BMW M3 Forum (E90 E92)
      09-05-2013, 01:53 PM   #45
MasterP
721
Drives: All the M's
I'm under the understanding that These Swift Spec R springs were made to use the Original E92 Bumpstops?
      09-05-2013, 02:34 PM   #46
lsmkr01
lsmkr01's Avatar
Drives: E92 M3
They are.... READ POST #41
      09-05-2013, 05:41 PM   #47
MasterP
721
Drives: All the M's
Thanks. I was hoping someone other than a vendor would confirm it. Looks like most people are still putting Other Bumpstops in. I just bought these springs and we're putting them in now - so I hope they're right!
      09-05-2013, 08:13 PM   #48
Denk
Denk's Avatar
1006
Drives: 2021 X5M
You'll be riding on the bumpstops, not a good thing. Depending on how you drive, you may not notice it. From my experience with lowering springs compared to the wonderful stock suspension, if you cut down your travel, you lose grip and anything over rough pavement is unsettling. It's best to retain oem travel, it'll give you more grip and a better overall ride...hard cornering and power down grip wasn't as good as stock. Keep in mind, BMW designed a great all around suspension, the stock dampers/springs are a beautiful match. Lowering springs change the character of that match. It'll be firmer and initially sharper on turn in but there's more to it than that.
      09-05-2013, 11:31 PM   #49
MasterP
721
Drives: All the M's
My observation has been the car exhibits increased body roll when you increase mechanical grip from wider tires/stickier tires.
I agree in general the M3s suspension is fine.
I finished the installation earlier tonight. It needs to be aligned, but so far the car rides like stock. It may be modestly firmer but I honestly can't tell right now.
      09-06-2013, 12:14 PM   #50
pkimM3r
pkimM3r's Avatar
205
Drives: m3 saloon in granny mode.
do these really benefit an otherwise stock suspension? Never thought sleeves or springs did anything to gain performance (if anything hinders it).
      09-06-2013, 12:24 PM   #51
SpiralOut
SpiralOut's Avatar
Drives: 2022 X5Mc
I installed mine and used e36 m3 bumpstops. Also shaved down guide supports about .2". Still think i need to shave a bit more to get it back to factory travel amount for best ride. I do bottom but only on big bumps or dips. Go to track tomorrow so will see how it does there.
      09-06-2013, 01:32 PM   #52
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Yes, that is correct.
      09-06-2013, 02:00 PM   #53
W///
W///'s Avatar
7494
Drives: F82GTS, E36/E92M3, Z4M
About to install mine on Saturday, with e36 bumpstops. Figured since i was there, might as well...
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
      09-25-2013, 02:51 AM   #54
jin.patrick
jin.patrick's Avatar
33
Drives: F80 M3
Getting mine installed today!!! I can't wait!
Current: 2016 F80 M3 (DCT) Black Sapphire Metallic
Past: 2015 F82 M4 (6MT) Austin Yellow
Past: 2010 E92 M3 (DCT) Silverstone II Metallic
Past: 2008 E90 M3 (6MT) Sparkling Graphite Metallic
      10-01-2013, 05:49 AM   #55
S65V8
*_*
Drives: ...
Awesome, hope the review helped that out Post picts and your thoughts on how accurate my review was in your opinion.
      10-04-2013, 07:49 PM   #56
///Lyubm
///Lyubm's Avatar
45
Drives: 2011 m3
So after reading all of the post its still unclear to me if there is any benefit to using e36 bumpstops with these since it was designed for oem bumpstops?
      10-05-2013, 05:03 AM   #57
S65V8
*_*
Drives: ...
The only way you can answer this for yourself is to call Swift USA and ask them. That's what I did, and I determined my own preference would be to change the stops to increase travel that I'm losing by lowering the car.
      10-06-2013, 08:42 PM   #58
JuzMe
JuzMe's Avatar
25
Drives: BMW X4; E92 M3
Did anyone manage to get answer from Swift whether E36 bumpstops required?
      10-06-2013, 09:16 PM   #59
swifty
314
Drives: F80, Levante & Tesla 100D
Which bumpstops did you go with. Both front and back? I'm planning on putting eibachs and are they lower than these swifts? Car hasn't come in yet but want to do it all in one step.
Current Bimmer: '16 F80 M3, '20 F87 M2c
Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40
Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335
      10-06-2013, 09:24 PM   #60
HP Autosport
Drives: F80 M3
No, E36 bump stops aren't required. Swifts designed these springs with proper rates, NOT progressive rate that are too soft for a lowered ride height(reduced bump travel).
      10-06-2013, 10:29 PM   #61
///Lyubm
///Lyubm's Avatar
45
Drives: 2011 m3
Thanks! not required, but will it help increase travel further or it would make no difference?
      10-07-2013, 02:02 AM   #62
HP Autosport
Drives: F80 M3
Anytime you use a shorter bump stop you are increasing compression travel, but it's highly unlikely you will need the additional travel.
      10-07-2013, 06:06 AM   #63
S65V8
*_*
Drives: ...
Eibachs are not lower than Swifts. I used E36 bumpstops in the front, rears you don't need to touch. I recommend you call up Harold @ HP Autosport as well, I think you should really consider Swifts vs. Eibachs. Eibach drop is basically the same height as the Competition Package.
      10-07-2013, 07:12 AM   #64
W///
W///'s Avatar
7494
+1. I went with E36 bump stop anyway (only an extra $40), figured while I was in there, might as well.
Really happy with the ride height.
Current:
      10-07-2013, 07:57 AM   #65
JuzMe
JuzMe's Avatar
25
That looks great!
      10-07-2013, 08:47 AM   #66
SpiralOut
SpiralOut's Avatar
Drives: 2022 X5Mc
My opinion is yes, go with the e36 M3 bumpstops. Even though they say they are not required, I went with e36 bumpstops and shaved my guide supports down about .2". The ride is very good and handling at the track is greatly improved. If I could go back I would shave about another .2 to .3" from the guide supports to just to give me a little more travel (currently i only have about .2" of travel up front versus the .5" they have with stock ZCP setup). Only 2 issues I have now are some occasional bottoming out over large bumps or big dips in the road and car does get slightly unsettled when hitting mid-corner bumps due to the fact that it's leaning hard on the front bumpstops when you're really pushing it. My local track is smooth so i had no issues there.... mainly just notice this on the road... off ramps, etc.
Just my 2 cents. I'm very happy with the Swift Springs though. Great product if you want to improve handling while keeping EDC.
spec-r, springs, suspension, swift, track
m3post
