11-12-2022, 12:04 PM | #1 |
Rep 38
F33 door wiring loom diagram
Hi all can anyone help me with a wiring diagram for the front door loom on a F33 4 series 2015 I have a diagram but it dont have the colours of the wires on it.
It's the colours of the wires I need please :-) Thanks |
11-13-2022, 08:53 AM | #2 |
Rep 7
Anything you are looking for in particular? The wiring diagrams are broken up into multiple different drawings. I've attached the drawing for the door connector, if that helps, but doesn't tell you what each wire is going to/from.
11-13-2022, 10:11 AM | #3 | |
Rep 38
I have a F33 and wanted to see if there was a possible solution to get the wing mirrors to fold on lock and unlock. This is a feature that cannot be enabled through coding so i was going to see if i could find another solution :-) |
11-20-2022, 06:20 PM | #4 |
Rep 7
I haven't tried this so I don't know if/how it works, but the coding guide I have says that in the FEM_BODY, Section 3053, you can enable/disable folding and unfolding the mirrors when holding lock/unlock on the key fob.
The Functions are: KOMFORTOEFFNUNG_FB and KOMFORTSCHLIESSUNG_FB For comfort access, there is also ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN and ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN under FEM_BODY section 3110 I don't see a delay setting, so I'm not certain how quickly they will fold/unfold when holding the buttons. |
