Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Jb4 map 2 without DP?
      06-12-2014, 11:48 PM   #45
-Wingman-
Drives: 2011 e92 M-Sport
Originally Posted by Jeff@TopGearSolutions View Post
It would make a difference in some respect as you need to now over-spin the turbo's to meet target due to a potential small boost leak. Over spinining the turbo's creates excessive air intake temperatures, reducing overall efficiency and power.
Good point. I hadn't thought about that. I assumed that if there was a boost leak somewhere like the CP area, the car simply wouldn't boost to the target psi. Plus, I've been noticing that my oil temps stay significantly lower while driving. Could that be from the engine heating up quickly and activating the oil cooler? Without the jb4 installed, my oil temps have stayed around 240. After the jb4 install, my oil temps stay around 200-210.
Originally Posted by JETmn View Post
You have a CP that uses the stock clip to attach on the engine end, correct? The other possibility is the t-bolt clamps on both ends.
Yes.
Originally Posted by Schmidty335i View Post
I ran Map 2 for two weeks with no issues with a stock DP. all i have is the jb4 bms intake and 91 oct chevron gas (cali) pulled hard. ordered a DP should be getting it today so i should be better off now haha
Sounds like a bad idea man lol. Running 91 octane on map 2.
      06-13-2014, 10:00 AM   #46
JETmn
Drives: 2011 335i xDrive Msport
2011 335Xi  [0.00]
Go check the stock CP you took off and see if the o-ring is still in there.
      06-13-2014, 01:23 PM   #47
Schmidty335i
Drives: E92 335i PS2 turbo FBO JB4
Yeah Wingman, i was starting to feel the same even though i had no issues. i put it on map 5. but i did put some octane booster in it just to make sure if i switch to map 2 iam at least in a little better shape haha.
      06-15-2014, 02:31 PM   #48
-Wingman-
Just a quick update. Had a quick opportunity to race another n54 335xi. E90 that was stock. Both of us had passengers. I raced on map 1....same result. He beat me. The catch is that I went ahead and switched to map 0. The result was exactly the same. Actually, I would say he pulled less on me on map 0. Lol
      06-16-2014, 08:02 AM   #49
JETmn
2011 335Xi  [0.00]
Did you ever check your CP to see if the o-ring is still in there?
      06-16-2014, 10:52 PM   #50
-Wingman-
Yep, it's still there. Maybe there's a leak somewhere else? Is it normal for the boost to spike up and build up in increments?
      06-16-2014, 10:59 PM   #51
weehe126
Drives: 2017 340i
No, that would indicate a leak
      06-17-2014, 09:08 AM   #52
JETmn
2011 335Xi  [0.00]
The o-ring is still on your old charge pipe? If it is, then you didn't take it off and put it on the new one and you have a moderate boost leak.
      06-17-2014, 12:51 PM   #53
-Wingman-
Yeah. Would it make that much of a difference?
      06-17-2014, 01:36 PM   #54
Andrewe92
enthusiast
Andrewe92's Avatar
Drives: 2011 e92 lci 335xi
I have an n55 currents mods are: 7" fmic, er cp, bmw full pe, bms intake, 93oct... I was running map 1 for a while before I got my cp than went to map 5 than got curious one day and tried map 2 it was a really strong pull im an xdrive and traction control went crazy and basically stopped my car haha but at any rate i have stock dps and map 2 feels good once and a while sometimes it doesnt feel as fast.. i say log your car with a few different maps and see what looks and feels good. map 5 when it tunes nicely with your car feels great!!
note: I noticed that on n54tech they updated the map guide for the n55 stg 2 and it no longer mentions needing a dp for map 2.. weird.. i could be wrong but check out map guide on the official jb4 n55 thread on n54tech
      06-17-2014, 05:25 PM   #55
JETmn
2011 335Xi  [0.00]
Yes, it makes a big difference! You have air blowing out of the CP that is supposed to be going in the engine. Depending on the MAF location it could be throwing off the tune. You are probably down a good 30whp.
