03-13-2017, 10:13 PM | #1 |
Rep 11
Tail Light Connector Short - Help Identify This Part
Driver side blinker shorted then the brake light was in and out. Took it apart to see that the pins in the connector shorted out and some broke off in the tail light's receiver (dorman socket?). I have attached the picture of the brake light side that I need to replace. It is attached to the black housing, not sure if it is replaceable without replacing the whole light.
Can someone help identify what this piece is called? Additionally I assume I will need to replace the taillight connector itself back to the wiring. Part numbers for each would be great. Here is a retrofit thread which seems to be the closest how to: http://f30.bimmerpost.com/forums/sho....php?t=1174188 |
assembly, bulb failure warning, replace, tail light |
