BMW M3 Forum (E90 E92)
Mporium BMW
      08-02-2013, 01:09 PM   #23
W///
W///'s Avatar
7490
Drives: F82GTS, E36/E92M3, Z4M
Originally Posted by aussiem3 View Post
Thank you.
I was planning on running square ZCP with 265/275, and Swift springs. Wasn't expecting any rub.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
      08-02-2013, 03:34 PM   #24
E90M3velocity
Philippines
338
Drives: Manual-Slicktop E90 M3
What specs are you running for the apex wheels?
      08-03-2013, 12:37 AM   #25
S65V8
*_*
Drives: ...
18x10s ET25 square set-up on kook RS-3s (275/35/18)
      08-03-2013, 02:11 PM   #26
E90M3velocity
Philippines
338
Cool, so rubbing im guessing?
      08-03-2013, 02:17 PM   #27
S65V8
*_*
Drives: ...
None at all, 18s too small. Plus, I don't throw on spacers since APEX are strictly track wheels for me. Even when I had BBS CH 19x10s, it didn't rub.
      08-03-2013, 02:19 PM   #28
E90M3velocity
Philippines
338
Cool thanks, car looks good btw
      08-06-2013, 12:19 AM   #29
crazydrummer
crazydrummer's Avatar
83
Drives: 335i 08
So who should I order these from?
      08-06-2013, 06:07 AM   #30
SpiralOut
SpiralOut's Avatar
Drives: 2022 X5Mc
Hey SROC5, you run the stock front bump stop or the one from the e36 m3?
      08-06-2013, 10:24 AM   #31
S65V8
*_*
Drives: ...
e36 m3 bump stop, to help with travel. come to think of it, the car hasn't bottomed yet (knock knock). Although I did hear these springs were tuned with the stock ones in place.
      08-06-2013, 10:25 AM   #32
SpiralOut
SpiralOut's Avatar
Drives: 2022 X5Mc
10-4. Thanks man.
      08-06-2013, 10:26 AM   #33
W///
W///'s Avatar
7490
The 2 vendors I asked said it wasn't necessary as they are supposed to work with everything else stock. I'm still going back and forth. Kind of like, well you're in there, might as well?
Current:
      08-06-2013, 10:30 AM   #34
SpiralOut
SpiralOut's Avatar
Drives: 2022 X5Mc
Same here. I have no real beef with the OEM suspension. So i'm really wondering if i should even muck with it. I was mainly wanting the slight drop and thought the stiffer springs would do better on track.... plus the extra camber you get from this would be a bonus. I would just hate to mess up the nice balance it has from the factory.
      08-06-2013, 01:48 PM   #35
S65V8
*_*
Drives: ...
Yep, I agree. It isn't necessary. I did it because it makes sense to me re: trying to keep as much travel as possible.
Don't mess with it if it doesn't bother you. It eventually bothered me on the track, hence the switch.
      08-06-2013, 03:19 PM   #36
E90M3velocity
Philippines
338
Do you have a zcp car? Just curious if these springs were tuned for zcp shocks which are tuned differently (from what i read) or the regular shocks
      08-06-2013, 07:45 PM   #37
S65V8
*_*
Drives: ...
ZCP car. Call Swift, they'd know.
      08-07-2013, 08:00 AM   #38
anselmw
Drives: 2001 M Coupe
Thanks for the great review. Only question for me is the same as other non zcp, will this work just as good. I might have to be the test case for it.
2011 M3 Sedan
2001 M Coupe
2020 Macan Turbo
2018 GT3
      08-07-2013, 08:08 AM   #39
SpiralOut
SpiralOut's Avatar
Drives: 2022 X5Mc
Another Q SROC5, What was your max front camber settings before the spring install? Just looking to see how much more you get just from the spring install.
      08-07-2013, 01:50 PM   #40
S65V8
*_*
Drives: ...
Yes, the only real difference re: EDC struts for ZCP and Non-ZCP is "Sport EDC" is 'dynamic' , like "Normal" and "Comfort" were to begin with.
-1 (F). I ended up with -1.9 with the spring install and suspension front pins pulled. Even that small amount of camber helped reduce shoulder wear on the track vs. before.
      08-14-2013, 01:51 AM   #41
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Yes, that is correct. Swift designed these springs around the OE bump stops, with proper linear rates and height there is no bottoming issues, including several of our customer who track their M3's at very bumpy tracks.
Most of the reports of bottoming were from progressive and often too much drop Eibach or H&R springs.
      08-14-2013, 10:08 AM   #42
SpiralOut
SpiralOut's Avatar
Drives: 2022 X5Mc
I ordered mine and included the e36 M3 bumpstops just cause it seems to make sense that you would need them. From what people say, there is actually very little travel in the stock front suspension before it hits the stock bumpstops. So with these springs wouldn't you basically be riding directly on bump stops if you kept the original ones or am I wrong there?
I just wonder what the pros and cons are of using these springs with the e36 M3 bumpstops versus the stock ones? Mostly for DD use, but i do go to the track like 8-10 times per year.
Are the e36 M3 bumpstops progressive like the e92 M3 ones? And how much shorter are the e36 M3 bumpstops vs the stock ones?
      08-14-2013, 11:05 AM   #43
S65V8
*_*
Drives: ...
e36 bumpstops are not progressive.
      09-05-2013, 12:40 PM   #44
JPH704
JPH704's Avatar
Drives: Huracan Performante & 720s
Just ordered these
After cross-reference reviews for these and the B&G, sounds like the swift springs have the edge. My previous car had Top Secret Aragosta coilovers. Those coilovers came with swift springs and I loved them! On a budget now... Hopefully these can do the job until I can get my real coilovers.
2019 McLaren 720s / 2018 Lamborghini Huracan Performante / 2019 Porsche Macan Turbo / 2016 BMW M3/// IG @jon.hagerty
spec-r, springs, suspension, swift, track
m3post