      06-20-2014, 05:59 PM   #56
-Wingman-
Oh damn, yeah I'll check it out.
      06-20-2014, 06:01 PM   #57
Andrewe92
enthusiast
Andrewe92's Avatar
http://www.n54tech.com/forums/showthread.php?p=193708
"Map 2: 14psi. Suggested for those with a high flow exhaust and 93 RM2 or higher octane. "
niceee I have 100oct in my tank now hah ill try it out.. but I still think you should get a dp for that quicker spool
      06-20-2014, 06:01 PM   #58
-Wingman-
Ok, well the CP is secure on the engine for sure. The o-ring is in good shape and all the clamps are pretty tight as well as the tmap sensor. Car seems to hold boost better, and it doesn't fluctuate that much, but the car doesn't feel THAT much quicker if you know what I mean. Is the boost supposed to taper down to just above 10psi as the rpms go up? Is there a possibly there's a boost leak somewhere else?
      06-21-2014, 09:49 AM   #59
mustangivore
33
Drives: 2011 335i E90
Would the BMW PE qualify as high-flow since it's just muffler upgrade? I'm guessing not although it helps 'engine by-products exit more efficiently' according to BMW. I run 93 all the time and have no other engine modifications (other than PPK) and wondering if I could run map 2 if I got JB4? Or maybe running map1 mostly and map2 on special occasions.
MHD Stage 2+ FBO
      06-21-2014, 09:51 AM   #60
Andrewe92
enthusiast
Andrewe92's Avatar
Would the BMW PE qualify as high-flow ? I'm guessing not although it helps 'engine by-products exit more efficiently' according to BMW. I run 93 all the time and have no other engine modifications (other than PPK) and wondering if I could run map 2 if I got JB4? Or maybe running map1 mostly and map2 on special occasions.
I also have the ppk and bmw pe, I am also wondering if the pe is considered a high flow exhaust.. Map 2 feels great for me sometimes.
      06-21-2014, 09:56 AM   #61
mustangivore
33
Being just muffler upgrade maybe helps only a little.
By the way, I also hear that down pipes don't help as much with n55 as with n54 but these are questions maybe good for terry or someone with expertise.
MHD Stage 2+ FBO
      06-21-2014, 10:11 AM   #62
mustangivore
33
Originally Posted by Johnny Boost View Post
AFAIK map 1 of the jb4 is similar to stage 1 sport for the Cobb. The bump up in hp is pretty small. Which means it could still be a close race. Was DTC on? How old are you tires? Did you launch from 2nd? Were you running e85?
My understanding was that jb4 map 1 is similar to cobb stage 1 aggressive, not stage 1 sport. I thought stage 1 sport was more akin to BMW PPK.
So like this:
BMW PPK ~ COBB stage 1 sport
JB4 map1 ~ COBB stage 1 aggressive
Am I wrong about that?
MHD Stage 2+ FBO
      06-21-2014, 02:07 PM   #63
JETmn
2011 335Xi  [0.00]
Yes, boost tapers bad with this tiny turbo. You want to shift just over 5k.
      06-22-2014, 12:05 AM   #64
-Wingman-
I know. It's horrible. Especially coming from a car that would build power all the way to 8700rpms lol
I'm trying to log on jb4, but I can't find the software I need to download to do logs. I put some e85 in the car and it's running a bit stronger, but I'd like to see numbers.
      06-25-2014, 09:37 AM   #65
ticaohaha
ticaohaha's Avatar
Drives: M4
I tried map 5 for auto tune, but the pull in Map 5 is not as good like it in Map 2 . I have Dp, Cp, Fmic, and run 93 oct. Is it safe to use Map 2 all the time ?
      06-25-2014, 09:58 AM   #66
Jsoboti
Jsoboti's Avatar
28
Drives: 2011 335i E92 M-Sport 6MT
Yup!!
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
