Go Back   6Post.com | BMW 6-Series Forum > BMW 6 Series Forum > General 6-Series Coupe, Convertible, and Gran Coupe Forum
      06-12-2020, 09:43 AM   #23
Thewrench86
36
Drives: E92 \M sport. F06 640d M Sport
👌 love a happy ending!
      07-16-2020, 12:56 PM   #24
rgerwal
17
Drives: BMW 640D Gran Coupe M Sport
Unfortunately I now have a similar problem and don’t want to start pulling the dash apart myself. Mine is a 640D F06 2015. When to work and all was good. Parked the car for the day. Returned in the evening and the display is blank apart from a couple of vertical lines.
      07-20-2020, 09:31 PM   #25
pcgold
Drives: 2015 650i Xdrive GC
2015 650i
Last year my dash went blank. I had gone away for a couple of weeks, when I got back the battery was low. I charged that up but the cluster wasn't working properly. Only a few idiot lights were on. THen next time I turned the car on, nada. The Heads up display wasn't working.
I live in Canada. Took the car to my indy. Dash faulty, no good, not repairable, only replaceable. Quoted me $4600Cdn plus tax and install, so around $5,500 in total. Since it was an indy, and the part was electronic, he could not offer me a warranty. Further, if the part came in and was installed but didn't fix it, they would not give me a refund.
Thanx, but no thanx. Went to the local dealer.
Exact same diagnosis but I was ready for the sticker shock so simply said to please go ahead and order it. Also, and a bonus, two year warranty, further if it didn't fix the problem I wasn't on the hook.
Now, I could have yelled at the poor guy on the phone giving me the bad news (ie $5500) but, as I said, I was ready for that so not upset or anything.
Was told two weeks but got a call after only one week and it was all ready.
When I went in the same guy I had dealt with was grinning from ear to ear. He had called BMW Canada who agreed to eat most of the cost. Maybe he did that cuz I wasn't mad at him on the phone. Goodwill I think (and maybe they know it's a common issue). So, the total cost was only $1,700 Cdn. Still a lot, but almost $3800 less.
Now, however, I wish I'd seen this solution. Next time (God forbid), I will simply replace the boards.
      08-15-2020, 03:14 AM   #26
Holt2498
Drives: BMW F06 640D M Sport LCI
Update - SOLVED
Just a quick update, dash has been perfect since my original post, so all is good.
I have helped another forum member who purchased the same LED PANEL from the eBay link I posted, all fitted and working fine.
WORD OF ADVICE - the two outer dials, fuel and oil temp, once positioned when refitting the PCB, gently push from the front of the panel where the displays show on each of the outer dials, you will hear a mild click and this tells you that the outer dials are correctly seated and you should not have the issues I faced.
Hope this helps.
      09-02-2020, 12:40 PM   #27
HBAH1747
Drives: bmw 520i 2015
I have tha same problem with my 6wb ( black screen ) after reading your procedure i orderd the LCD and i fix it and it works .
What i did :
1. Remove battery ( negative only ) importent dont close the trunk while the battery off.
2. Remove instrument cluster (YouTube) and open easly.l ( i change the LCD make sure to press gently the 2 small gauges from the front)
3. return battery back.
Thank you very much Holt2498 good job.
      08-07-2021, 10:12 PM   #28
rkl
New Zealand
Drives: BMW 320 e90 BMW X1 e84
Thanks for the info. Just had the same issue pop up on my '14 F11. would most agree that the part number would be the same.
Prefer to open her up and repair in one hit.
      08-12-2021, 03:44 PM   #29
Kolianovskyi
87
Drives: BMW 650i
Got the same on the fourth day after purchase. Disappeared by itself after 15 min. Drove as is))). Never seen again after.
      08-12-2021, 08:15 PM   #30
blackbmw2018
15
Drives: bmw 6
Thanks for sharing, the eBay link is dead. Please advise where to purchase the module.
Thanks
      08-13-2021, 10:22 AM   #31
Kamate
31
Drives: BMW m6
Your can look up the part number or try this
https://www.ebay.com/itm/18439383125...AAAOSwW8xfLhBL
      08-13-2021, 12:19 PM   #32
blackbmw2018
15
Drives: bmw 6
Thank you!!
      08-14-2021, 09:42 AM   #33
pcgold
Same thing happened to me a few months after I bought my 2015 650ix GC. Indy wanted more than $5000Cdn to fix it. And no guarantees it would work. Dealership wanted same. But in the end BMW Canada must have recognized it's an issue because they paid a lot of it. Went ahead and had it done. Final bill was about $1700Cdn IIRC. Still a heck of a lot.
So, I bought one of the above off ebay just in case this ever happens again. It's on a shelf cuz I just know it will happen. But at $200, it's a lot of piece of mind.
      08-14-2021, 05:41 PM   #34
Kolianovskyi
87
Drives: BMW 650i
Is there a bulletin or so for this issue?
      08-15-2021, 12:43 PM   #35
pcgold
Not that I am aware of.
      03-28-2022, 03:26 AM   #36
F.saqer
Drives: BMW F10 528i 2016
Bmw f10 2016
Hi, I have the same issue with my 2016 BMW F10, and I have read your post which is really great job. I have order the display, but I would like to ask if also this works for F10 528i 2016? it has exactly the same instruments cluster you have shown in this post.
thank you,
      07-14-2022, 05:13 PM   #37
Kolianovskyi
87
Drives: BMW 650i
And had again same issue after a year. Turn off the car. After 20 min it came back alive.
      07-17-2022, 03:39 AM   #38
FlyinLowSD
Tinker
Drives: 2017 640i GC,1994 300ZX MT 2+2
Originally Posted by Holt2498 View Post
BMW BLANK PANEL 6WB FAULT - solved.
So the message is, if you have the BLANK SCREEN and if updates don’t work, it’s much more serious and likely to be (most definitely) the BOSCH LED DISPLAY which has failed. A few hundred (NOT THOUSANDS AS most and BMW WANTED) we are up and running again, everything works perfect.
Please see attached a picture of the actual part required, the part number is the BOSCH number starting with 89.
Hope this helps someone.
Kind regards Jeremy.
BRAVO!
      02-01-2023, 02:54 AM   #39
cello11
CELLO11
cello11's Avatar
Drives: BMW X5 F15 and 640 Cabrio
I have the instrument cluster 6WA installed in my 640i . Now during the night time the orange background illumination starts flickering and disappears and reappears both on speedometer and rpm indicator. Any way of repairing it? I tried many things but no success.
My current idea is to replace it by the 6WB for approx 1000 EUR. Any opinions?
      07-19-2023, 02:13 PM   #40
Rob BMW 6
Rob
Drives: 2015 BMW 6 series
Holt2498. How did you align the gas and temp gauges and them to work? I've tried twice now and the gauges are working. I'm fairly sure the are aligned. Was some else you did to get them to work?
      11-27-2023, 04:40 AM   #41
Daveashes
Drives: F80 and FO2
Holt2498 where are you located pal and would you be up for a LCD panel swap on my FO2 , I would offcourse make it worth your while pal , I'm located Newcastle upon Tyne
      03-14-2024, 04:01 AM   #42
chiragdaswani97
Drives: F10
Greetings,
I was able to swap out the old lcd panel for the new one in 6wb cluster but the light during the day is very low. I tried correcting it by changing DIM_DTN to 0x7F but had no luck. Kindly help
6post.com
