BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Apple CarPlay Retrofit - Done! (Update:16/11/18...now also with full screen function)
Studio RSR
      02-26-2018, 02:16 PM   #67
Ian83w
61
Drives: F32 440i lci
Originally Posted by R99 View Post
Works with NBT EVO ID5 or ID6
Do u remember if your WiFi antenna was burgundy and were it was placed behind the head unit thanks ian
      02-26-2018, 02:26 PM   #68
R99
1099
Drives: 2016 330d F31 Touring
@wibbles
      02-26-2018, 02:39 PM   #69
Ian83w
61
@wibbles
Yeah Craig I’ve spoken to him a few times over on babybmw he’s a top fella cheers shall have a word with him. Thanks Ian
      02-26-2018, 02:47 PM   #70
R99
1099
I’ve told him to look at the thread!
      02-26-2018, 02:47 PM   #71
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
The connector is a burgundy colour - "Wi-Fi" is actually stamped into the metal of the EVO unit under the connector.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube
      02-26-2018, 02:58 PM   #72
Ian83w
61
Sound cheers Craig were do u mount the antenna just in void behind the hu or is there a specific place if u don’t mind telling me that is thanks ian
      02-27-2018, 12:13 AM   #73
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Sound cheers Craig were do u mount the antenna just in void behind the hu or is there a specific place if u donÂ’t mind telling me that is thanks ian
usually I thread the antenna out into the passenger footwell then back up into the centre console near the idrive controller
      02-27-2018, 11:14 AM   #74
Ian83w
61
Ok thanks mate appreciate it 👍
      03-01-2018, 05:48 AM   #75
simnew
106
Drives: 2018 440i GranCoupe MSport
If you specify CarPlay on a new car, does it have that antenna for the head unit added already ?
Originally I was going to add it to my car at a later date from the connected drive store but it sounds like there could be a risk that because I haven’t specified enhanced Bluetooth that I may not gets the antenna.
      03-01-2018, 11:04 AM   #76
vp
59
Drives: MY18 430GC
If you order without CarPlay then it will not have the antenna. Retrofit ends up being more expensive and a pain than ordering it with 6CP
      03-01-2018, 11:12 AM   #77
Ian83w
61
I thought it wouldn’t work out more expensive as the antenna isn’t much and easy to install. Then just a matter of abit of coding and a fsc code required. if anything I thought it would be cheaper. Unless I’m missing something.
      03-01-2018, 11:13 AM   #78
vp
59
Drives: MY18 430GC
I thought it wouldnÂ’t work out more expensive as the antenna isnÂ’t much and easy to install. Then just a matter of abit of coding and a fsc code required. if anything I thought it would be cheaper. Unless IÂ’m missing something.
FSC codes cost as much as ordering it during build.
      03-01-2018, 11:25 AM   #79
R99
1099
FSC codes are around £100 via eBay. Antenna is under £20.
Then you need to pay for Coding.
      03-04-2018, 04:41 AM   #80
Brobbo
70
Drives: G20 320D Msport
So I’m going to get the codes from the guy on the bay. So before I load the custom FSC CODES is there a way of backing up my existing fsc pack?
      03-31-2018, 10:32 PM   #81
DocBlackhawk
3 Time Iraq and Afghanistan Vet
DocBlackhawk's Avatar
Drives: 2017 340i xDrive
I was previously unable to purchase CarPlay. Picked it up from connected drive today when I noticed it had populated as an option (Bought car July 2017, Manufactured Sep 16). It runs horribly slow. Figure it might benefit from the antenna. Anyone else find it slow without the antenna or is this how CarPlay always behaves?
      04-01-2018, 01:26 AM   #82
vorphlack
Drives: f30
Normally I create required FSC without touching existing codes from factory.
      04-01-2018, 01:03 PM   #83
Wagstafari
Wagstafari's Avatar
132
Drives: 2014 BMW F30 335d Xdrive
Hi All,
Very keen on this too.
Can anyone confirm where ID6 software can be obtained? And if anyone has upgraded them selves?
Currently running ID5 in my 2017 F36 with NBT EVO.
Wanna enable Android screen mirroring but also car play for the wife's iPhone.
I know Simon from Bavarian is the man to go to locally, and I prob will, but just curious on the above regardless.
Cheers.
Wag
F36 440i GC with a lot of bling
Sold - 2014 F30 335d xDrive M Sport / Alpine White / MPerformance Rear Spoiler / MPerformance Black Grills / Adaptive Suspension / M Sport Breaking / Reversing Camera / Folding Auto Dipping Mirrors / Sun Protection Glass / Adaptive Headlights / 19" M 442M Alloys / Pro Nav Media Package / Sunroof / Heated Memory Dakotas / High Gloss Interior Trim / High Gloss Shadowline / Xenons /
      04-03-2018, 06:47 AM   #84
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Carplay will be laggy without the antenna.
      04-05-2018, 05:23 PM   #85
DocBlackhawk
Thanks. Got the cable in and it runs flawlessly.
Wibbles444.50
      04-08-2018, 03:32 AM   #86
wayneallwine
Drives: 320d M Sports Edition Shadow
Hi , I have just installed CarPlay retrofit on my F30 (ALPINE Headunit) .
I need WiFi antenna (Repair lead, WLAN cable aerial Part number: 61119372321) to make my CarPlay usable.
I am going to buy this genuine parts, and try to find someone to install on my F30.
I understand HeadUnit rear connector (#8) is for WiFi antenna. And it should be routed to the passenger footwell and goes back to head unit position?
I would need to understand it with some picture or drawings...
Would you help?
      04-08-2018, 12:26 PM   #87
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Would you help?
There is no need to route into the footwell, route it into the centre console under the idrive controller.
      04-08-2018, 12:27 PM   #88
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Originally Posted by Wagstafari View Post
Hi All,
Cheers.
Wag
ID6 is just a coding option, no doubt Simon/Vorphlack can tell you that.
