Schwaben Scan Tool
07-28-2016, 07:49 AM | #23 | |
Rep 14,829
It seems like many if not most are comfortable even coding with bluetooth and smartphones...it kind of makes me wonder why we would have bothered with the bav tech and ISTA's of the world....I haven't made that leap and still prefer to plug in a laptop, but I guess this behavior is like being a dinosaur... |
07-28-2016, 10:07 AM | #24 | |
1208
Rep 2,835
It was because I didn't have it to tell me what was wrong that the car ended up at the dealership. |
08-28-2016, 02:30 AM | #25 |
Rep 1,903
Drives: e92 335i 6MT
So is there any difference in function between the foxwell NT510 and the Schwaben version? I know that with the Foxwell you can add other makes not just BMW. With the Schwaben scan tool, can you also add non-BMW software later on?
08-28-2016, 06:14 AM | #26 | |
General
17415
Rep 18,796
08-29-2016, 02:40 PM | #27 |
Rep 16
Drives: 2010 E92 335i 6MT MSport
08-31-2016, 08:09 AM | #28 | ||
Rep 6,968
Drives: 2007 Black/Black 335i e90
Boot camp is a good idea, but if you don't have a version of Windows handy?? |
09-07-2016, 09:01 AM | #29 |
Rep 1,903
So can anybody confirm the difference in function between the foxwell and the schawaben branded units? The Schwaben unit costs an extra $20 and is a different color, is there anything else lol?
09-12-2016, 11:47 AM | #30 |
Rep 1,903
09-12-2016, 12:51 PM | #31 | |
1208
Rep 2,835
I do know that mine will do BMW and Mini... |
09-12-2016, 08:31 PM | #32 | |
66
Rep 262
Mine works great BTW. Found my "SES" light was from a dirty solenoid. Cleaned it (not replaced) and it fixed the problem....that right there saved me $140. Damn near paid for itself on the first day. Last edited by 9iron; 09-12-2016 at 08:33 PM.. Reason: spelling |
09-18-2016, 01:11 PM | #33 |
1208
Rep 2,835
Well, mine just gave me a serious peace of mind. Had to drive the car to the indy shop that is going to replace the water pump. Monitored the engine and radiator temp and the rpm of the water pump the whole way there to make sure if the water pump died on the way I would know.
09-18-2016, 04:24 PM | #34 |
2183
Rep 2,806
From the Q&A on the ECS page and after a search of the BMW Functions List, it appears you cannot change the battery type (AGM <-> flooded cell). I'm assuming you can register the same type of battery with a different Ah rating!?
Certainly is a good tool that seems to be pretty reliable and easier to use than a PC based system. |
09-18-2016, 07:06 PM | #35 | |
1208
Rep 2,835
I set it to pull up the live data for the coolant and pump today. Worked like a charm. |
09-22-2016, 07:27 AM | #36 |
Head Fry Cook at McBurgertown
507
Rep 1,005
I bought the ECS unit.
It has more than paid for itself with airbag & service resets and pointing me towards a faulty vanos (problem gone). |
09-22-2016, 07:43 AM | #37 |
Rep 14,829
What was the issue with the airbag? After all this Takata stuff, I'm beginning to question if say the warning goes on and the airbag is disabled, is it better to leave it as such? (the thought is just like something doesn't usually spontaneously combust, and airbag lamp doesn't just turn on for no reason) My Nissan was the first year that side airbags came out on the Maxima, and over the years I've reset it hundreds of times, rather than buying a new module which was in the $800 ballpark. Now I leave it disabled.
09-22-2016, 09:18 AM | #38 | |
507
Rep 1,005
None were steering wheel related. |
09-22-2016, 09:34 AM | #39 |
Rep 14,829
Gotcha--when I removed my DSC hydro pump, and turned the ignition on (not to start the car but to see the mileage), the car went berzerk--all kinds of fault codes related to velocity, including the airbag. Wipers went on full blast and could not be turned off. googling and searching only lead to a few posts, and a person here was good enough to respond to a PM when the thread was years old. The implication was that the condition was 90% due to turning the ignition on with the DSC hydro out. Upon reinstallation, the faults all cleared upon their own.
09-22-2016, 07:16 PM | #40 | |
Rep 6,968
10-09-2016, 11:24 PM | #41 | |
Rep 31
Drives: 2006 325xi Sedan Jet Black
10-20-2016, 06:40 PM | #42 |
Rep 5
The tool can do lots of good things, like register a new battery (as long as it is the same spec). BUT, it will not 1) code a battery with a different Amp/hour rating, and 2) switch battery types (from wet to AGM or vice versa). I confirmed this with Foxwell tech support after trying to find it on my scanner. Latest firmware update did not add this simple feature so if enough owners request a feature maybe it will happen????
10-20-2016, 07:48 PM | #43 |
Rep 458
Wish it would do simple coding like the carly app. I would buy one today if it did...
