09-19-2020, 01:13 PM | #1 |
19
Rep 83
"Seized" Caliper
Just came for tire change to a local mavis. I'm being told my front left caliper is "seized" being told it's a 'ticking time bomb'. They showed me the brake. Front pads is more worn than the rest.
Is there anything I can try to fix this . I cannot open it up or work with brake fluids. The mavis folks are saving they can get a caliper that's not bmw but made by the same company. Also they said they would need to bleed the brakes and put .4 brake fluid. Any reccomendation ? I'm totally lost as the car only has 35k miles on it and bmw apparently serviced it before my free maintenance expired about a year ago. It drives fine I don't feel a difference at all ? Wouldn't have even noticed the brake is a problem if they didn't point it out. |
09-19-2020, 01:42 PM | #2 |
Rep 16,139
A seized caliper wouldn't work at all, so the car would pull seriously to the right when braking. What's more likely is pads that aren't moving freely in the carrier, which will cause excess wear, the result of inadequate lubrication of the pad/carrier interface. Another possibility is that the caliper piston isn't moving freely. Any competent brake shop would have no problem fixing it, but since the caliper has to come off the car to do it you might as well get the front pads replaced while you're at it.
09-19-2020, 02:06 PM | #3 | |
65
Rep 127
In most cars (I haven't driven a BMW long enough to know its patterns), the front pads wear more quickly than the rears. Also, there can be some difference in wear between the two sides. Is this a 1-piston or 4-piston caliper? |
09-19-2020, 02:12 PM | #4 | |
19
Rep 83
09-19-2020, 02:33 PM | #5 | |
Rep 16,139
https://f30.bimmerpost.com/forums/sh....php?t=1471617 |
09-19-2020, 05:35 PM | #6 | |
19
Rep 83
Any reccomendations for non bmw brake pads ? Or are the bmw the best ? Also for brake oil any brands you would use over bmw ? I really appreciate your feedback. Saved me from. Making a 650 dollar investment . |
09-19-2020, 09:18 PM | #7 |
Rep 16,139
Akebono pads are well regarded. Pads aren't oiled, they're lubricated with brake grease. I use Permatex 24125 Ceramic Extreme Brake Parts Lubricant.
