BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > N54 Dyno Chart Compilation
      04-26-2018, 09:44 PM   #683
GEOS07335i
Drives: 08 335i
Originally Posted by shanker604 View Post
solid #s
you wouldnt make more by pushing it past 6000rpm... these tunes taper the boost the higher you go so there is no need pushing it past 6000 rpm on stock turbos
These were 5th gear pulls. Is it better or more accurate to do the pulls in 4th or5th gear?
2008 335i E93, DP's, 7" FMIC, DCI,CP TIAL Q BOV, MHD Stage 2+, Alpina Flash
      04-27-2018, 06:05 AM   #684
NoGuru
NoGuru's Avatar
772
Drives: 335is
2021 Chevy Silverad ...  [0.00]
2002 Jeep Cherokee  [0.00]
2014 CTS  [0.00]
2011 335is  [0.00]
Originally Posted by GEOS07335i View Post
Here is the Dyno. I think these are decent numbers for what I have. Also I had asked the speedshop not to run it to redline but shift around 6K. So maybe it would have made a little more.
  • ARM 7" FMIC
  • ARM DP's
  • ARM DCI's
  • ARM CP
  • Tial Like BOV
  • VS BAP MAP Adapter (for BOV to intake)\
  • MHD Stage 2+
Here is the 2 data logs of the DYNO Run's if anyone cares: https://datazap.me/u/geosbmw/arm-fbo...-5-14-24-25-28
I made 378/403 with basically the same setup.
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
      05-05-2018, 09:45 AM   #685
feuer
feuer's Avatar
Drives: wife crazy!
Newer engine and turbos!
      05-11-2018, 08:21 AM   #686
GEOS07335i
Drives: 08 335i
I posted a few weeks ago. I'm curious about DYNO's what gear should the DYNO be run at to get the most accurate power rating. I've heard 3rd or 4th gear pulls. My shop did the pull in 5th gear and I thought the car was going to blow up?
      05-11-2018, 09:33 AM   #687
RSL
Drives: E92 ///M3 (Retired) / 335is
Closest ratio to 1:1. 3rd or 4th for logging on the street maybe, not on a dyno.
      05-11-2018, 01:13 PM   #688
Silent9n54
574
Drives: 2007 E92 335i
i think dyno is usually done in 4th right ??? maybe 3rd if you are not making a lot of power
      05-11-2018, 01:57 PM   #689
NoGuru
NoGuru's Avatar
772
Drives: 335is
2014 CTS  [0.00]
2011 335is  [0.00]
Like RSL said, closest to 1:1 in the gearing.
My DCT is 5th.
      05-15-2018, 03:07 PM   #690
rsyed07
rsyed07's Avatar
Drives: E46 330i, E92 13' 335is
2011 335is 7spd DCT 72k miles walnut blasted at @71k
Dynotjet pull adjusted for 5th gear with 93 octane gas
Stock baseline
302whp/346ft-lbs
MHD Wedge Stage 1+ tune
VRSF Chargepipe
NGK plugs gapped to 0.022
348whp/397ft-lbs
Will post an additional dyno when intercooler, downpipes, and possibly inlets are installed for FBO status.
      05-15-2018, 09:46 PM   #691
RagingE93
16
Drives: 335i E93
Just dynoed my car
2007 335i
No walnut blasting
Mods
Vrsf dp
Injen dual intake
Charge pipe with tial bov
5” step intercooler
Ngk plugs
JB4 G5
MHD backend race flash by bms
Ran on map 5 @19lbs
Dynojet corrected
400whp / 442wtq
      05-16-2018, 03:52 AM   #692
Silent9n54
574
Originally Posted by RagingE93 View Post
Just dynoed my car
2007 335i
No walnut blasting
Mods
Vrsf dp
Injen dual intake
5” step intercooler
Ngk plugs
JB4 G5
Ran on map 5 @19lbs
Dynojet corrected
400whp / 442wtq
nice results !! welcome to the 400whp club
Not too familiar with JB4 but was that on straight pump gas or you have some E85 in there ?