11-29-2016, 09:48 PM | #44 |
28
Rep 19
Foxwell NT510 scanner test report OK experience and K.0 experience
Foxwell NT510 scanner test report OK experience:
- The included software is not native to Mac computers. - win10 is compatible. - Can can provide sensor data from the oil level system on an F82 M4, The M4 apparently can only read the oil level with the iDrive, which we plan on permanently removing for non-street use. - Allow me to alignment and calibrate fuel injectors on a 2009 535i N54 engine - Can read codes from a transmission control unit (TCU) on a 2003 e46 325xi. - Can register a battery to an e90 328i. - I have a 2007 328i Coupe, NT510 can determine which wheel speed sensor is bad. - NT510 can read and reset airbag service light. I have an intermittent airbag service light on a 2004 X3 that BMW service cannot track down as it clears from memory before I can get it in for service. - Have the ability on the 09 BMW E82 135 to scan for ghost codes, and any other stored codes. For example, example it will read codes that you did not get a scanner connected fast enough while the check engine light was on and it goes off before you know what the code actually was. -Can code new injectors in the BMW 2010 335i. -Can Re-program the Speed Governor on 2011 e90 328i LCI model, vin WBAPH7C52BE852716...please note: Performance software is required to manipulate top speed limiters. -Can perform a throttle actuator adaptation on an e92 M3 after replacment - Is capable of functioning as a universal OBDII reader for all makes in addition to it's BMW/Mini/RR Specific functions. - Can work with a 2012 mini cooper countryman s all 4. - Have E36 OBD1, for OBD1 cars will require adapter ES2992111 to perform function, Available features will be dependent upon the cars abilities. Not all features are compatible with all models. -Communicates via the obdII plug in the cabin on the E39 M5 2000, no extra adapters needed. - Whether NT510 can read TPMS codes or not (Specifically to tell which TPMS receiver is malfunctioning), it depends on the vehicle,If your car has the ability to provide this information the tool will be able to pull this data. - can read and reset O2 sensor readiness codes but will not code them off permanently. - Updates can be skipped; sequential installation of updates is not required. - Can reset "Right/Left Cornering light" warnings on 2011 335d caused by after-market halo installation. To properly clear the error code you need halos with proper resistance, this will cause the car's computer to automatically reset the warnings. - I own a 2011 335i N55. all functions are supported across the E93 series. - Able to reset the (sas) steering angle sensor - Ok to reset the Airbag/seatbelt light on Mini Cooper S R56. - Ok to modulate the e-parking brake on a 2012 BMW F10 to enable a rear brake job with rotor replacement. - Module recoding and programing is possible with this tool. - Availability of features of this nature will vary heavily model to model and year to year. - Can register new tire pressure monitoring sensors. - Can do VANOS test, Idle Sync etc for e46 m3. -Can activate the abs unit in order to bleed it on a 2008-011 m3. - Can do battery registrations and coding on BMW and mini cooper. - Be able to code a new battery on 08-2011 M3's. - To make NT510 is compatible with the early E36 (The car has ads modules for Abs and srs), need the 20 pin adapter ES2992111. - Can reset the adaptations needed after an e46 m3 smg clutch change. - Allow for line code changes when programming car options, such as automatic door locking. - Enable auto rear window defogger for GM5 module on BMW E46. E46 general module coding is possible. - Can perform the dynamic drive reset for a 2002 745. - Reset the transfer case oil wear indicator on BMW e83. - Be able to display the sensor's output if this function is registered by the car's dme. - Can pull codes from the SRS system and reset the light once all issues are corrected- - Able to reset transfer case adaptations after transfer case fluid change in an F32. - Allow coding of the LCM and GM on BMW vehicles. - Have the ability to program new ABS components to current vehicle. - Can code for Xenon headlight conversions and also for activating *Sirius Retrofit Enable Code (FSC)* for Mini Cooper R56's, but only some models not all. - Can read BMW Specific (Shadow/Hidden Codes) - Can code injectors and new battery on 2008 BMW 135i. NT510 scanner test report Fail experience:: - NT510 scanner cannot remove the top rpm limiter on a bmw z4m roadster 2007, performance tuning software is required to remove top speed limiters. - Can't retract the calipers on a 2005 BMW x5 4.4i e53. The E53 does not have electronically controlled calipers. On the E53 you'll manually compress the pistons after removing the caliper, please see the following tools to assist you with this task, http://www.worldobd2.com/wholesale/f...i-scanner.html ES8211 ES9747 ES2153340 Where to buy Foxwell NT510 Multi-System Scanner? Make sure buy from an authorized Foxwell dealer with good quality device and fine after-sales service, more importantly able to register at official site foxwelltech.com. FYI, I bought from the dealer www.worldobd2.com, the customer service is helpful when I have any issue, they response quickly. |
