BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - NBT Retrofit - E92
      03-26-2019, 04:50 PM   #45
niksss
10
Drives: 2016 BMW F10 535i
Thanks mashman ! I have another question. How can i secure the nbt with screws ? The mounting points dont match ! I also cant install the faceplate because the metal pins that attach to the console are blocked by the nbt frame. How did you guys do it ?
EDIT: I have just put it in without screws. I don't know if it is ok. Also is it normal for the NBT to never actually power completely off. In the morning my NBT was instantly on (there was no boot animation) ? Doesn't that mean that the car doesn't go to sleep and that I will have battery drain issues ?
      03-27-2019, 04:44 PM   #46
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Yes mine is on constantly.... has been in for two years now and never fully flattens the battery. I drive mine every other day so gets a regular charge, so will depend on how much use your car gets
      03-29-2019, 07:43 AM   #47
niksss
10
After some research I found out that NBT starts booting up as soon as you press the unlock button on your car. If I stay close do the door, unlock the car , enter the car fast and immediately after that insert the key, I see the boot animation. Maybe that is the case with you also or maybe it depends on the emulator.
Another question that I have is has anybody tried to enable BMW Live (Internet, Weather etc...) with Bluetooth internet ? I have coded this:
3003 > DUN_PROFILE - aktiv
3003 > PAN_PROFILE - aktiv
3003 > ONLINE_BROWSER - beide_aktiv
3003 > ONLINE_SERVICES - nicht_aktiv
3003 > ONLINE_SERVICES_GLS - nicht_aktiv
3003 > ASSIST - nicht_aktiv
3003 > ONLINE_BROWSER_LIVE - aktiv
3003 > DATACOMM_CSIM - nicht_aktiv
But nothing shows up. I have only Mobile Care, Hotline and Your Service, which show up a phone number when I press them. I read that I have to code some VO, but I doubt I can code VO on a retrofitted NBT car.
      07-29-2020, 07:39 AM   #48
Alexvier
Alexvier's Avatar
35
Drives: Crimson Red 325i M sport
Thumbs up
Great I'm keeping this, detailed step by step tutorial. Awesome.
Ultimate Driving Experience........
Socket4542.00
      12-20-2020, 12:47 AM   #49
Yonyx
Drives: BMW 330i
well, after 3 years my retrofitted head unit started playing up: doesn't talk to iDrive, stuck in one position, no audio signals, etc. The screen is functional, the iDrive is still good too. So I am thinking about replacing just the head unit with the emulator (Evo version maybe?). Any leads in Australia? I am aware of Canadian and Romanian options. Was hoping for a closer option, ideally with installation.
      12-20-2020, 08:51 PM   #50
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
You can buy the NBT headunit on ebay
The emulator needed to run the NBT on the E series comes from either the Canadian or Romanian vendors you mention above
You need the emulator for the NBT HU model you pick (ie standard NBT emulator wont work with a EVO NBT HU)
If you already have the emulator then replace your NBT HU with the same model, unless you are happy to buy a new emulator for $700+
Hope this helps
      12-24-2020, 04:32 AM   #51
Yonyx
Drives: BMW 330i
I was under the impression that the head unit has to be coded to my car VIN number. Or is it emulator only?
      12-25-2020, 05:49 AM   #52
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Not sure tbh. I am certain the emulator from Romania does not. The emulator from Canada on the other hand needs to be registered and activated by the seller. I think they use your vin to do this
      02-13-2021, 11:48 AM   #53
InnerBlueSkies
InnerBlueSkies's Avatar
1093
Drives: 2008 E90 M3
Great DIY and contribution. With the right tools and "know-how" anything is possible.
      02-13-2021, 10:59 PM   #54
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Thanks mate.... so true.... and for everything we don't know, we have google hahhahah
      02-26-2023, 03:16 AM   #55
GnomeChild
IN54NE
GnomeChild's Avatar
324
Drives: e90 335i LCI M-Sport
2010 BMW 335i  [0.00]
How do NBT guys like the upgrade? I have factory CIC, would it be worth it for me to retrofit NBT? Really the only functionality I'm missing is Bluetooth Audio and I have a combox sitting for the retrofit. CIC + combox should have the basic functionality of NBT, correct? Plus I somewhat prefer the UI of CIC... Although I wouldn't mind the updated LCD of the NBT. I also prefer the bulky NBT controller but don't like that I have to file my trim... Decisions decisions
How about any issues with updating Navigation Maps? I am currently having issues updating CIC maps but I believe that to be a firmware issue (and should be resolved with an I-Level update). Any complications getting new map data loaded through the emulator? Does the glovebox/armrest USB still function?
      03-02-2023, 02:47 AM   #56
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
NBT is def worth the upgrade over CIC for both looks and functionality. You can find up to date nav maps and USB can be made to work.
      03-02-2023, 05:45 PM   #57
Luxury
Luxury's Avatar
Drives: A4 1.8TQM, 135is DCT
I want to do this on my e82 with CIC. I want genuine remote start, which doesn't come in iDrive 6 or the ConnectedDrive Store, yet. Car play is a nice addition! For me its about figuring out how to do both the head unit and upgrade my 2G chip. If I can have 5G, I will.
2013 BMW 135is Coupe | Dinan Stage 3 | M3 Subframe Bushings | Dinan Monoball Joints | Dinan Toe Links | 1M Strut Bar | MPSS - BMW 313M's 18x7.5 / 18x8.5 | Min Grey, Savanna | Prem, Tech | DCT | #341/586
      05-11-2023, 02:26 AM   #58
scroller
16
Drives: 335i
Can someone suggest website for shipping to EU for emulator for the NBT EVO E90 series. I have found this people doing that would you recommend them?
https://carsystems.com.ua/product/ex...rofit-adapter/
      05-11-2023, 10:23 AM   #59
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
Ive never heard of these people sorry. Cant vouch for them either way
      05-13-2023, 08:00 AM   #60
scroller
16
Drives: 335i
Can you then suggest website that are providing the retrofit kit but with shipping to EU or you can give the website from where you buy then and I ask them, did they ship to EU.
      01-25-2024, 06:47 AM   #61
LOLMEE
Drives: E82
All good but how did you remove and place the cic front panel
      03-22-2024, 03:23 AM   #62
scroller
16
Drives: 335i
Hello, i have individual audio system, rear camera from E70, bluetooth after replacing the CIC to NBT unit, did you need to replace other modules to work like bluetooth, amplifier and the module for the rear camera to work? Because I have acquaintances who say that after this retrofit I will also have to change the parts I mentioned.
      03-24-2024, 02:39 AM   #63
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
No I didn't replace any of those modules in my 2008 E92 but that doesn't mean you wont need to
      03-24-2024, 02:40 AM   #64
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
It is held in with two friction pins and simply pulls out
