07-30-2016, 05:55 AM | #46 |
58
Rep 232
The crazy thing was that I didn't get a coolant low light, it gave me a drivetrain malfunction light. The dealer said it was because the oil temp was different than the transmission oil. I was about 3/4 gallon low.
09-23-2016, 01:49 AM | #47 |
Rep 3
Every 2 weeks I get a notification on the computer saying low coolent. I keep topping it up but obviously something is wrong. I cannot see a leak anywhere on the ground so any ideas what it could be?
09-23-2016, 06:05 AM | #49 |
58
Rep 232
11-08-2017, 08:48 PM | #53 |
Rep 5,233
Fine to add to both reservoirs; had it done at the dealer recently.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND LONG GONE: 09' E60 M5|02' E39 M5 |
BMWM5NYC496.00 |
11-09-2017, 09:39 PM | #55 |
Rep 5,233
BMWM5NYC496.00 |
11-25-2017, 01:15 PM | #57 |
Rep 740
11-25-2017, 01:19 PM | #58 |
Rep 5,233
Same coolant in both; recently had these topped off at dealer.
07-03-2018, 10:38 AM | #59 |
Rep 620
Thank you for making sure the correct information was posted in this thread. Frankly Used2B and a few other members need to delete/edit their incorrect and misleading posts in this thread as it could cause someone looking for a quick answer to put coolant in wrong hole.
07-03-2018, 02:08 PM | #60 | |
Perennial PFC
336
Rep 1,275
E90Fleet shows the comparison of the 2013 manual and the revised 2015 manual in his #21 and #22 posts on the first page of this thread. Good information if you wish to learn more. |
07-04-2018, 05:11 PM | #61 |
112
Rep 385
I checked my manual and it will also confuse anybody who hasn't had BMW experience. It mentions only one tank, locates the turbo tank, but shows a close up of the engine radiator tank.
The engine coolant filler on my USA driver's left side is the same cap BMW has been using on some models since the '90's. Note, it isn't the same cap still used on current models that have a big high mounted expansion tank you can see. These are pressure release caps, they are supposed to allow blow off at a certain pressure for safety. On the F10 M5, you can't see the tank and all you get is a long filler neck, kind of like a wash/wipe reservoir filler. The other little filler tank up close to the engine with the knurled cap is for the turbo cooling circuit. Note: although the main coolant circuit for the engine/AC/Steering/etc has a level sensor, the turbo circuit does NOT! Yes, if you get a leak or worse a hole in the turbo circuit radiator or lines, you can bleed out all the coolant in no time flat and there will be no warning. Guess how I know this. Both tanks take the same 50/50 diluted mixture of BMW coolant. On USA cars, the engine radiator filler neck has no min/max level (the first car, let alone BMW, I've seen like this). This is some trick BMW NA has to get all us "rich" people to keep coming back to the dealer for stupid things. In any case, a tape measure set to 6" makes a perfect gauge to stick down the neck. If it just touches the coolant in the bottom of the neck, it's perfect. Fortunately the turbo circuit tank has a min/max level gauge inside and it's a snap to check and fill. STAY VIGILANT! Check these levels every couple of weeks at a minimum, especially the morning before you go out for a planned hard run. Cooling is a major Achilles' Heel of this and it's 550i brother. Remember, the turbo/intercooler coolant circuit has NO low warning! You need to fix any leaks as soon as they start. Pictured below is the main coolant circuit cap for the engine, heater core, etc. Last edited by TLK; 07-04-2018 at 05:17 PM.. |
07-08-2018, 11:07 AM | #62 | ||||
Rep 620
2014 911 Carrera S - White/Two Tone Espresso/Cognac - Aerokit Cup...
2013 F12 M6 - AW/Black Merino - Loaded 2018 F150 XLT Sport - Lightning Blue/Black Cloth - 5.0 V8 4D/4WD... |
11-21-2018, 09:41 PM | #64 | |
72
Rep 96
Got a warning on my dash that had me look. Stated: Engine coolant level low: Top off as soon as possible. Possible engine damage. Attention: scalding hazard. A little aggressive on the verbiage, made me nervous.. I'm assuming its correlated to that driver side tank rather than the passenger side tank, as that is above minimum. Any thoughts? Yes, I do have a leak on the coolant lines that are common. Need to swap out the rubber hose and clamps.. |
11-21-2018, 10:09 PM | #65 |
112
Rep 385
There could be a big difference between 1 inch from the top and 6 inches. Undoubtedly there is an expansion tank or chamber somewhere since hot liquid expands in volume. If you really did fill it almost full, it would just come boiling out the relief valve in the cap or blow the cap off if it doesn't work.
My 6" measurement is based on the metric info I got out of TIS. The warning message is a helpful message but also liability mitagator. Yes, if you open it while it is hot you can get badly burned. When you try to sue BMW to cover your medical bills, their lawyers will pose that you were warned by the car and you did not heed the warning, so BMW is not responsible. Liability mitagators are to be seen constantly here in the USA, where most of the world's lawyers live and work, and most of these type of liability lawsuits are filed. Finally, general advice to everyone - don't be cheap or lazy about fixing cooling system problems. This is a $100k USD car, it has at least 7 radiators in two cooling circuits to cool the engine, turbos, DME ECUs and so on. This is why there are no fog lights on the F10 M5. That space is needed for airflow through radiators that other cars don't have. If you get a bad failure of a hose, pipe or connection, or even a leak in a radiator, you can start losing coolant fast enough that you not be able to drive the car. Maybe even damaged something badly. And not that much of the cooling system is visible without a lot of disassembly, so you won't just fix it by the side of the road or at home. |
Seattle99672.00 |
11-22-2018, 01:35 AM | #66 | |
72
Rep 96
I've replaced the rubber hoses and clamps for the coolant lines once already. After today's warning, I checked again and noticed one clamps leaking a bit. What a terrible design flaw. The BMW heat shield jackets they supply are simply shocking. The stock BMW crimped clamps are terrible as well. I was able to spin one by hand before replacing it.
F10 M5 6spd - Real Drivers Use 3 Pedels - BPM Tuned - SOUL Exhaust - aFe Intake - 21" AG M590 on MPS4S Tires
B9 Audi SQ5 FZJ80 Toyota Land Cruiser |
