01-31-2021, 02:53 PM | #1 |
134
Rep 257
Keepig tabs on brake caliper temps at track
This is after 2 full sessions, ~20 laps or so. MPS4S tires (300TW). CCB calipers but system converted to giro disc steel rotors and DS1.11 pads. It was a cool day with ambient temps in low 50s. WINDY as hell.
The 6 piston calipers must run cool, didn't even register temp both on outside as well as middle of the calipers. Rears run about 280-320 which makes sense since I leave MDM on so its probably traction control working. Rear passenger got hotter than rear driver which must be because of my track's specific layout of left vs right handers. Interesting data. Last edited by USSEnterprise; 01-31-2021 at 03:25 PM.. |
01-31-2021, 03:00 PM | #2 |
Rep 939
cool
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
01-31-2021, 04:20 PM | #3 |
Rep 1,730
Sheesh. I get more temps into my lighter e46! That's a bit weird...
2018 Grigio Telesto F80 M3 DCT | :: Bone Stock :: 2004 Titanium Silver E46 M3 6 Speed | :: Track Car :: |
01-31-2021, 05:08 PM | #4 | |
134
Rep 257
Of course with r-comp tires and on a hotter day when I'm going much faster (hopefully), I would assume caliper temps would be hotter. However, in my experience so far, the F80 brakes are proving to be very well engineered. Out of the box. Last edited by USSEnterprise; 01-31-2021 at 05:18 PM.. |
01-31-2021, 05:31 PM | #5 | ||
Rep 1,730
01-31-2021, 05:44 PM | #6 | ||
Rep 3,412
The calipers looks fantastic and the monster rotors should be a decent heat sink. Running r comps with some more pace will start to highlight their weaknesses, but I believe the caliper will at least start to heavily discolor pretty by that point.
Not a Doctor, those are just my initials.
01-31-2021, 07:56 PM | #7 | |
Rep 10,509
Consider Dsc off with street tires for a while and see if there are opportunities to heat up the front brakes with more aggressive threshold braking at entry? Cool pics, and great looking rotors! |
TractionControlDelete4602.50 |
02-01-2021, 12:06 AM | #8 |
Rep 886
Good stuff man. Next try mdm off, you'll probably knock off a few more seconds. After that get harder on the brakes to find more time, after you are comfortable at that pace...let's talk tires!
What suspension are you on?
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
02-07-2021, 07:41 PM | #9 |
134
Rep 257
Ran 4 sessions today with Hoosier R7s. DSC completely off. Cold day, was in the low to mid 40s. To put my pace in perspective, I was running about 5 seconds slower than GT3s at my local track.
Got the front calipers up to 320 or so degrees, but still runs much cooler than I would have thought. Very happy with F80 CCB calipers. |
DRLane3996.00 |
02-08-2021, 12:45 AM | #10 |
58
Rep 207
How's the noise when the DS1.11s get up to temp? When I was bedding they were squealing so bad that it was unbearable. Specifically the rears since I used DS1.11 fronts/ DS2500 rears and I'd be able to manage with them on for a few days after the track since the squeal was very tolerable compared to now with the DS1.11 rears
02-08-2021, 09:53 AM | #11 |
Rep 1,730
i run 1.11's in an ap racing kit up front and they have zero noise on the track or even driving around town.
02-08-2021, 12:55 PM | #14 |
134
Rep 257
How big are your rotors (they look kind of small?) One possible answer is the 400 mm F80 rotors have a much larger area to dissipate the heat (as well as extra cooling vanes built into the girodisc rotors - im not sure thats the case but im speculating?)
Piston design and diameter also contribute to heat in the caliper. On my race bikes, I upgrade the aluminum Brembo pistons to aftermarket stainless pistons (Braketech) that cool better and allow for more fluid in the system. We'd have to compare the F80 CCB caliper's pistons to the AP caliper and its pistons. Last edited by USSEnterprise; 02-08-2021 at 01:13 PM.. |
02-08-2021, 02:26 PM | #15 | |
Rep 3,750
There is a larger surface area on 400MM rotors but because the F8X has zero airflow to the brakes, it'll also hold more thermal mass. My stock iron calipers reached 700-800F - it's why I had to change them. I ran DSC Off with DS3.12s. Do you threshold brake? Toyo RRs were definitely putting more heat into my brakes than MPS4S would but not registering even 250F in the front is highly sus. The stock calipers/lack of airflow are a heat loving combo. Even if the girodiscs helped cool the rotors, the caliper will have a hard time dissipating that heat. They're terribly designed for track use. |
02-08-2021, 03:42 PM | #16 | |
134
Rep 257
I'm not the fastest driver out there by a large margin, however, those temps are from a car running within 5 seconds of GT3s on a 2+ minute lap so I'm not put-putting out there either and car sees a good workout. I don't subscribe to the zero airflow hypothesis. Sure it has no ducting but there are functional vents at the edges of the bumper that direct air to the outside of the rotor/caliper. I don't imagine my CS front bumper is unique and even base/comp M3s have the same vents, but I could be mistaken? Keep in mind my data is also from winter time track days with temps in the 40s. On a 90 degree Texas summer day, I'm sure the calipers will heat up more. And as they do, I will share in this thread. Please continue sharing your data as well including your specific setup as you did, helpful for folks to get more data. Last edited by USSEnterprise; 02-08-2021 at 03:52 PM.. |
02-08-2021, 04:13 PM | #17 | ||
Rep 3,412
Also, in the spirit of sharing meaningful data would be helpful to see a speed trace from your faster laps.
02-08-2021, 06:09 PM | #18 | |
134
Rep 257
To gauge a 2:08/2:09, you can simply search on youtube for "Eagles canyon gt3" so you don't have to take my word for it. Majority of the fastest road cars around ECR now happen to be GT3s/GT3RS/GT2RS, hence the benchmark. Regarding thickness of the rotor, I can't seem to find it on girodisc's website. I know it doesnt mean much but minimum thickness stamped on rotor is 34mm. Here's a weight comparison of them when I replaced the CCB rotors (they are ridiculously heavy). |
02-08-2021, 06:47 PM | #19 | ||
Rep 3,412
A look at NASA time trials at ECR last November in the TT2 and TT3 which is where the f8x would likely land. The fast laps are 1:53, 1:55 respectively. Looks like anything sub 2 mins is cooking... So you likely have a lot of room to progress with that setup.
02-08-2021, 06:58 PM | #20 | |
134
Rep 257
Here? https://racehero.io/events/nasa-texa...aceway/results Not seeing any 1:53s, the fastest laps I'm seeing are 2:02s. |
02-08-2021, 07:05 PM | #21 | ||
Rep 3,412
Gomeler500.00 |
02-08-2021, 07:09 PM | #22 |
Rep 886
Hey all,
I have these 400mm Girodisc rotors as well, the radial depth is 3in for those who asked...massive thermal batteries! These rotor's vanes cool exceptionally well compared to the carbon rotors & the bulk of the cooling gains we are seeing are from the rotor vanes acting as air pumps. The massive pads are also a benefit for brake temp management!
USSEnterprise134.00 |
