05-20-2013, 11:12 PM | #133 |
20
Rep 121
i was going to do this to my e36 M3 with the ZHP modded knob so it illuminates, but this way its less of a hassle for only $15 more.
05-21-2013, 04:51 PM | #135 |
Rep 1,629
The OEM knob and boot are worthless so its not a big deal to sacrifice the ring for a greater cause. After the F10 M5 knob is installed you will gladly burn the stock on and not think twice
05-21-2013, 05:00 PM | #136 |
Rep 4,002
I just took my M5 knob off and will be for sale, bought it a few miles ago and its like new. Getting rid of the E90 and going with a DCT E92
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
05-22-2013, 10:07 AM | #137 |
Rep 8,496
by "ring" you mean the plastic frame that snaps onto your center console? The answer is No. standard 3-series cars rights are larger and simply just different shape
06-01-2013, 02:06 PM | #138 |
Rep 459
I must be some sort of wimp....I have tried my hardest to get the OEM knob off but it refuses to budge.
Is there any sort of technique here, or is it just a case of heaving up in the direction of the lever itself? TIA |
06-02-2013, 06:29 AM | #139 |
274
Rep 2,665
Drives: Goggomobil
Just muscle power. Make sure you don't smash your face as you pull the shift knob up. It is very tight but the only way to remove it, is to pull it up. Good luck.
F86 X6///
06-04-2013, 08:11 PM | #141 |
DHS
222
Rep 4,037
Drives: 2023 M4, 2020 Land Rover
Looks ok.
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
07-08-2013, 09:36 PM | #142 |
Rep 1,790
07-16-2013, 11:41 PM | #148 |
Rep 1,102
Changing the shifter actually makes it sportier! I didn't think it would be a huge difference but shifting is much better.
Thanks for the DIY, it helped tremendously. Unclipping the wires was annoyingly difficult but once off I carefully removed the OEM boot from the ring by pulling with my fingers then using a razor to CAREFULLY scalp/delaminate the leather off. I didn't want to cut up the OEM leather too much in case I want to use it again, not to mention it's just bad form. I've read how many folks here had a difficult time getting the thicker M5 leather to allow the ring to clip back down so I made sure after the OEM boot was removed the OEM ring was as clean of debris as possible by scraping away all glue and bits of leather remaining. Next I put the M5 boot on, determined and then created the location of where to place holes in M5 leather and voila! I tucked the leather under the ring (NO GLUE, NO CLIPS) and snapped it in. Took me 2 hours while in conversation with my 3M clear bra installer. I highly recommend this mod. For me this also allows my elbow to rest where it should be while still keeping a hand on the shifter.
2011.75 Jet Black E92 ///M3: ZCP|6MT|FR|EVOLVE 600 SUPERCHARGER|DINAN|BBS|VORSTEINER|BMW PERFORMANCE|IND EDITION|TMS|LUX 5K| |
07-17-2013, 03:25 AM | #149 |
Fight On!
109
Rep 325
For those that did the mod, does the leather match the other leather pieces (e.g. handbrake)? I realize it's thicker, but I am concerned from the outside appearance perspective.
07-17-2013, 04:14 AM | #151 |
Rep 1,083
I don't notice, my GF and friends don't even notice I got a different knob
07-26-2013, 07:54 PM | #152 | |
E90 6MT MASTER
74
Rep 314
07-29-2013, 02:52 PM | #154 |
Rep 459
I can definitely recommend this mod.
As well as being aesthetically much nicer, it does genuinely improve the feel of the shift, even between 1 and 2, which is normally regarded as a weak point with this transmission. For disconnecting the electrics I used a very small flat bladed screwdriver inserted into the locating lug. For separating the boot from the locator ring I used a metal letter opener - thin enough to get between the plastic and the leather, strong enough to not bend and with an edge that is not too sharp, so less likely to cut through the leather by mistake. |
