E93 Roof Rattle fix?
12-07-2016, 05:50 PM | #1 |
Rep 3,035
Drives: BMW/MERCEDES/PORSCHE
I've been getting a slight rattle on my e93, i've done some searching and it seems like a lot of people have this issue and some have fixed it by "lubing" the seals but nobody explains what that means exactly.
Can anyone explain to me what exactly "lubing the seals" means?! or if anyone has any insight on a good fix for this roof rattle please share! Thank you,
BMW E93 M3 / Mercedes Benz W209 CLK500
BMW E64 650I(sold) / BMW E92 328I(sold) / BMW E46 M3(sold) / BMW E92 335I(sold) Porsche 996 911 C2(sold) / BMW E46 325CI(totaled) |
12-07-2016, 08:46 PM | #4 |
73
Rep 236
I didn't DIY this particular fix - I had "fix the hardtop rattle" written into the purchase contract, and the tech told me what the fix was.
First, you can verify if this is the particular rattle by applying slight upward pressure on the hardtop right next to the windshield and near one of the two latches while going over a bump that you know would have caused the rattle. If that silences it, then this fix should work. The way it was described to me is that you use a deepset socket to remove the conical locating pin on part #6 in the following diagram. http://www.realoem.com/bmw/enUS/show...diagId=54_0365 Then reinstall it with one or more of the 54377148164 washers installed as a shim. Mine was on the right latch and required 2 washers to take it from rattling like mad over every little road imperfection to dead silent even over big bumps. I think the washers come in a bag of 4. These are the leftovers. Last edited by Jarrod; 12-07-2016 at 09:20 PM.. |
R6jay7.00 StradaRedlands5012.00 |
12-08-2016, 11:12 AM | #5 | |
Rep 3,035
12-08-2016, 11:16 AM | #6 | |
Apprentice
373
Rep 801
This is exactly what's wrong. If I place my left hand on the top left hand corner of the roof, the rattle goes away. I will be fixing this promptly! |
12-08-2016, 01:59 PM | #7 |
73
Rep 236
Sounds like it. Super, hope you get it knocked out. It was described as a super-easy 10 minute fix. If you can post a couple pics that would be awesome. Since I didn't get to see it done, and it isn't clear from that diagram, I am not sure exactly where the washers go. It sounded like he was describing that they go on the back of the locating pin, thus moving it slightly farther out so that it fits more deeply into the corresponding hole at the top of the windshield. Not 100% sure on that, though. Let us know how it goes!
12-08-2016, 02:13 PM | #8 |
73
Rep 236
I still have a slight rattle that sounds like it comes from the left rear when I go over bigger bumps. There is also a tiny leak back there - I found two drops of water next to the left rear window after a big rainstorm the other day. Unsure if the two might be related or not. Probably not but I got a bottle of Gummi Pfledge and will go over all the seals with it this weekend, to help keep them supple.
12-08-2016, 02:45 PM | #9 | |
Apprentice
373
Rep 801
12-08-2016, 03:16 PM | #10 | |
Rep 3,035
02-07-2017, 12:22 AM | #11 | |
Rep 71
Thanks for the info.....this rattle has been driving me crazy. |
02-07-2017, 10:05 AM | #12 |
54
Rep 158
Lubing your seals is exactly as it sounds - you take lube, and place it on your seals lol.
