BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > M3 vs Non-M Front Subframe
      09-30-2020, 06:40 PM   #45
The Nightman
Cometh
The Nightman's Avatar
1090
Drives: Boy's Soul
Originally Posted by feuer View Post
Well is a fact. Source is BMW. I wrote that in my original reply to you. Look it up. Do some work. Because as per you recommendation I need to chill.
Just want to clarify that the figures you quoted are for the E46. The same source you used lists the following the the E9x:
E90: 22,500
E93: 15,750
http://youwheel.com/home/2016/06/20/...ehensive-list/
There are no figures for the E92 but journalists reported that the E92 is 25% stiffer than the E90. It is not known how much of the increase in stiffness is due to the chassis itself or the additional bracing BMW added to the E92.
Chassis is stiffer, all 4 vs 2 doors are, due to spacing from pillar to pillar, thus engineers deemed them not needed.
This is possibly true if the E90 and E92 were equipped with the same bracing. I still believe that the E90 does not have the E92 bracing due to cost cutting. MSRP on the E92 was $1700-2700 more than the equivalent E90 model:
https://www.e90post.com/forums/showthread.php?t=78473
feuer4275.50
      09-30-2020, 11:44 PM   #46
ornicar
ornicar's Avatar
136
Drives: 125i
E90: 22,500
E93: 15,750
I have found this excellent document on the cars reinforcement effects.
https://publications.lib.chalmers.se...391/219391.pdf
One of the conclusions is that local lateral stiffness may have more effects on handling steering and ride characteristics than the global torsional rigidity.
" The results presented in Section 4.2 show that the largest factor affecting handling and steering characteristics is lateral stiffness for front and rear, whilst camber stiffness front is shown to be the third largest factor. Global values for torsional and bending stiffness is shown to have a large affect on Primary ride, but very limited affect on handling and steering characteristics in relation to the other factors. "
      09-30-2020, 11:47 PM   #47
ornicar
ornicar's Avatar
136
Drives: 125i
E90: 22,500
E93: 15,750
      04-06-2021, 01:30 PM   #48
CalvinNismo
CalvinNismo's Avatar
53
Drives: BMW 135i Coupé
Originally Posted by ornicar View Post
So you were 100% right @ [Phil325i] (contact: 157271) I did a dry fit, and the M3 brace is bumping into the steering motor in a large area
Photos will follow.
I'm afraid that opening the plate to such a large area will weaken it too much and that in the end it has no interest.
in addition the 2 fixing points at the rear are slightly offset.
Are you satisfied with the 2 bars solution from an NVH reduction point of view?
I may also consider fitting the E88 bars again.
The M reinforcement plate will be for when I mount my M hydraulic rack one day maybe
The brace does in fact fit the 1 Series with a hydraulic rack. It requires 10mm spacers for the front and 20mm spacers for the rear and slotting of the rearmost holes. You cannot however fit the standard undertray with the brace mounted, which would be fine if your car is a track slag. Thanks ornicar for selling me the brace and for the advice! I have ultimately gone for a front only brace though, similar to Biginboca and I can notice the increased stiffness. I may look into a custom/secondary plate for the rear section of the subframe in the future.
I have done a 'how to' on BabyBMW which I am more active on.
How to Fit the E9X M3 Belly Pan to the E8X 1er
Appreciate 3
ornicar136.00
Biginboca3763.50
DLag30103.50
      04-06-2021, 08:47 PM   #49
Biginboca
Biginboca's Avatar
3764
Drives: 2009 E92 328i 6MT
Nice job! Your brace came out great and the write up is perfect. Interesting to me that on the 1 you can use the puck for jacking the car too. On the 3 series we have to remove that plastic puck and instead have to stick with a stupid metal rectangle that gets bent to hell in short order lol
      04-15-2022, 01:36 PM   #50
bimmermech123
55
Drives: 2008 BMW 328i
Originally Posted by Guy Fieri View Post
The "upgrade" is the solid panel that reinforces the subframe:
It won't fit non-M subframes but I replicated it by using the same mounting points for my own bracing. It reinforces the tension strut and wishbone mounts. It was more of an experiment but I couldn't believe the difference it made. Biggest surprise was the reduction in NVH gained from the M3 arms. The factory underbody panel still fits too.
What material did you use for the custom bracing? Aluminum or steel? Also, can you confirm the dimension of the bracing? It looks like 1" wide, 3/4" high, and 1/16" thick.
      05-27-2022, 08:25 AM   #51
e30h26
Drives: E90 335I
I ended up doing this with the original strut braces since I upgraded to the M3 one. Had to shorten them slightly and repaint them after flattening the ends to drill a new hole, but it worked out really well.
Biginboca3763.50
feuer4275.50
      05-27-2022, 06:54 PM   #52
Biginboca
Biginboca's Avatar
3764
Nice work man! Did you notice any difference after? I modded the Aluminum M3 front subframe plate/brace to fit my car and felt a noticeable improvement after installing it:
https://www.e90post.com/forums/showp...&postcount=276
      05-28-2022, 04:08 AM   #53
335i54n
Drives: e90 335i, e39 m5
heres mine, i made the mistake of using 7075 al bar which after the fact I learned is not really weldable or bendable. so I had to use spacers since theres a height difference between front and back of sub-frame.
already have monoballs in front with m3 and other strut bars but these bars added a ton of feedback. not sure if it help handling but any increase feedback on a front strut suspension is appreciated but most dd probably wont like it
Biginboca3763.50
      05-28-2022, 12:27 PM   #54
Shoooter_j
85
Drives: 07 e92 335
Nice, gna have to try this out!
