure errors:
MSD80 ECU:
Error: 1(1) No.: 52653 0xCDAD Botschaft (Anforderung Radmoment Antriebstrang, BF)
Translated: Error: 1 (1) No .: 52653 0xCDAD message (requirement wheel torque drive train, BF)
frequency: 1
error type: 4 (4281 ) Timeout
KOMBI:
A3AF CAN_ID_200_ERROR_Ausfall_Botschaft_Regelgeschw_Stu fentempomat
Translated: CAN ID 200 ERROR Malfunction message control rate cruise control level
Not sure what to make of these errors. No errors coming from the DSC module. The other errors seem to indicate they are not receiving messages they are expecting, probably from the DSC?
I removed $544 from the VO and recoded the modules but the errors still persist. Now the cruise control doesn't work at all.
I tried going into Tool32 and doing the steering angle reset procedure. Process ran fine but didn't fix the problem. Should I update the DSC module with winkfp?
      06-13-2015, 06:59 AM   #2
PXF00367
Drives: 135i
Oh,I just have same problem but my case is after cruise retrofit and add $540.
Error code is just same.
I expect being solved but doesn't 1 have $544 functions?
      06-13-2015, 08:51 AM   #3
reisf
reisf's Avatar
Australia
128
Drives: LBB M2
Try recoding SZL module, that has the steering angle sensor and is the thing with the the indicator, wiper, and cruise control stalks.
      06-13-2015, 06:26 PM   #4
vtl
vtl's Avatar
Australia
1495
Unfortunately SZD is not listed as a module for me in INPA or NCS Expert, it think coding is all in the DSC module.
      06-13-2015, 08:48 PM   #5
vtl
vtl's Avatar
Australia
1495
Tried updating the DSC module with WinKFP. Completed but didn't fix the problem. FYI if you reprogram your DSC you'll have to run all the recalibration items in INPA to get your DSC working properly.
      06-13-2015, 10:43 PM   #6
reisf
reisf's Avatar
Australia
128
Drives: LBB M2
Hmm maybe just try recoding all modules available to you...worth a shot right?
      06-13-2015, 11:53 PM   #7
vtl
vtl's Avatar
Australia
1495
Yeah, had a go recoding the modules and no luck.
I think its maybe because I coded $544 without removing $540 (regular cruise). Tried deleting $540 and then adding $544 and it has different behaviour. I no longer get cruise control failure on startup, and no error codes present in INPA. But when I try to activate cruise, I get this code from the DSC module:
DSC
5E64 5E64 - PT-CAN Instr_Cluster3 plausibility err_1
Error counter: 1 Logistic counter: 40
Vehicle speed 58.00 km / h
Brake Light Switch 0/1 00:00
Bremsfluessigkeitsschalter 0:00 0/1
ASC / DSC_aktiv (pushbutton function) 1:00 0/1
Brake pressure detected 0.00 0/1
ABS control 0:00 0/1
ASC control (BMR) 0.00 0/1
ASC control (AMR) 12:00 0/1
GMR control (GMR) 12:00 0/1
GMR control (MMR) 12:00 0/1
CBC regulation 0:00 0/1
MSR-control 0:00 0/1
TDR scheme 0:00 0/1
SDR-control 0:00 0/1
DBC control 0:00 0/1
RTA actively 1:00 0/1
Run-Up Mode 0.00 0/1
***no suitable error symptom. Fulfills test conditions
Error not currently available, but already stored error would not cause illumination of a warning light
Error code: 5E 64 20 01 28 08 00 04 3F 3A DE
Person on another forum experienced this error when they didn't VO code their KOMBI. Although I definetly did code my KOMBI as the warnings on startup went away.
Has anyone got a TRC file for their DSC module? Annoyingly its the only module I haven't got a backup of
      06-14-2015, 06:28 AM   #8
PXF00367
Drives: 135i
This could not be used since my system also has a problem, but the TRC file which changed each VO and was initialized, is attached.
It may be able to use for comparison.
But in my system, 540 and no specifying were the same contents.
      06-14-2015, 11:21 PM   #9
vtl
vtl's Avatar
Australia
1495
Thanks for that, I compared but didn't find any real differences.
I think it might be my programming setup has put wrong vo defaults into the DSC
I have come up with a workaround, so if I VO code the DSC and KOMBI to $544 (with $540 removed) and then change
ACC_AUSSTATTUNG to wert_03
Then I get cruise control with braking, but I don't get the cruise popup display in the cluster that shows the set speed. Otherwise the cruise control works and applies brakes down hills.
Not ideal but at least it works. I will see if I can play with the DSC options with the dynamic cruise and see if I can get a working default.
Otherwise I will try and reinstall BMW standard tools.
      06-15-2015, 07:43 AM   #10
PXF00367
Drives: 135i
When adding 544 to VO and setting ACC_AUSSTATTUNG to wert_03, I was surprised that the cruise control operated.
It is that 6 cylinders has 544 functions.
When the lever was pulled especially to the front for a long time, it turned out that a brake lamp lights up clearly.
It is completely wonderful.
I appreciate.
However, it is the same that meter is not displayed.
I also need to do my best in this dissolution.
      06-15-2015, 07:50 AM   #11
vtl
vtl's Avatar
Australia
1495
Cool, good to see the workaround worked for you as well.
I'm not quite sure what you mean by this? Do you mean your brake lights activate when you push + hold the cruise control stalk?
Also I am wondering under normal operation does the dynamic cruise control activate the brake lights when braking down hills?
      06-15-2015, 08:37 AM   #12
PXF00367
Drives: 135i
Since I tested at night, I found out that a brake lamp lit up.
