03-26-2015, 04:53 PM | #91 | |
BMW 4 Life...
149
Rep 3,360
So how are u liking your tune? It's been a while; any noticeable difference?
MODS: *** / M Sport + Performance / Meisterschaft / Challenge / MORR / more to come! ***
03-26-2015, 05:11 PM | #92 |
Rep 3,688
Drives: 2021 Supra 3.0 (Past: 2015 M23
What are the downsides? the OBD2 port could be permanently damaged?
03-26-2015, 06:10 PM | #93 | |
8217
Rep 18,823
Drives: BMW
Worst case scenario would be forgetting to turn off the module and a BMW tech spending time troubleshooting why a scanner isn't communicating properly.
03-26-2015, 06:28 PM | #94 | |
Rep 616
The "external code reader" you may be referring to is the Dinan programing computer. The way the Dinantronics works is you install the complete harness and control module. Then the programing computer wirelessly programs the Dinan module with the performance software level that is chosen. Nothing interferes with communication to the car. I have programmed and installed many Dinantronic units with never an issue |
03-27-2015, 08:27 AM | #95 |
Rep 1,517
I have personally never tuned, nor have any interest in modifying my stock vehicles from the engine perspective. But just for purpose of discussion (and my lack of knowledge) how would an Alpina tuned vehicle differ from many of these? I assumed they have all new ECU's created (and various other internals ie.. intercoolers/fuel pumps etc...) but I was just curious.
Reviews of the B3 for example, reflect they certainly do something right. |
03-27-2015, 10:56 AM | #96 | |
145
Rep 170
We do not like to tap into CAN bus on our customers cars. We use ESS E-Tronic due to the features, power and control they offer while not having to access CAN bus or crippling the OBD port. |
03-27-2015, 03:42 PM | #97 | |
Rep 508
I always thought it would be required that a CAN BUS enabled tune would turn itself off it anything was ever connected to the OBDII port but now I understand why they have not enabled it that way. It's a sneaky way to block would-be car thieves. I would be willing to bet if users were to demand that the piggyback disable itself if anyone were to plug in to the OBDII port such a firmware revision or option would be quickly released. Has anyone ever asked for this? |
03-27-2015, 03:44 PM | #98 | |
Rep 508
03-27-2015, 04:20 PM | #100 | |
8217
Rep 18,823
Drives: BMW
As soon as a diagnostic connector is plugged in, it goes into diagnostic mode. The Macht Schnell EVC module also is passive, leaving the OBD2 port open while in use. Testing as we speak. Once these become mainstream, piggybacks will start phasing out.
03-27-2015, 05:49 PM | #101 | |
Rep 616
Yes it wont do that at this current time. But you would need a diagnostic to do fault reading, programing etc. from obd port regardless. S1, S2, S3, etc are only a specific label the vehicle receives after "X" amount of Dinan items installed on a vehicle. It is not just a specific level of software. Dinantronics may be able to do fault code reading/clearing in the future when the Bluetooth app is available for customers. But that is not confirmed at all yet. From what I know, the Bluetooth feature will allow the user to switch between maps and a valet mode Last edited by A Frankfurt; 03-30-2015 at 11:38 AM.. |
05-26-2015, 01:19 PM | #103 |
Rep 1,178
Will COBB have a tune for this car soon?
2002 E46 M3 Coupe.. SOLD
2011 BMW 1M Coupe SOLD 2013 BMW M3 Coupe SOLD 2014 BMW 335i MPPK SOLD 2015 M3 SOLD |
05-26-2015, 01:27 PM | #105 |
Joint Chiefs of Staff
4918
Rep 115,980
06-24-2015, 11:09 PM | #107 |
117
Rep 105
Updates as of late.
I still haven't installed the new JB4 OBD cable as I ran into a few difficulties after my first attempt. So right now it is still "tapped" into the CANBUS in engine bay. Power is still fantastic even in hot weather. I also sent in my old ESS module for a new one that does not have the battery drain "feature". I may install it after next oil change but I've been very busy. |
06-29-2015, 03:41 PM | #108 |
Gone Fishin’
7318
Rep 12,125
I've run both JB4 in map1/2 and ESS e-tronics in stage 1/2. If you have any specific questions I would be glad to answer them.
JB4 OBDII connector does not seem like it was tested at all on 6MT cars. Frankly I feel like a stepchild running 6MT with JB4 these days. The power is great but the features always seem to be more buggy on 6MT cars. |
06-29-2015, 08:27 PM | #109 |
117
Rep 105
I finally switched to the ESS tune and I have to say what everyone else has said - it is very smooth and pulls just as hard as the JB4. I was somewhat skeptical of the smoothness claim as it came from people who had automatics but I would argue it is also applicable to manuals.
So far I've tried the linear (1) and normal (3) maps on 91 octane with no plus or minus in boost. Where I really notice the difference is in the low end - below 3000 rpm. There is a noticeable power/torque increase compared to the JB4 and it follows up with smooth ripping power as you increase in RPM. I'm quite impressed. Aside from having to splice wires and all that with the JB4, I actually found the ESS a bit more difficult to install. The CAM sensor was tricky to remove (performed with long skinny flat head) and to install (really tight area if you don't remove the intake pipes which I did not). So the saga continues... |
06-30-2015, 08:55 AM | #110 | ||
1860
Rep 2,104
Also, have you noticed any more traction issues with ESS over JB4? I had just about eliminated JB4 for myself, since I wanted mainly a 'set it and forget it' tune that offered max reliability. JB4 seemed to allow the most tinkering, Dinan the least (and is too expensive); ESS might have been just right. But then one of the forum members switched from ESS to JB4, saying ESS wasn't very linear or had some problems or something. And I also realized you can just tinker JB4 to make it very conservative. Which left me even more |
