2010 2011 BMW 5 Series Forum F10 Strange noise coming from engine (N55) 535i LCI |
02-16-2024, 08:04 PM | #1 |
Rep 3
Hello guys I noticed that there’s a strange noise coming near the firewall of the engine bay right where my fuel rail is. I had the valve cover replaced in 2/23. I know there is an oil leak and have the gasket on order to replace but could it possibly be related or is this normal? The noise was consistent until I turned the ac on and off then it started with the rhythm heard in the video. I turned the vehicle off and on again and the noise went away. Attached in the link is a video of the noise. https://youtube.com/shorts/ahG4WO2UmQ4?feature=shared
02-16-2024, 09:59 PM | #2 |
Rep 437
A very strange noise indeed!
02-16-2024, 10:13 PM | #3 |
186
Rep 127
1). Remove cover on R.H. side (above blower motor) and try the bower motor with ac on and off see if it is from blower motor.
2). See if noise/sound change when oil fill cap removed |
ChiltiCoatl891776.50 StradaRedlands4971.50 |
02-17-2024, 08:44 AM | #4 |
Rep 3
I will try these both later today, it’s very strange because it will still make the noise even if the ac is completely off.
02-17-2024, 01:55 PM | #5 |
178
Rep 274
It sounds like the diaphragm inside the pressure converter/boost solenoid (part no. 11747649407). I had 2 of mine fail and it would make this noise if I had gotten into the boost hard. A small blip of the throttle would make the noise stop. LCI 535i models up until a build date of 07/2014 have a PWG. EWG N55s don't have this boost solenoid.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #578262 as a referral.
F10 535i M-Sport | Gone but not forgotten: G01 X3 xDrive30i M-Sport; F15 X5 xDrive35i; E70 X5 4.8i |
02-18-2024, 04:17 PM | #6 | |
Rep 1,873
02-18-2024, 07:25 PM | #7 | |
Rep 3