      05-31-2022, 11:50 AM   #55
rbryantaz
Drives: 2007 E70 4.8i, 2008 E90 335i
2008 BMW 335i  [7.67]
2007 BMW X5 4.8i  [10.00]
I fitted the E9x M3 rear subframe brace onto my E90 and it helped the chassis feel much more solid:
Info here: https://www.e90post.com/forums/showp...postcount=4300
Good info.
I did this recently and on my 335i.. I didn't realized that there is a slight interference with the gas tank on the 335i. The gas tank has a "well" (which extends down by about 3/8") that interfered with the rear passenger bar. I thought my bar was bent at first but realized that it is because the 335i has a different gas tank than the M3.
The well is actually visible in your picture. It is probably fine to just tighten up the bar and let the gas tank flex but it is something to be aware of.
I ended up installing 3/8" spacers between the cross brace and the bars so that it didn't flex the gas tank too much. I believe that 1/4" spacers were enough and only lightly flexed the gas tank but 3/8" makes it a non issue.
Name:  m3 subframe brace spaced pass on 335i.jpg
Name:  M3 subframe brace spacers.jpg
Given that it is a simple spacer and longer bolts I think it is worth adding for a 335i. As a side benefit it also allows the original bolts to be installed in the outside holes so that they are plugged.
-Rich
2007 E70 X5 4.8i with 10" android screen Running 265/60/18 AT34s All Terrains (Mainly for road trips)
2008 E90 335i with 10" android screen, 7" intercooler, inlets, Dinan intake, JB4 BEF, E85 conversion, Mfactory LSD, M3 suspension, EDC shocks with custom controller.
      05-31-2022, 04:59 PM   #56
335i54n
the e84/e92 x brace is a better fit/design imo, the m3 brace is like that to clear the resonators on v8. e92 brace fits, no issues
      05-31-2022, 05:12 PM   #57
rbryantaz
Yes the e92 brace does fit without any changes.
It is described well here: https://www.e90post.com/forums/showthread.php?t=165246
I have to think about the single bolt point on the rear of the e92 bars where they bolt to the subframe attachment. That seems like it could pivot slightly where the M3 version is one piece in the back so it won't pivot. I know there is much debate about this with front strut bars... Can this have the same issue?
-Rich
      05-31-2022, 05:20 PM   #58
335i54n
not really, both bars are weld to the center plate and the way the bar are setup it make more sense as braces, the e92 way. the m3 way is only cause they could Not route the bars the same way due to the resonator. part of me wishes i too went m3 brace to match and maybe will need extra room for exhaust
      06-03-2022, 03:02 AM   #59
autoart
347
Drives: 2009 335i e90 M/ 22 X3
The M3 version looks to be made out of larger/ thicker metal also. The previous post also says that the M3 version has different designs for the e92/e93/e90. Maybe you were sold the wrong one, just a thought. So is this even a worthwhile mod in your opinion?
      06-03-2022, 05:40 PM   #60
rbryantaz
I haven't driven it much after putting it on and sadly haven't had time to take it out to throw it around corners.
It seems a little thicker. I think the only place it "could" be really better than the e92 version is that the e92 version just has a single bolt hole on the rear as I mentioned. There probably isn't enough movement in the body to allow that to pivot but it is more likely to pivot than the M3 version is because it is welded in the rear (rather than front) and the front is a 2 bolt point connection.
e92 picture from ecs:
This is probably not a significant difference and the spacers are a disadvantage. There are however usually more used M3 braces around so they are often cheaper used. I think I only gave $100 for mine.
Note there is also another ear brace that goes in the rear of the e93:
https://www.realoem.com/bmw/enUS/sho...88#51618045988
I have one but didn't realize that I needed to add mounting points to the body of the car that are only really reachable when the rear subframe is out so I haven't installed it.
-Rich
      07-02-2022, 04:07 PM   #61
tylerhart_21
tylerhart_21's Avatar
Drives: 2008 Bmw 328i Coupe
2008 Bmw 328i  [0.00]
I have a small question. Would using similar hardware to the m3 strut tower brace be better or similar to using rivnuts. Marked in red.
      07-03-2022, 11:46 AM   #62
335i54n
you mean a nut and bolt through the subframe? nope, rivnut imo is best and easiest way
      04-21-2024, 11:09 AM   #63
Simbl
Simbl's Avatar
50
Drives: E92 330i
I know this is an old post but I have just found a company manufacturing steel undertray or what they call sump guards. They bolt into the front subframe were some of us have put in brace bars, it’s via a bracket so not sure how much bracing it would actually do.
https://www.sump-guard.co.uk/steel-s...0-91-2004-2011
      04-22-2024, 03:46 AM   #64
Phil325i
Phil325i's Avatar
623
Drives: E92 325i MSport Coupe
It looked good until I realised that there's no access to the sump plug, so you'd have to remove it every time you do an oil change!