If you continue pulling stalk to -dir, a car will be slowed down strongly and a brake lamp will turn it on the second half.
So in the downhill of excessive speed, I guess that a brake lamp lights up.
      06-17-2015, 05:31 PM   #13
vtl
vtl's Avatar
Australia
1495
Actually I have now found out theres at least 3 types of cruise control stalk. Theres:
1. A control stalk which has a distance control for active cruise
2. Control stalk with up/down/forwards/backwards (the one I have)
3. Control stalk with up/down and forwards/backwards with 2 positions, light press for 1kph speed increments, strong press for 5kph increments.
The 3rd one is used for dynamic cruise. So that would probably explain why option $544 doesn't work because we have the wrong stalk. Probably the can message is different for the stalks and the DSC doesn't like it.
The solution might be to buy a new switch column but that doesn't explain why I can't revert to stock.
PXF00367, what model and what options are fitted to your car? Did you have any other modifications?
      06-18-2015, 08:05 AM   #14
PXF00367
Drives: 135i
My 135i is 2007/12 N54 MT CCC, so may be near your car spec, and not carrying out special modification.
I do not think that the difference in a function is brought about by the difference in stalk.
stalk which I got is 61319123041 and this is actually common to almost all E8 and E9 series.
The information which I have acquired about cruise control is the following.
http://www.bmw.com/com/en/insights/t...cruise_control
S540A Cruise control
S541A Active cruise control
S544A Dynamic cruise control
Since information is not displayed on kombi, it does not understand in detail, but it seems that my cruise is two steps, 1kph and 10kph.
But the rate control in a curve is not certain.
I do not know why your setup does not return, either.
In search of a 135i owner with other auto-cruise, I am going to acquire information.
      06-20-2015, 09:36 AM   #15
PXF00367
Drives: 135i
vtl, I want to check your 540 KOMBI.TRC.
Can you upload that file?
      06-21-2015, 05:23 PM   #16
vtl
vtl's Avatar
Australia
1495
Attached my kombi trace for option S540A and S544A
      06-22-2015, 07:27 PM   #17
PXF00367
Drives: 135i
I got another factory 540 coded trc but AT, AFS model's.
I am going to go to a dealer at this weekend for 540 coding, may be not 544.
If it goes well I will upload data.
      06-30-2015, 06:46 AM   #18
PXF00367
Drives: 135i
did not go well, since it did not exist in a menu, was not able to code in a dealer.
      06-30-2015, 07:00 PM   #19
vtl
vtl's Avatar
Australia
1495
Ah thats a shame. I haven't made any progress either. Tried the latest (that i could find) v54 daten files and didn't make any difference to the programming.
      11-23-2017, 07:40 AM   #20
juld0zer
Australia
480
Drives: Prev 135i 7DCT, Now 130i 6sp
Vince, did you ever resolve this issue?
It suddenly happened to me after I fitted a donor DSC module (done the same previously without issue).
Last time i drove the car to work to program and encode using ISTA/P but this time i used Tool32, NCS Expert and INPA. I have a feeling the Tool32 method of writing the VIN stuffed things up.
Even after a full recode in ISTA/P i still have the same problem.
I tried connecting both of my spare DSC control units (all are coded to my car), same two faults (A3AF and CDAD) persist.
I also went as far as chopping and soldering in a new section of wire for the speed signal output from the DSC to the bundle of wires under the dash, believing i may have disturbed the harness too many times from swapping masters, boosters, DSC modules etc. No change.
      11-23-2017, 04:05 PM   #21
vtl
vtl's Avatar
Australia
1495
Ah sounds like a real pain!
I have never bothered to revert the dynamic cruise control after my workaround. The cruise control is great and I wouldnt want to go back to stock, which is when I get that error.
I received a pm from Duesentrieb who suggested to reset the Varianten Codierung:
you could reverse it. You need to code $540 to cluster and DSC and then reset the 'Varianten Codierung' in the DME. After resetting, the car needs to go to sleep mode. (The light of the start button will switch off, when the car sleeps). After this $540 would work again.
I see you have an N55 which has pretty poor support in INPA (unless its all untranslated)
On N54 I think this is done by going into INPA MSD80, status analog/digital -> digital value -> car equipment ->reset
On N54 it learns the car's equipment (one of them being cruise control). It may have gotten stuffed up somehow and you can try this, but might have to be done via tool32 on N55.
I have tried this fix to get the popup for the current set speed of the cruise control to display on the cluster but no luck I have not tried to revert back to stock to fix the CDAD and A3AF errors. With my workaround I don't get any errors so might be worth coding in dynamic cruise control $544 if you cant get it working on $540
SE7EN335330.00
      11-24-2017, 03:20 AM   #22
juld0zer
Australia
480
Vince - you're a lifesaver man! If you ever come up to Sydney i owe you a beer.
N55 is supported but it's a bit of a hack to get it to work and yes - it's largely in German.
So i hooked it back up to ISTA, deleted the DME adaptation values and stored versions (I figured this is as close to your suggestion as possible). Didn't work. Part of the procedure is to wait 30s afterwards, which i did but still no bueno.
This is another of those situations where INPA is better than ISTA. I crawled my way through the German menus and then found "gelernte Varienten" amongst the possible adaptations resets. It is the only one with varienten in it. So i clicked it, held my breath and wala.. no more annoying cruise control failure warning punching my nose every time i start the car!
Hopefully this helps someone out there. I did find a few threads with no resolution so we are not the only ones suffering this random issue.
SE7EN335330.00
