01-23-2024, 10:52 AM | #1 |
27
Rep 112
Front ball joint removal tool? - anybody have Crunchysann?
So in replacing my thrust arms, I thought I would go ahead and replace the ball joints too. Good design...right? Well my car prev owner being from Virginia for 8 years...yeh...they're frozen in there. Went at just one for a couple hours with various punch/chisel and BFH, and zero movement. Applied heat though probably not as much as needed because I don't want to torch other good things, but no help. I figured before I bought an air hammer that might not work either, I would look around.
https://crunchysann.com/products/f-s...t-removal-tool They make this perfect tool, but they're out of stock on the f-series sized one and nobody there has replied when they might have it back in stock. One guy on youtube made his own tool out of bolt hardware and bar steel. I'll resort to that soon, but no rush so going to try and get this tool first. Anybody have this tool they would sell or rent out? I'm in SF Bay Area, California. |
01-24-2024, 11:06 AM | #2 |
19
Rep 148
Are you hammering with a chisel from the top like this guy?
https://youtu.be/lyRm70nAsns?feature=shared |
01-24-2024, 05:24 PM | #3 | |
27
Rep 112
01-31-2024, 08:07 PM | #4 |
Rep 9
Drives: 2016 BMW X3 xDrive 35i M Sport
I went through the same trouble back in July. Took me a good 6 days. Removed the cv axle and blasted it with an air hammer for a while didn’t seem to do much but destroyed the top of the balljoint. First time seeing the press tool custom made to fit the ears. Would have been a life saver. A 3lb hammer and patience combined with the air hammer and some heat ended up getting the balljoint with 140,000 miles out of a car from Pennsylvania.
02-12-2024, 10:56 PM | #5 |
27
Rep 112
Update... Crunchysann isn't bringing any new stock into production yet while they fight copycats, so off to Home Depot and I bought a 2" galvanized pipe cap and a 2" short galvanized threaded insert. Took my grinder to the threaded insert and cut length and fingers to go around the ball joint wings, and a hole through the cap. Put it on the old ball joint, lined up the fingers and cranked it down, then hit it with the impact. Didn't see any movement, but just a few minutes of hitting it with my 2lb hammer on a large chisel and I got movement! A minute later it was out.
Since I only messed up one ball joint during my thrust arm replacement, and both felt nice and tight anyway, I decided to leave the other side as it is and not risk having it be even worse. |
02-13-2024, 05:03 PM | #6 | |
19
Rep 148
02-15-2024, 05:44 PM | #7 |
27
Rep 112
Pics attached here. One finger had to be shortened...not even sure it was making contact with anything...because there isn't any room on one side. I was going to possible remake the whole screw-in insert to accommodate for that and still put a narrow finger to one part that could connect, but it became unnecessary.
While this tool didn't remove the ball joint on it's own, it added the necessary pull/tension on it so that a few solid whacks with my hammer and large chisel got it to release, and it was very easy from there. So now I went in for an alignment and my tie rods are frozen. GREAT. Fortunately, other than the steering angle being turns a bit at the wheel, they said the rear end was in alignment and the rest was actually pretty close. They tried heat along with a BIG F wrench and couldn't get it to budge, so I'm not holding out that 3-5 days of PB Blaster and then maybe heat myself is going to get it done, and I'll be cutting/replacing the entire tie-rods inner & outer, but we'll see. Last edited by JamesInSJ; 02-15-2024 at 05:50 PM.. |
02-15-2024, 05:57 PM | #8 |
27
Rep 112
Pipe cap: https://www.homedepot.com/p/Southlan...08HN/100156130
Threaded short: https://www.homedepot.com/p/STZ-2-in...2XCL/202310599 or you can use any 2" pipe with threads on one end, and cut the length and fingers to size. |
