01-06-2024, 05:49 PM | #793 | |
Rep 496
01-06-2024, 08:52 PM | #794 |
877
Rep 218
Drives: 2012 335i Sport
I had already ran the harness up to the head unit and it seemed like it would be easier to access and troubleshoot if needed, but perhaps it was not as easy as it seemed. Pretty sure, matched the colors and had double checked the pin outs. Would 4-5 inches of untwisted wire at the end of the retrofit harness cause interference in the KCAN system? Open to tapping at the FEM, but I am more concerned that something else is up with the harness at the point as it should give the same effect at the iDrive controller harness
01-07-2024, 09:04 AM | #795 | |
Rep 496
You mentioned trunk mount, what wiring harness are you using? Neither trunk mount nor tapping the CAN at the iDrive controller are part of the official retrofit instructions, so I can't help but wonder if something is hooked up improperly or the wiring harness isn't correct. People place the module in the trunk without issue so I know its possible. Also, with a CIC car, I want to confirm you placed the wires in the quadlock harness into the correct positions, which are 18,28,and 27?
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo |
thatgarrett876.50 |
01-07-2024, 09:10 AM | #796 |
Rep 535
Mine was in Trunk because of lvds it is actually retrofit wiring Hannes for F10. Connection I did like on wiring diagram for F30
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
thatgarrett876.50 |
01-07-2024, 11:24 AM | #797 | |
877
Rep 218
01-07-2024, 11:26 AM | #798 |
877
Rep 218
That’s exactly what I did too, since I’m not doing the surround view module it is actually a little easier to mount like this as you don’t have to run separate wires on each side of the car. The harness length and plugs all fit perfectly so far too, just the CAN errors is the only weird part
01-07-2024, 01:08 PM | #799 | |
Rep 496
01-08-2024, 11:14 AM | #800 |
877
Rep 218
I couldn’t get the module to show up because the CAN network was showing all kinds of errors, but it looks like the CAN wires in the retrofit harness themselves are at fault- there is contunuity between both CAN wires, the ground, and the shield wire (also ground I believe), all when the can wires are disconnected at both ends, meaning there must be a break of some sort in the wires, likely at a sharp edge. I’ll check and see if the FEM has the CAN wires there, then I’ll cut the retrofit harness there, test the can wires and see if the branch from there to the rear of the car still has the continuity readings or not. If so, I’ll start pulling trim. If I get lucky and only the branch going from the cut at the FEM to the center dash has continuity, I’ll just connect the wires at the FEM and toss the (extra) wiring that was running from that point up to the iDrive. Glad I’ve pinpointed it and shouldn’t be too much of a pain, but still not the most fun project to undertake. I’ll update once I’ve successfully figured out where the wiring is bad- appreciate you bouncing ideas back and forth in helping me thing this out
01-08-2024, 05:24 PM | #801 | |
Rep 496
thatgarrett876.50 |
01-08-2024, 07:44 PM | #802 |
877
Rep 218
It was OEM from one of those Eastern European sellers on eBay, came in the packaging and everything and appears OEM, I’ll see once I investigate more though, I did have a pin break when I was trying to insert it into the CiC harness so maybe it wasn’t? Looks good if it isn’t
01-17-2024, 05:36 PM | #803 |
877
Rep 218
rlesko
Finally completed it and got everything working! My problem ended up being a few different things: -the CAN wires must have gotten behind a clip or where a mounting bolt goes, because they were smashed on the middle side of the passenger footwell, the wiring was exposed and likely in contact with metal and led to my initial can errors. Remedied by cutting my CAN wires in the new harness as it passed the FEM and tapping wires there instead. -still no rearview signal, so I set up eSYS on my Mac and all the pain that that is, and tried for multiple days to get it to connect to the car. Turns out the ENET cable was junk so I got a different one and it worked first try. -then I never got the TSRVC to show up in ESYS, checked the wiring and the TSRVC wasn’t getting 12V, traced the wire to the rear fuse box and figured out I had installed it on the “bottom” row instead of the “top” row of the plug, the