There is a really good write up over on bimmerfest...but the basics of it is: 1. Stack your roof and stop it, go put the keys somewhere else so the roof will not move on you accidentally. Turn the car off of course. 2. Clean your seals with gentle soap and water. just enough to dampen, clean and remove dust and crud. Not enough water to drip or run into your interior. It's at this point you realize how many feet of seals the E93 has.... seems endless once you inspect it. 3. Along all your seals apply at the minimum - Gummi Pfledge, or much better is Krytox grease (a little goes a loooooong way). 4. While you are at it get some Wurth 2000 penetrating lubricant spray and lube up every joint you can find in your roof, start at the trunk and work your way forward. Don't forget the pins and receivers at the front along the windshield tops. 5. If you are feeling particularly diligent take a trombone cleaner and run it through all the seals with rain gutters / drains so they are clear. 6. May as well inspect the strings that control the roof lining while you are all up in here. Replacing worn and frayed strings is pretty cheap, simple and quick and can save you major $$'s on dealing with the damage if they snap. This should help a lot and it maintenance all E93 owners should do at least yearly. There will always be some clunk or rattles if you hit a pothole or similar, but in normal day-to-day use on a semi-decent roads it's shouldn't be rattling. |
02-07-2017, 10:15 AM | #13 |
Rep 666
^+1
I lubricate all of my seals and joints 4 times a year and never hear any rattles or have leaks. The only time I hear creaking is if I accidentally get my interior protectant (Griot's) on the rear chrome strip where the rear roof shell seals to the trunk. Cleaning it off and re-lubing the seal fixes that.
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
02-07-2017, 10:17 AM | #14 |
BMWCCA 149159
38
Rep 847
For more details on what lubing the seals means look here:
http://www.bimmerfest.com/forums/sho...d.php?t=609222 It also covers the linkage which also needs attention... |
02-07-2017, 10:55 AM | #15 |
Rep 71
Thank you for the responses. I will definitely be doing all of that. I remember coming across that post a few years back and it actually crossed my mind the other day to try and find it again. So fun2drive, thank you for re-posting it and the hard work that went into making it. Curious on how often the motor itself needs to be maintained. I've NEVER had a single issue with my top since I bought the car in 2010 *knocks on wood*, so I've never had it serviced. Does it need hydraulic fluid replaced at a certain point?
My rattle sounds more like metal on metal though ( like the pin shim situation described above) |
02-07-2017, 11:04 AM | #16 |
Rep 3,035
forgot to update this thread! I lubed my seals with gummipledge and it didn't do anything, then after some more research i used dupont krytox and it almost got rid of all the sounds! i'm a believer!
02-07-2017, 11:09 AM | #17 |
Rep 666
I use this: https://www.amazon.com/Super-Lube-92.../dp/B0081JE0OO
It's cheap and is compatible with all rubber compounds. Only a super light coating is necessary. I also use Gummy Pledge right after cleaning the seals to condition them, then use the silicone.
10-28-2018, 01:19 PM | #18 |
Rep 8
You must be very careful how many shims you put there! It will stop the rattle, but if there is a 1-2 shim more than needed it will leak. It's best if you have pressure washing machine to test for leaks.
12-10-2018, 07:38 AM | #20 | |
Rep 16
Fixed - Thankyou soooo much
BTW, took less than 10 minutes although i took the op to Gummy Pflege the seals and oil the moving parts too, so maybe 20 total.... Cheers J |
05-16-2019, 10:45 AM | #21 | |
Rep 3
Drives: 2010 520D & 2007 325i Cabrio
Garage List 1991 Kawasaki ZZR 1 ... [0.00]
2013 F10 520d Luxury [0.00] 2010 F10 520dSE [0.00] 2007 E93 325i Cabr ... [0.00] |
In the end it was the small hinged plastic squares at the rear of the parcel shelf, which rise up to allow the roof arms to extend. Can't see those? No, they're hidden - that's why. Here's how you check. Start to open the roof and stop when the roof is stacked and the rear deck is about half way up. The plastic squares can then be got at. Wiggle and flex them slightly - don't break them! One of mine creaked when moved. That was both the creak and the rattle that had been annoying me for a whole year. A drop of silicone or WD stopped it completely. But it taught me a lot. In trying to find this rattle, I learned how to lube and service the whole roof, how to dismantle and re-assemble the boot and back seat assemblies and a whole lot more. So I got to know the car a lot better. I hope that this will help some poor soul out there. |
06-08-2019, 02:31 AM | #22 | |
28
Rep 20
Real loud rattle coming from rear passenger side. I haven't opened the roof yet to inspect, but opened the trunk at the gas station, noticed a plastic cover for the roof contraption when the top goes down in the trunk. It was loose unlike the one on the driver side and may be the issue for my rattle. |
