10-08-2018, 06:11 PM | #1 |
29
Rep 81
Thrust Arm and Bushing Replacement (DIY?)
Hey all,
Just got back from the dealer after a coolant flush and it appears like my thrust arm bushings are severely worn. To make a long story short, the dealer has quoted:
To make it better they've only quoted the actual ~$70 bushings and bolts as the only parts required. Not the actual thrust arm(s). So safe to say I'm a bit salty. I know lower control arms are easy in our cars but what's the difficulty like on replace both thrust arms (w/ bushings pre-installed)? Something that I can do in the garage w/ a pretty good set of tools? Anyone else have a similar experience? My car is a 2014 335 xdrive for reference. Thanks! |
10-08-2018, 07:39 PM | #2 |
Rep 3,540
Why would you want to replace the actual arms unless you need to?
If you have a hydraulic press to remove the bushings from the arms you might be able to DIY it, but given your post asking about it, I get the feeling you don't have the tools required. The price they quoted you doesn't sound too out of line (for my area anyways). Either way, you can find the various procedures here. |
10-08-2018, 09:58 PM | #3 | |
29
Rep 81
10-09-2018, 09:11 AM | #5 |
Rep 1,467
I just replaced mine. Both of them went by 65K miles. I have an x drive as well.
The job is very easy on a lift. Make sure you remove the axle bolts on each side (buy new axle bolts; they are one time use) These arms are known to go bad around 60K miles on modern BMWs. $700 for this job is asinine.
2014 EBII 435ix - Stage 2+ Dragy: 0-60 3.61; 60-130 10.18
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 |
BMW DIY Guy3075.00 |
08-20-2019, 07:49 PM | #6 | |
57
Rep 215
08-21-2019, 01:23 PM | #7 |
Rep 3,022
Drives: 2019 M2 Competition
I have every possible bushing for the F32 from Powerflex, and am working on bushing replacement DIYs on them all and will post them here for sure.
That said, I am still very much learning and trying to find the minimalist approach for all of the process.. leveraging the rear sway bar guide to replace all the bushings there, looking to the fronts for more guidance etc. Still don't have it all down yet, and waiting on some tools and parts, but welcome any advice as well. Good to know on the axle bolts? Not seen that anywhere yet..
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
haagm58809.50 |
08-21-2019, 02:41 PM | #8 | |
Rep 785
Since BMW recommends the control arms be replaced for every other bushing change, we prefer to sell these as a pre-assembled set. So that's one reason? Dunno if they are being honest or not, but I guess maybe the arms get fatigued from repeated articulation. Given that they also sell their bushings without the arm, it doesn't seem like they are just trying to rip the customer off by offering them pre-installed in new arms. This Dealer could be jumping the gun and suggesting they replace them on the first bushing change to make more money. |
08-21-2019, 03:36 PM | #9 | |
9
Rep 39
Could be because they're aluminum and pressing bushings in and out widens the hole out of tolerance (or maybe weakens it). On my ZO6, GM recommended not changing the ball joints at all but replacing the entire arm. |
09-04-2019, 11:22 AM | #10 | |
Rep 3,022
https://www.realoem.com/bmw/enUS/sho...diagId=31_0942
09-04-2019, 11:44 AM | #11 | |
Rep 1,467
09-04-2019, 11:49 AM | #12 |
Rep 3,022
Ok, I am unclear of which bolt you are talking about then? I am going to be removing both arms (each side of course) to replace the bushings and want to make sure I am ready and have everything I need.
Thanks!
09-04-2019, 11:59 AM | #13 |
Rep 3,540
You don't have axle collar bolts since you're RWD. Control arm swaps are very fast and easy for your vehicle since you just have to undo the ball joint bolts on the knuckle and the bolts holding the bushings to the subframe.
09-04-2019, 12:16 PM | #14 |
Rep 3,022
Thanks man, I really appreciate the wisdom as always!
09-04-2019, 12:38 PM | #15 |
Rep 1,467
If rwd, this is the easiest job. If awd, you have to remove axle bolt and move the entire boot out of the way.
09-04-2019, 03:39 PM | #16 | |
Rep 3,022
https://www.newtis.info/tisv2/a/en/f...ounts/GaGZPQz2 Wonder if it is worth doing so?
09-04-2019, 10:15 PM | #17 | |
Rep 681
2016 328ix F31 - SOLD!
2006 997.1 C4S |
diy, thrust arm |