bottom row connects to nothing. Spent about 1.5 hours getting the old PIN out and slotting it in new connector. -at this point, the rearview camera worked! I had done some coding via BimmerCode in expert mode at the beginning, so that is to say that you CAN do this retrofit without ESYS and just via BimmerCode by editing values in the HU and REM in expert mode!! -I injected a new CAF into the TSRVC, edited my FA, and VO coded just to be safe and have everything happy. I’m planning on flashing my REM to a new iSTEP so my LCI tail lights inner turn signals will work, so the modified FA will be used to flash the rearview camera settings back in when I do that. All in all, 2 silly mistakes made this longer than it should have been, but everything works and no harm done! |
rlesko238.50 |
01-18-2024, 08:04 AM | #804 | |
Rep 496
It seems like you were able to save a substantial amount of money with the trunk mounted camera module which is another big win. I did everything the OEM way in my car with the driver footwell mounted camera module because I had ultimately planned to do the ‘surround’ view but after retrofitting front and rear PDC with reverse camera I don’t think I’ll bother with the ‘surround’ view as I don’t think its worth the investment from time or money perspectives - I could have saved at least a couple hundred bucks with trunk mounted camera module!
thatgarrett876.50 |
01-18-2024, 09:19 AM | #805 | |
877
Rep 218
02-10-2024, 06:13 PM | #806 |
Rep 17
Hi all,
First off, thanks for keeping this thread alive with comments, tips and solutions. It really did come in handy when trying to understand exactly how to undertake this retrofit. I did read all 37 pages too before starting. Today I completed this instal on my F20 LCI (2015). I purchased the camera cable, plastic holder and screw for the control module, and the small female PINS for the FEM (in case there were no K-Can wires I could splice into) from the dealership. The camera module, camera and wiring harness I purchased via Ebay. A few things for those with F20s. You won't need the plastic holder for the ECU. As I mounted it in the boot I couldn't figure out anywhere to instal it. I installed the camera module on the left hand side without the bracket, didn't need it. The camera cable was long enough to reach it there. I then took the tape off the retrofit cable and kept the Ground wire and Fuse (power) wire in the boot. I did shorten the fuse wire as it was way too long. There was a Ground point near the module. I ran the cable on the left hand side of the vehicle to the drivers footwell, crossed over to the head unit and connected the wires as per the instructions in the PDF on this thread. (White to PIN 24, Red [mine was yellow] to PIN 21 and the Shield to PIN 23) I then took the K-Can wires to the FEM in the passenger side footwell. On my car PINS 51 & 52 were empty so I just put connected the small female Pins on the wires and inserted them. (Female PINS part# 61 13 1 383 776). I did have a problem that the K-Can wires barely reached the FEM so I did have to slice them and put in some extra wires as the wires were too taut. I added about 15/20 cms. The hole for the camera took a while to do. Take your time with it as a tighter fit is what you're aiming for. I made a stencil out of cardboard and used it as a guide so it would be nice and centred between the licence plate lights. Had no problem coding with E-Sys. I did have to inject the Cafd files into the TSRVC as per the instructions by ShawnSheridan. Once I added 3AG to the VO I coded the FEM, HU_NBT, REM, ICM and TSRVC. I was lucky that the camera and control module (ECU) were from the same donor car so I've no errors on the dash and don't think I'll need to use Rheingold. Image is clear, guidelines are there and I'm able to turn the camera on and off via the PDC sensor switch (as I added one near the gear lever when I installed front PDC a month ago). All in all, this was a pretty simple instal. I really didn't have too many issues with any of the steps. If anyone needs any information, please ask, I'm no expert in any way but I'm happy to share details of what I did. Also, cost wise I think I spent around 350 euros (give or take a few euros) all up. Camera Control Module and Camera were purchased on Ebay in the US. The retrofit cable on Ebay in the UK and the rest I got a my local dealership. |
