04-01-2009, 09:45 AM | #2 | |
Philaf_666
14
Rep 163
- Wishbones - Tension rods (front and rear) - Guiding rods - front sway - subframe bushings - rear lower camber link You'll find most of them here : http://www.hpautowerks.com |
04-01-2009, 10:25 AM | #3 | |
Rep 579
04-01-2009, 11:25 AM | #4 |
Rep 1,477
Here are the part numbers needed for wishbone pieces front and rear.
Left Front Wishbone link--31102283577 Right Front Wishbone link—31102283578 Left Front Tension link—31102283575 Right Front Tension link—31102283576 Regulating Rod—37142283867 Left Rear Wishbone link—33322283545 Right Rear Wishbone link—33322283546 Left Rear Guide Arm link—33322283547 Right Rear Guide Arm link—33322283548 ABS/Brake Pad Wear sensor brackets (2)—34522283017 |
04-01-2009, 03:50 PM | #5 |
Rep 201
ABS/Brake Pad Wear sensor brackets?
I assume you need these brackets because stock doesn't fit one of the new rear pieces, but which piece?
135i ....
04-01-2009, 04:32 PM | #6 |
Rep 1,477
rear wishbones need the new brackets. The non-M brackets will not work. Good news is that they are cheap (about $5 each IIRC).
Up front, the driver's side wishbone needs a new regulator rod to keep the xenon lights level. Good news is that is is also a cheap part (around $10). |
04-01-2009, 05:22 PM | #7 | |
Rep 201
135i ....
04-01-2009, 05:30 PM | #8 |
Rep 621
FYI, if you order the parts from HP Autowerks then brackets will be included and I believe there is an option for adding the regulator rod. Just talk to Harold about it, he was very helpful with me.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
04-01-2009, 05:58 PM | #9 |
20
Rep 354
Im in for that
2009 AW 135i
CP-E CATLESS DPS, AFE EXHAUST , OIL COOLER KIT,FORGE DVV,,BMW PERFORMANCE SIDE SKIRTS AND BMW P . PEDALS, BMW PERFORMANCE SPOILER , BMW PERFOMANCE KIDNEY GRILLS, CODE 3 IC, DIREZZA Z1 STAR SPEC |
04-01-2009, 07:44 PM | #11 |
AutoXer
34
Rep 683
04-01-2009, 07:57 PM | #12 |
Rep 621
For those interested you can read my review on these parts here: http://www.1addicts.com/forums/showthread.php?t=228333
04-01-2009, 11:11 PM | #13 | |
Rep 201
Heh, I'm not even sure it's an option you need to mention since he sells these parts as upgrades for 135/335 he knows what is needed. I have front and rear parts sitting in my garage waiting for install and knew to check for the regulator rod (he included it without my mentioning the need). I just checked the box with the rear stuff and I have my brackets too.
135i ....
04-02-2009, 02:29 PM | #14 |
Free at last
289
Rep 986
where can you find pricing on these parts????
04-02-2009, 02:46 PM | #15 |
Rep 1,159
Anyone has tried these?
http://www.hpashop.com/product.sc?ca...3&productId=74 Looks a lot better than the stock ones. |
04-03-2009, 12:56 AM | #16 | |
Supreme Allied Commander
3895
Rep 54,605
Drives: F80 M3
04-03-2009, 12:58 AM | #17 | |
3895
Rep 54,605
Drives: F80 M3
http://www.e90post.com/forums/showthread.php?t=227480 Feel free to PM, email or call me with any questions you may have. Harold |
04-04-2009, 05:52 PM | #19 |
Philaf_666
14
Rep 163
Front parts are now installed!
I couldn't really test it hard because one of the rear RFT had a screw in it ( 4 new direzza star specs ordered ) so I had to switch back the winter tires for the rear. I still had the summer RFT in the front but I couldn't push the car due to this weird setup. Plus it's been raining on and off. But still, coming back from the shop I could quickly tell the difference. I'm not sure if it's due to -.75 camber or the stiffness of the bushings or both, but the car seems to turn more easily without having to turn the steering wheel as much. You can feel the road much better and be more confident while cornering. The steering is more precise. I also feel the car won't understeer as much once with my summer setup, but I'll let you know if this ends up being true once I can really push the car to the limit. It's a bit harsher over bumps due to the main bushing on the tension rod being much stiffer, but I consider it a good trade off for a better handling. Plus it's going to get much better with non-RFT. Now I'm tempted by the rear pieces... |
04-06-2009, 03:17 AM | #20 |
3895
Rep 54,605
Drives: F80 M3
04-13-2009, 06:01 PM | #21 |
Rep 503
I placed and order for the following parts for the HP AUTOWERKS site.
(thanks Harold) I've already changed to non-RFTs. Now I just have to find a shop that can do the install, correctly. 1 BMW Rear Upper Link Kit 1 BMW Rear Guide Rod Kit 1 BMW Rear Subframe bushings 1 BMW E82/90/92/93 Front Control Arm Kit Once I get it installed I will write a follow-up on the before and after.
MM
04-13-2009, 10:26 PM | #22 |
Rep 503
Yeah, I hear ya. I have my car at a tuner shop right now and am having the Dinan Stage 2 ECU upgrade installed. I met with the owner of this shop and he is Dinan certified and his shop mainly does BMW upgrades and installs. I sent him a email today to let him look over the parts so he can let me know if he will be able to do the full install and how much the labor will be. I will be taking my car back so I can test the Dinan software upgrade and then hopefully I will be bringing it back to the shop to complete the upgrades... for now
MM
