06-03-2014, 09:03 PM | #353 | |
177
Rep 2,301
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
06-04-2014, 12:35 AM | #354 | ||||
Rep 1,947
Now back on topic. I've looked at that pressure data, and it doesn't look quite right to me. You'll notice I rarely trust another person's work because I don't know if they use as many safeguards as I do. I know when I data log something, I don't just put up a few numbers on the screen and expect everybody to trust it as the gospel (like it sounds like you've done here). I usually do what my friends call "the data storm" -- dumping so much data that you simply can't refute it. There's a car in my area who just installed a data logging pressure sensor. I'm hoping that we'll have time to dump the data or figure out how to log it during a track session. I'll trust my data. |
06-04-2014, 12:52 AM | #355 |
24
Rep 159
Regular Guy and Kawasaki00 - let me know what you find on your pressure numbers so I can compare. I ran my pressure sender on a Macht Schnell oil pressure fitting to a braided line that is about 2 feet long which ends at the pressure sensor. The pressure looks to be in spec, but I'm relying on the gauge so I'm sure data logging would be far more accurate. Are any of you seeing the pressure dip slightly when blipping the throttle or do I have something else to worry about?
Thanks to both of you for all of the information in the thread and a big thanks to EAS for sharing information that can help people make informed decisions irrespective of what side of the oil debate anyone is on. |
06-04-2014, 01:52 AM | #356 | |
Rep 4,381
Your oil pressure readings are quite interesting, (assuming IUC) if the max oil pressure is only reached when the 10W60 is cold it infers that its flow rate at normal operating temp will be the same as the flow rate for a 0W40 at least up to 6k rpm....it being a volume flow regulated oil pump with a pressure relief valve (set at around 95psi?). |
06-11-2014, 10:48 AM | #358 |
Î canŧ főcus mŷ attėntĭon
72
Rep 1,406
Forgive me if it's already been discussed, but what kind of job is replacing the rod bearings with the VAC ones? I may be picking up a 2008 M3 and would rather be safe then sorry. Any DIYs on the boards?
2011 M3 Coupe - Individual Fire Orange/Black Novillo Extended Leather, 6MT, Mode Carbon, Eisenmann Race, BBS CH-R, BC Coil-overs (Sold)
1995 M3 Coupe - Avus/Hurricane, AEM EMS, Precision Turbo, Boostlogic, H&R, Fikse FM/5, MaxVelocity, Maximum PSI, 20% Tint, etc etc..(Sold) 2009 M3 Coupe - AW/Fox Red, 6MT, Carbon Roof, Shadow Trim, etc (Sold) |
06-11-2014, 03:22 PM | #359 |
Rep 1,381
Not sure if anyone did a DIY for the M3. But there was a DIY for the E60 M5 which is a very similar car. You would have to remove the entire subframe and steering rack to be able to remove the oil pan. It's quite a detailed and complex job.
06-11-2014, 04:46 PM | #360 |
8182
Rep 18,821
Drives: BMW
There's no need to completely remove the subframe, it can be tilted to lower the pan out.
06-11-2014, 07:23 PM | #361 |
Rep 1,947
06-12-2014, 12:31 AM | #362 |
Rep 1,381
06-12-2014, 11:42 AM | #363 | |
8182
Rep 18,821
Drives: BMW
Others shops may follow their own route.
07-25-2014, 04:15 AM | #364 |
60
Rep 198
So I had the unfortunate luck of running over a rock on the fwy a few weeks ago.
