Go Back   7Post - 7 Series Forum > BMW 7-Series Forums > (F01) 7-series General Discussions
      12-28-2023, 11:38 AM   #1
McMarv
Drives: Bmw F01
HSR Control Unit Replacement - Coding?
Hello Guys,
i think my HSR control unit from my f01 (2010) is faulty. So. I ordered a brand new to test. In the replacement info it says that it has to be coded.
Can you tell me which kind of coding is necessary and how I can do this by myself? I have ista D, a enet cable and E-Sys.
Thank you so much!
      12-30-2023, 03:33 AM   #2
TheNine90
Drives: bmw
You can do it using esys. It necessary to vo code it. Load FA, select HSR from svt and press code
      12-30-2023, 07:05 AM   #3
McMarv
Drives: Bmw F01
Sounds not very complicated. Do I need full PSdZData or something else for that? Thanks!
      12-30-2023, 09:03 AM   #4
TheNine90
Drives: bmw
Only esys and psdzdata lite
      01-02-2024, 09:52 AM   #5
McMarv
Drives: Bmw F01
Hello,
i just got a brand new HSR Control Unit. But i cant "code" it, cause there is no CAFD in it.
Please see the attachements with old control unit with CAFD and new one without CAFD.
How i get for the new one now the coding done or the CAFD in? And which CAFD version i need?
Thanks for your help!
      01-02-2024, 10:14 AM   #6
TheNine90
Drives: bmw
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (ECU)=> Left-Click on HSR => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown (bottom) => Select OK => Right-Click on HSR (the ECU itself not the underlying CAFD) => Select CODE.
McMarv0.00
      01-03-2024, 11:38 AM   #7
McMarv
Drives: Bmw F01
Perfect. This worked. Thanks
Additional info:
You need for the actual psdzdata a newer version of esys like 3.30.1 or newer otherwise "Detect CAF for SWE" will be greyed out. A launcher is for CAFD injection not necessary
7post