      05-16-2018, 09:45 AM   #693
RagingE93
16
Drives: 335i E93
This is on race flash with 4g of e85. I haven’t done any walnut blasting so I know there’s a few more ponies we can get out of her.
      05-16-2018, 09:52 AM   #694
RagingE93
16
Drives: 335i E93
https://youtu.be/qLhpRR_b6xs
vids
      05-16-2018, 03:13 PM   #695
Silent9n54
574
i take it back, welcome to the 399whp club
      05-16-2018, 03:28 PM   #696
RagingE93
16
Drives: 335i E93
Hahha. Hater! I’m sure one more pull would of been over 400. Map 5 was still auto learning.
      05-16-2018, 06:28 PM   #697
Silent9n54
574
not a hater im just kidding man !! you can call it 400 !! i call mine 410whp when in fact it was 408
      06-08-2018, 05:04 PM   #698
hcopeland
Drives: Graphite E92 335i
Originally Posted by natedog7700 View Post
You should be making more than this. Whats your boost and what LPFP you running?
I want answers!!
'07 335i e92 -- RB Turbos - JB4 G5 - MHD Tune - VRSF Catless DP - VRSF Relocated Inlets - Devilsown/BMS Methanol Injection
      08-02-2018, 06:48 AM   #699
lightmanek
lightmanek's Avatar
117
Drives: BMW E92 335i N54 MT ST PI FF
335i 2006 with 167k+ miles
This is my E92 335i on dyno a year ago.
Pump fuel (Shell V-Power 99+) and BQTune.
Mods included among others:
Hybrid Turbo S2 from PerunTurbo, 4BAR TMap, Chargepipe, HKS BOV, Forge 7'' FMIC, Sport Alu Radiator, Ebay oil rad 3x bigger than stock, 3'' catless exhaust with MG Motorsport muffler, RM Motors downpipes, DCI from BMS, Air scoops, MMP in and out 2'' pipes, 550i Clutch, NGK gapped, many more little things I forgot about. Bottom line is, this was stock fuel system and now I know that car had misaligned camshaft as one cam skipped one chain giving non-ideal ignition at high RPM.
      08-06-2018, 02:29 PM   #700
rsyed07
rsyed07's Avatar
Anybody have any e30 map dynographs?
      08-06-2018, 04:03 PM   #701
Julian2485
Drives: Black lci e90 335 xdrive
Is your clutch holding up ?
      08-06-2018, 07:49 PM   #702
lightmanek
lightmanek's Avatar
117
Yes, there are pics of it in 550i clutch thread on this forum.
I did 39k miles on mine and it still holded strong. Only thing, my pressure plate maxed out so the clutch was starting to grab up top the pedal.
As I'm doing engine rebuilt before pushing for 600hp, I'm putting brand new 550i clutch.
      08-06-2018, 10:06 PM   #703
Masher
19
Drives: 2008 E92 335i
Stage 1+ v8
Mods:, MHD v8 Stage 1+ 93 octane, super dirty DCI (not cleaned 4+ yrs), downpipes.
Car is a 08 e92 335i, has 165k km.
Also have a 1-1.5 psi boost leak nbd, can't really find it + too lazy.
https://datazap.me/u/masher/after-ba...og=0&data=3-23
Need a baseline dyno with stock map to see how accurate this is...
Got around 361WHP, max boost of 15.5 psi, im surprised my hp was this high actually, esp with my boost leak. When i smooth it out to 2 i get 350whp.
Deciding if i want to go stage 2+ or not... decisions.... Wonder if stage 1+ accounts for the downpipes as it wasn't a requirement for that map.
      08-08-2018, 08:01 PM   #704
langsbr
234
Drives: 335i
Shame shame, someone has a naughty copy of windows, lol. :-P