Long story short, I had the car towed to my dealer and insurance picked up the tab. Damage from the rock resulted in broken underbody panels, left rear control arm, a dent to my Akra Evo, and most importantly, a hole in my oil pan! My car is a 08 and had just a few clicks above 69k when the insident happened. I talked to my SA and inquired about the cost of doing rod bearing inspection/replacement, since the front subframe and pan would already be removed. The cost of 4 hours labor plus parts seemed worthwhile to me so i went ahead and had them done. I want to remind everyone that my car never exhibited any issues relating to the motor and performed flawlessly for 69k on 10w-60. I had 1 UOA done 7k miles ago and it showed very low copper levels. Dont mind the scratches on the lower bearings, they are from being in a plastic bag loose. A few mentionable notes from the master tech who did the work. -The amount of wear on my old bearings is "normal" and "with in spec". -Old bearings were measured using a micrometer and showed uniform wear. Good thing. -New 702/703 were plastigauged and verified to be "with in spec". -Crank had no marks or signs of scoring. -Tech says to stick to 10w-60. -Says bearing wear is normal on high rpm motors. "Either the bearings go or the crank does, guess which is more expensive?' Some other interesting things he mentioned. -Every S65 he has seen has had some sort of wear to the bearings. Some obviously worst then others, but just the "nature of the beast" were his words. -In the 10 years he has been a tech at this dealer he had only seen 2 blown S65 motors and they were both found to be due to user error (miss shift, over rev). States the S65 is one of the most reliable motors he works on. -He swears by using the recommended 10w-60, he told me a funny story that one of the newer techs went out to do a top off on a F80 M3 and had 10w-60 in his hand My tech stopped him before and asked him if he was sure that was the right oil? New tech responds with "yeah! its an M3 right?" My tech kindly asked him to go back into the shop and search the system for correct oil for F80... -Specifically stated that following BMW 15k service intervals is not recommended. Oil changes every 5k for street use and 3k if including track time. -Motors that rev this high are not meant to last 200k. His opinion is if you get 100k of street and track miles, you got your moneys worth. Bearing maintenance is something he says BMW should add to their inspection 3 So I got my car back a couple days ago and everything seems just as fine as before. I asked my SA if there was any break in period. He replied, No. No reduced revs, no early oil change. Just drive it he says. So I did! On the way home after getting her up to temp, a guy in a 1 series ahead of me is about to exit but sticks his hand out waving me by. I come up to pass him and he has a thumbs up hanging out the window So I quickly grabbed 5th, "WHAAP!" followed by 4th, "WHHRAAAAAAPP!" Perfect buttery smooth downshifts on my first attempt after not driving her for 2 weeks (that pretty much never happens I usually make a couple jerky downshifts before my timing gets up to speed) In any case it feels great to be back behind the wheel of this motor again. Now I have some peace of mind for the next 60k I hope. Although the dealer says no break in period is neccessary, I was thinking of having an oil change done after 1k just to get rid of any new metals from the fresh bearings. Thoughts on this? My personal opinion on this "bearing problem" is mainly unchanged. Yes the S65 has bearing wear. As does the S85, S54, S14, and S38. This is nothing new to people who have been around M cars for years. Its a high maintenance motor. Learn to live with it. As others have mentioned all manufactures have their issues (Ford 5.0L, AMG 6.2, LSX, P-cars). Understanding what your brands issue is and maintaining the car around that is key for longevity. I will continue to use 10w-60 unless another oil is recommended by BMW. I still believe these blown motors we are seeing are factory defects from tolerance stack up when mass producing engines. I can agree that my bearings dont look "good" after 69k. I can also live with the fact that this motor will need fresh bearings every 60k, CODB- CostOfDoingBusiness in my book. Shafique
*1996 S54 E36 M3* •2017 F87 M2•
Sold: 07' e90 335i, 08' e92 M3 |
07-25-2014, 07:26 AM | #365 |
274
Rep 2,664
Drives: Goggomobil
Sorry for my ignorance Could someone tell me how a bearing wear will contribute to a bearing failure when through the wear the clearance between the crank and the bearing is increasing.
Is the failure the result of hammering due to the increased clearance thus dislodging the shells from the rods and forcing a misalignment?
F86 X6///
07-25-2014, 07:32 AM | #366 |
274
Rep 2,664
Drives: Goggomobil
F86 X6///
07-25-2014, 10:31 AM | #367 | |
60
Rep 198
Also forgot to mention the bearings are in no particular order, they are random and I just put the ones that looked alike together for pictures. Sorry for lack of clarity, however fact is bearings shows wear.
07-25-2014, 10:39 AM | #368 | |
60
Rep 198
The issues we discuss arising from more clearance, weather they are from resized bearings or worn bearings, can still have worst affects rather then better. Crank walk is one that comes to mind if you have too much clearance or not enough oil flow. http://www.jackstransmissions.com/pages/crank-walk
07-25-2014, 04:35 PM | #369 | |
274
Rep 2,664
Drives: Goggomobil
F86 X6///
07-25-2014, 04:51 PM | #370 |
Rep 1,246
Drives: E92 M3
Of the journals are fucking contacting the bearings then it's not "by design" Lol.
Full dumbass. |
07-25-2014, 06:37 PM | #371 |
Bad Lieutenant
232
Rep 3,517
LOL @ "No Dumping"
Glad you got it taken care of ... did your tech have any say over the newer bearings, as opposed to the older lead bearings he removed?
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
07-25-2014, 06:45 PM | #372 | |
60
Rep 198
Tech didn't say anything regarding the different materials of old vs new bearings. All he said was that there is only one part number for these (702/703) bearings and I/we already know that thanks to this forum. He did say its BMW procedure to plastigauge the newly installed bearings to verify clearances are with in spec. Not sure what their protocol would be if they found that clearances are too tight once new bearings are installed.
07-28-2014, 03:44 PM | #373 | |
Rep 7,297
Maybe Kawasaki can chime in? That doesn't sound correct to me but I could be wrong. |
eas, journal, oil, rod bearings |
