Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > M3 Control Arm Folks, Please Come in...
      10-09-2017, 02:34 PM   #177
vladmury
vladmury's Avatar
Denmark
101
Drives: 325d E90 LCI M-sport
I might have them replaced in the future just to be sure, the shop told me they rarely fail in 6 cylinders diesels
      10-09-2017, 02:49 PM   #178
feuer
feuer's Avatar
Drives: wife crazy!
Just have in mind that new mounts might not fix the issue. It might even make it worse. Vibrations, its frequency, when and where it starts and when and where it ends up are tough to diagnose.
      10-09-2017, 02:52 PM   #179
vladmury
vladmury's Avatar
Denmark
101
Shops in Denmark are a money pit , I am using Schmiedmann and they arent great neither. So instead of waisting money on diagnose attempts , will leave it as it is and change the mounts later. Then will see what else can be, one things is for sure it appears only at idle rpm so its somehow related to engine
      08-01-2018, 02:50 PM   #180
vladmury
vladmury's Avatar
Denmark
101
Has anywone experienced that M3 arms will transmit road vibrations to the chassis? It feels like driving on rumble strips constantly and I replaced driveshaft, wheels, tires, driveaxles, guibo and still not solving the issue.
It comes from the front and the dashboard has high frequency vibration it can be felt also in the floor and pedals. Could it be a faulty M3 arm?
They were inspected and have no play, I dont want to waste more money this car has been a lemon from the start
      08-01-2018, 03:21 PM   #181
6ixSpd
Save the manuals!
6ixSpd's Avatar
6026
Drives: '16 M3, '23 718 Spyder
I've had no such issues with NVH using M3/TRW front control arm kits, nor have I heard anyone complain about that. Seems like your issues is elsewhere.
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      08-01-2018, 03:30 PM   #182
bluewater328
Drives: 2011 bluewater 328i LCI sedan
Did you pre-load the suspension before you tightened the control arm bolts? If you didn't, your control arms now want to press against the road even more (and bearings are prone to fail).
      08-02-2018, 09:55 AM   #183
vladmury
vladmury's Avatar
Denmark
101
Yes, I had them installed at a local garage specialized in BMW. As far as I understood preloading is not necessary for M3 arms.
      08-02-2018, 11:25 AM   #184
FCobra94
Guest
n/a
Drives:
Try again
      01-31-2019, 12:25 AM   #185
hellokitty
hellokitty's Avatar
Drives: '17 M3 ZCP DCT
I just installed the front and rear arms. The front steering is considerably heavier (more difficult to turn the steering wheel). Is this normal? Is there a way to make the steering a tad bit lighter?
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race
      01-31-2019, 07:33 AM   #186
DaFish
DaFish's Avatar
158
Drives: 2014 435iX, FBO
Yes, normal and you get used to it. Added camber is the trade off
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S
      01-31-2019, 10:14 AM   #187
6ixSpd
Save the manuals!
6ixSpd's Avatar
6026
Beef up those weak arms.
chris82827.00
      01-31-2019, 10:26 AM   #188
DaFish
DaFish's Avatar
158
I'm with 6spd here, I'm recommending Wheaties and an anabolic steriod
chris82827.00
      01-31-2019, 12:28 PM   #189
bbnks2
1208
Drives: 135i N55
Did you get the car re-aligned?
      01-31-2019, 08:42 PM   #190
maddmatth
New Zealand
555
Drives: F82 M4, E92 335i
Yes, when I drive a loaner 335i with stock suspension I did notice it felt pretty light in comparison to mine.
But share your alignment specs so we can see if there's anything that might make yours worse than normal, you should get an alignment after replacing them.
      01-31-2019, 10:24 PM   #191
hellokitty
hellokitty's Avatar
Thanks for the responses guys.
I sprayed down my lower steering shaft U joint with WD-40 and topped off the power steering reservoir and that did the trick. Now my steering is only very very slightly heavier than before but much much lighter compared to where I started off with my complaint.
The steering feels "normal" for an e92 now even with the m3 arms.
      02-01-2019, 03:28 PM   #192
FCobra94
Guest
n/a
Drives:
Yup, was just going to suggest this.
