steering wheel peeling :(
07-16-2012, 06:21 PM | #1 |
yoroshku
Rep 107
Any suggestions on repair? anyone have experienced this? If the plastic was at least black, it'd be OK, but it's white stands out like hell haha
Thanks! |
07-16-2012, 06:58 PM | #2 |
yoroshku
Rep 107
Well. I only searched this forum, and didn't come with any results. After a more extensive search, there seems to be a ton of info in the DIY and Cosmetic/lighting forums here are some links incase other people just search this forum.
http://www.e90post.com/forums/showthread.php?t=516463 http://www.e90post.com/forums/showthread.php?t=476105 http://www.e90post.com/forums/showthread.php?t=243169 http://www.e90post.com/forums/showthread.php?t=575763 |
07-16-2012, 07:05 PM | #3 |
Rep 3,893
Drives: 330i, 135i
Interesting point. I had mine replaced under warranty 5 years ago. I had the same issue, the SA was kind enough to replace it along with the inside door handles which were also peeling off for free. After 3 years or so now the new one is also starting to peel off (steering wheel) but its black and not white like yours so its much better since is not as noticeable. Hope you are under warranty as ask to replace it? Good luck!
07-16-2012, 07:53 PM | #4 | |
yoroshku
Rep 107
07-17-2012, 12:51 PM | #5 | |
15
Rep 162
07-17-2012, 04:45 PM | #6 |
yoroshku
Rep 107
08-05-2012, 03:51 PM | #9 |
yoroshku
Rep 107
All fixed the picture is not very good because of the flash, the alcantara is not grey. Was a bit tricky to remove the cover. Wish the whole steering wheel was alcantara.
08-11-2012, 04:46 PM | #11 |
Rep 11
Had same issue on my previous 330i (e46). I removed the trim, sanded it down, adhesion promoter (USE LIGHTLY), then 4-5 coats of Duplicolor matte black. Even my wife was surprised at how good it looked. Total cost was about $6, as already had adhesion promoter in stock.
