Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > downpipe install NOT!!!
      06-28-2013, 07:16 PM   #1
335xi Kevo
335xi Kevo's Avatar
26
Drives: 2008 335xi
Hey Guys,
Just about to finally get around to my XI downpipes and found a little treat!
[IMG][/IMG]
08' 335xi 6MT
Space Metallic Grey
Premium, Nav, Cold weather, Sport
Procede 2.5, DCI, Forge DV, PWM, Scoops, KW V1, ETS 5" FMIC, VRSF Downpipes, M3 Skirts
      06-28-2013, 07:16 PM   #2
335xi Kevo
335xi Kevo's Avatar
26
Drives: 2008 335xi
oil is visibly on the rear snail as well. Oil lines?
08' 335xi 6MT
Space Metallic Grey
      06-28-2013, 09:33 PM   #3
335xi Kevo
335xi Kevo's Avatar
26
Drives: 2008 335xi
no one?!
08' 335xi 6MT
Space Metallic Grey
      06-28-2013, 10:10 PM   #4
07tundra
Drives: 8.1L Chevy 2500hd
That could be coming from the valve cover......how many miles? Take the pipes off and look.
      06-28-2013, 10:36 PM   #5
335xi Kevo
335xi Kevo's Avatar
26
Drives: 2008 335xi
Valve cover gasket was done at like 82k. We went back to stock. CPO'ing it.
08' 335xi 6MT
Space Metallic Grey
      06-28-2013, 11:06 PM   #6
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Oil blow by off the rear induction tube.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      06-28-2013, 11:45 PM   #7
335xi Kevo
335xi Kevo's Avatar
26
Drives: 2008 335xi
Its clamped tight. Would there still be seepage? Is this enough to warrant a rear bank replacement? AKA seal's shot? Do I have a case?
08' 335xi 6MT
Space Metallic Grey
      06-28-2013, 11:49 PM   #8
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Rear induction tubes don't have a clamp and don't seal to good....
      06-28-2013, 11:59 PM   #9
NiVeDh
NiVeDh's Avatar
Drives: '08 E90 335i, '99 E36 M3
It could be making its way down all the way from the oil filter housing gaskets.
      06-29-2013, 01:22 AM   #10
335xi Kevo
335xi Kevo's Avatar
26
Drives: 2008 335xi
Non-oil cooler equipped.
08' 335xi 6MT
Space Metallic Grey
      06-29-2013, 01:26 AM   #11
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Housing is still there, can leak...I would check it.
      06-29-2013, 10:11 AM   #12
335xi Kevo
335xi Kevo's Avatar
26
Drives: 2008 335xi
Oil filter housing gasket is fine.
08' 335xi 6MT
Space Metallic Grey
      06-29-2013, 11:38 AM   #13
BMWM.D.
Stupid Idiot
BMWM.D.'s Avatar
134
Drives: E90 335i & 6th Gen ZL1
When was the last time you took a good look under the engine like this? Depending on how long ago the valve cover repair was done, it could be residual oil. Unless you spend a decent amount of time with degreaser, it can be hard to get the oil from the nooks and crannies on this engine. I see it all the time from past repairs.
As mentioned earlier, it could also be from the rear turbo inlet. Under full-throttle, the oil vapors are directed from the cyclone-separators in the valve cover to the rear turbo inlet. This is done because when there is pressure (boost) in the intake manifold, the vapors must enter the engine via a different path. The small amount of oil pictured could definitely be seeping from the rubber grommet where the tube connects to the turbo. It's just a push-fit connection.
      06-29-2013, 11:50 AM   #14
335xi Kevo
335xi Kevo's Avatar
26
Drives: 2008 335xi
Thanks for the info guys. The valve cover was done just over a year ago. I am very anal in degreasing and cleaning the motor. The techs recently did my water pump and 02 sensors, along with dropping the transfer case and re sealing it.
I took a look in there post repairs and didn't notice anything.
The oil is visibly on the turbo dripping off of it.
08' 335xi 6MT
Space Metallic Grey
